Hi guys,
I'm new to oscilloscopes and decided to pull the trigger on a new R&S RTC1002 after quite a bit of research. There isn't much info on these available on the internet yet. I was torn between this and a Keysight 1000X. I know the Rigol's are cheaper, but I suppose you can say I have a bias towards German engineering. A couple of the things I liked about the RTC1002 over the Keysight was:
1: The LAN port for remote viewing/control on a big screen. Who cares about screen size if you can do that? Not available on the 2 channel Keysight.
2: The component tester.
3: The ability to upgrade to 300mhz.
4: The fast boot up time
5: Made in the Czech Republic in R&S's own quality controlled factory rather than a 3rd party Chinese factory like the Keysight
There's a promotion on now to get the unit fully loaded for only $1900. Which is around $2000 cheaper than if I was to upgrade to all the same features later. It was tempting, but I'm not sure if I need 300mhz, or the MSO feature right now. I do like the signal generator feature, however its only $195 purchased alone. So I will probably order that.
If anyone else has any comments or feedback on this unit please share.
