Been using the RTB2004 and ran into some suboptimal situations and wanted to get input from experts and see if I should file for feature enhancements.
1. Instead of fixing the trigger to the left/middle/right, have the ability to let the user set the position.
2. Extend #1 to have five presets instead of the three. Use pressing the Horizontal position knob to cycle between them.
3. Channel vertical rearrangement
a) Swap channel position while keeping the scale the same.
Currently, one has to select the channel, move it to almost the final position, then select the other, move it to the final position, then select the first channel and move it to the final position.
b) When moving a channel, instead of overlaying the move, swap with the one in the direction. One will have to select whether to "jump past" vs overlay. I totally get that overlaying channels is incredibly important and useful.
4. In the Math on waveforms, add ability to filter waveform - specify corner frequency, filter type (high, band, low) and it is applied to the incoming channel.
5. Ability to do math on more than two channels.
6. Show pairs/triple waveforms as vectors on a polar plot.
