Author Topic: RS PRO / Siglent 1052DL+ stuck at boot logo.  (Read 17927 times)
Offline Oknaj
  • Country: cs
Re: RS PRO / Siglent 1052DL+ stuck at boot logo.
« Reply #25 on: October 31, 2023, 06:34:45 pm »
Hello, same with me! It is the second time this has happened.
First time, I send it back to seller and they fixed the scope.
Since this is a normal behaviour for this type of device, I would like to be able to repair it all alone, without waiting several days (or weeks) for the seller.
Can I have this recovery package, please?
Siglent SDS1102CML+
Tried the "math" button trick, with no success.
Offline LucHeylens
« Reply #26 on: November 02, 2023, 05:53:43 pm »
Hello everybody,
My Siglent 1052DL+ stays frozen at boot screen (SIGLENT splash screen).
Of course, I tried the "heart massage" on the MATH button, many times, but it does not help.
Can someone help by sending me the famous "USB recovery package" (that seems to be THE solution).
Many thanks in advance !
Luc
Offline tautech
« Reply #27 on: November 02, 2023, 06:38:12 pm »
Hello everybody,
Luc
Welcome to the forum.
Yes, the only solution when MATH does not work.
Send PM with your email contact.
Currently travelling....
Offline Andrea2603
« Reply #28 on: December 12, 2023, 11:05:59 am »
Hello everyone, after searching online I stumbled on this site.
I guess I have the same problem as you guys have, got a RS1052DL+ stuck on boot screen.
Tried multiple times the math button reset but haven’t worked.
Any kind soul could help me with the usb reset?
Thank you everyone
Andrea
Offline tautech
« Reply #29 on: December 12, 2023, 11:15:55 am »
Thank you everyone
Andrea
Check your messages.
Offline malinda
  • Country: lk
« Reply #30 on: December 29, 2023, 05:19:41 pm »
Hello I have the same problem with my RSDS 1052DL+... I get stuck at logo boot
From Sri Lanka
Offline jtorregl
« Reply #31 on: February 01, 2024, 11:00:21 am »
Hello to everybody
I'm happy to read that the problem with my oscilloscope has solution.
In my case, I have a RSDS 1152CML+ (150 MHz) and it is brozen showing a screen with the RS PRO logo. I've tried the solution of the "Math button" but it didn't work.
I read in the forum that there is the posibility of reinstalling the software via USB or somethink like it. Please, don't hesitate to contact me and send me the files to try to fix the oscilloscope.
Thanks in advance.
Offline Kit
  • Country: co
    • kit electronica
« Reply #32 on: February 14, 2024, 05:26:21 pm »
Hello everybody, my SIGLENT SDS1202X-E (buy it in december 2023) start up fine but any control doesn't works, several minutes later is working again.
math button trick not work at all. Please help me. Thank you.
Note: My house do not have earth connection (ground). This will can be a problem?. Excuse my poor english!!.
Offline adam4521
« Reply #33 on: February 14, 2024, 06:19:28 pm »
Yes, you need to have that fixed. Check local codes but TT system, at least.
Offline Kit
  • Country: co
    • kit electronica
« Reply #34 on: February 14, 2024, 09:35:05 pm »
I used this oscilloscope in other place with earth connection and happens the same.  :-BROKE
Thank you.
Offline lsara
« Reply #35 on: February 21, 2024, 05:07:46 pm »
Same issue with oscilloscope RS PRO RSDS 1072CML+ ! it stays in the RS Logo.
Could I have the recovery package please?
Many thanks!
Offline lsara
« Reply #36 on: February 22, 2024, 03:34:16 pm »
Many thanks, the fix worked!! :)
Offline neskor
  • Country: cs
« Reply #37 on: May 04, 2024, 12:44:22 pm »
Hello I have the same problem with my RS PRO RSDS1072CML+, stuck at RS logo boot.
Can I please have this recovery package.
Thanks in advance.
Offline James2680
« Reply #38 on: May 13, 2024, 03:48:27 am »
Hi, looks like this is a common problem. Mine was working last Thursday and then Friday no go. I to have a SDS1102 DL+, stuck on boot screen still under warranty, but if i can avoid sending it away and losing 2 week that would be great.
Can you please supply me the fix tautech as well?
Many thanks in advance and for all the help you have provided here on this thread.
Offline tautech
« Reply #39 on: May 13, 2024, 06:35:13 am »
Please send PM with your email address.
Offline James2680
« Reply #40 on: May 15, 2024, 01:06:21 pm »
Well finally got to town and purchased an 8Gb usb drive. Not many places stock the 8Gb's. Did as instructed and I now have a working oscilloscope. Many thanks tautech you saved me time and money. :)
Offline DelticEngine
« Reply #41 on: May 18, 2024, 02:23:54 pm »
I have the same problem, but with a different device. I have an RSPro RSDS 1072CML+ which, as far as I know, is a rebadged Siglent SDS1072CML+. I read about the method using the 'Math' button but this did not fix the problem and my 'scope it still stuck on the boot logo. I also tried downloading firmware from Siglent and put it onto a clean 1GB flash drive. The 'scope read the flash drive but nothing changed. Is there a special firmware or software that I can put onto a USB flash drive to fix my 'scope ?
Offline neskor
  • Country: cs
« Reply #42 on: May 20, 2024, 09:07:26 am »
I have now a working oscilloscope.  :-+
Thank you Tautech!!!
Offline mrivett
« Reply #43 on: July 22, 2024, 06:11:39 am »
Hello
I have the same problem with my RS PRO RSDS1052DL+, which is stuck at the RS logo boot.
Can anyone send me this  this recovery package.
Many Thanks
Offline tautech
« Reply #44 on: July 22, 2024, 07:21:01 am »
Hello
Many Thanks
Offline slawekmod
« Reply #45 on: August 07, 2024, 07:16:16 pm »
Good morning.
Hello everyone. I have a problem with my Siglent 1072 CML+ oscilloscope.
The oscilloscope had not been used for two years. Today, after turning it on, it stopped at the Siglent logo. It does not respond to any buttons, the USB port for communication with the computer does not work. You cannot reset using the Math function.
The oscilloscope was used for approximately 100 hours.
Please help.
Sorry, I don't speak English and I use a translator.
Greetings from Poland.
Sławomir.
Offline tautech
« Reply #46 on: August 07, 2024, 08:20:18 pm »
Good morning.
Please help.
Sławomir.
Offline slawekmod
« Reply #47 on: August 07, 2024, 08:43:18 pm »
Hello
Yes, I received the message.
I replied to the email.
Thank you very much for help.
Regards.
Sławek
Offline slawekmod
« Reply #48 on: August 07, 2024, 08:58:53 pm »
Big thanks.
The oscilloscope works!
Thank you very much.
Regards.
Sławomir
Offline Stestef89
« Reply #49 on: August 09, 2024, 11:32:30 am »
Hi everyone, I have the same problem on my RSDS 1102CML+ oscilloscope, freezed on the boot logo RSPRO.
I tried with math button but nothing change...
Someone can help me please?
Thanks in advance
