Author Topic: BWD 1722B large screen CRO  (Read 337 times)
Offline duodiode62
« on: October 04, 2020, 10:42:46 pm »
Hello.  I recently obtained a BWD 1722B oscilloscope and would like to obtain a service manual for it, or at least a decent circuit diagram.  Can anyone out there be of help?
Cheers, Stuart
Re: BWD 1722B large screen CRO
« Reply #1 on: October 05, 2020, 12:01:34 am »
Welcome to the forum.
Oh wow.....and it's like large display DSO's today are something new !  :-//
The best BWD resource is Kevin Chant and if he hasn't posted any documentation on these drop him a line with maybe a link back to this thread to see the size of that beast.  :scared:
https://www.kevinchant.com/bwd.html
Avid Rabid Hobbyist
Offline amspire
« Reply #2 on: October 05, 2020, 01:00:38 am »
It is probably sharing some of the circuitry with other models which have documentation.
Is it a tube + transistor circuit inside? It looks a bit like their 5MHz oscilloscope models.
Richard
Offline duodiode62
« Reply #3 on: October 05, 2020, 01:29:33 am »
Thanks Richard.  I'll have a look at other models.  Yes, it is a hybrid design, with 6CW4 nuvistors in the vertical amplifiers and 12AT7s in the time base, as well as lots of transistors.  The E.H.T. generator also has valves.  I may have come unstuck here, as the core of the E.H.T. generator transformer is broken; however, it does look like a Philips standard line output transformer as used in millions of 1960s B&W TV sets, so I may be able to find a replacement.  The vertical and horizontal deflection power amplifiers use heaps of 2N3055s driving what looks like a standard TV deflection yoke.  The CRT is a '50s style 70 degree 17" TV type, looks to be a 17CGP4.
Thanks Tautech.  I've looked at Kevin Chant's site, and its not there.  But I will have a look through to see if there are similar pre-amplifier and time base designs.
Cheers, Stuart
Online james_s
« Reply #4 on: October 05, 2020, 04:23:58 am »
An analog scope using magnetic deflection has got to be very slow by scope standards. It might make a good vector monitor to play something like Asteroids on.
Offline amspire
« Reply #5 on: October 05, 2020, 05:57:47 am »
That scope turns out to be only 15kHz bandwidth - that is not a misprint. Trigger goes to 25kHz.
It is designed for viewing electro-medical outputs, classroom demonstrations and servo waveforms.
1722B is the mainframe and plugins include 17A (balanced input to 25mV/div), 17B/2 (unbalanced 30mV/div) and 17D (50uV/div).
So I doubt that looking at any other manuals would help - it is a very specialised model.
