Author Topic: R&S PSU number of channels needed  (Read 762 times)
Offline salomonanderTopic starter
« on: October 09, 2024, 12:29:29 am »
Hey,
I often need voltages like +-15v and +-18v. Will i need to get at least a two channel psu? Or can the r&s supplies do it with one channel?
Thanks
Offline tautech
Re: R&S PSU number of channels needed
« Reply #1 on: October 09, 2024, 01:35:52 am »
Split rail designs normally need a 0V reference where a 2ch PSU in Series mode/configuration is the normal solution although a on-board voltage divider or LM78**/79** regulators are sometimes also used.
18V spit rail will require 36V or more with is a value beyond what is normally considered the 'industry safe' of ~30V.
Best versatility will be provided with a 2ch PSU providing 30V/channel.
« Reply #2 on: October 09, 2024, 10:30:22 am »
Thanks!
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #3 on: October 09, 2024, 10:31:19 am »
Pretty much all R&S supplies can output at least 20 volts, and several go up to 32, 64, or 100 volts
https://www.rohde-schwarz.com/us/products/test-and-measurement/dc-power-supplies_64067.html
We also sell a four-quadrant SMU (the NGU) that directly supports -20 volts to +20 volts.  If you want to do it all with one channel on one supply, that would be the easiest way to do it.
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline coromonadalix
« Reply #4 on: October 09, 2024, 11:50:42 am »
you have many who track rails IE   adjust them simultaneously ... 1 master the other channel as slave
unless you go with fixed ones too ... ?  it depends of your current requirements
0-30vdc (per channel) models are the most common, some have switches to do single/ separated, in serial or in parallel,  but  a positive and negative one at the same time,  haven't seen a lot
as Tautech wrote,  you need a ground reference and isolated supplies from each other ....  and you put them as attached image, nothing fancy,  but you need to adjust them separately ...
« Reply #5 on: October 09, 2024, 05:32:21 pm »
Sorry i did not think this through  :palm: i work in pro audio and often repair gear from the early transistor age. Switching power supplies are a no go in my field. Do the oldschool R&S psus with VU meter behave more like an old fashioned transformer/regulator power supply? They would also cost a fraction on ebay.
« Reply #6 on: October 09, 2024, 06:16:37 pm »
the less noisy psu's  are toroid based x-formers
« Reply #7 on: October 10, 2024, 10:30:21 am »
Thanks,
yes after some research i realized that R&S have transformer based versions as well. Its just hard identifying them. So far im pretty certain that HMP2000, NGA100, HM8143 and the old NGE100 are transformer based. But some seem to still have a switching element like the NGE100 series. Im wondering if its the same for NGA100? Can anyone confirm which ones are linear transformer based without any switching element? Thanks
And another noob question: does the arbitrary mode in some psus allow me to use one channel as a sinus generator? Or am i understanding that wrong?
« Last Edit: October 10, 2024, 10:59:39 am by salomonander »
« Reply #8 on: October 10, 2024, 11:11:02 am »
Did more reading. Looks like the NGA is the only true linear psu they build. All others mentioned claim a mixed architecture. A transformer into a rectifier and the into switching mode circuit. I honestly dont know if hybrid will work for me. And please correct me, if i did my research wrong.
Offline glitchcatcher
  • Country: at
« Reply #9 on: October 10, 2024, 01:12:49 pm »
They have some nice documents explaining a lot:
https://www.rohde-schwarz.com/products/test-and-measurement/dc-power-supplies_64067.html
On that site, click:
Fundamentals of DC Power supplies – output characteristics
and
Fundamentals of DC Power supplies – measurement & monitoring
Find a compilation of characteristics attached.
clandestine one-man UNI-T fan club
« Reply #10 on: October 10, 2024, 01:20:51 pm »
Thanks Flo, thats awesome! I have never seen that comparison list.
Is there a similar one for the older models? From the newest versions it would be the NGA102 for me. It seems to perform well from the charts.
« Last Edit: October 10, 2024, 01:31:24 pm by salomonander »
  • Country: at
« Reply #11 on: October 10, 2024, 02:57:53 pm »
Yeah I also discovered this just recently.
The only other datasheets I have is a PDF with many older models, see file attached.
« Reply #12 on: October 10, 2024, 03:22:15 pm »
Thanks!
Im pretty set on a NGA102 now. But i could get the HMP2030 for a fraction of the price. Its one of the hybrid ones. And im not educated enough in order to tell if this will work just as well as the NGA for audio. Can anyone else tell? If its suitable it would be a no brainer (i can get it for 500€ new).
There is a little info on construction on page 34:
https://cdn.rohde-schwarz.com/hameg-archive/HAMEG_MAN_DE_EN_HMPSeries.pdf
According to Flos document, ripple on the HMP is a lot higher though. Maybe due to the hybrid design?
« Last Edit: October 10, 2024, 05:54:19 pm by salomonander »
