What's the name of these fuses?
May I ask why it's a bad idea to connect a battery to BLACK/RED?
1808 125V/10A Littelfuse
For the same reason that cars cannot move in the oncoming lane.
Has anyone used any other off-the-shelf power supply for the RD6012 please? Preferably something with integrated temperature control for the fan, as the S-800-65V 11.4A is noisy according to user reports around
NVVV S-800-70 (800W / 70V = ~11.4A)
I ordered another one NVVV S-800-65 (800W / 65V = 12.3A), and today got the package, looks OK.
The fan is not working at all, if there is no load, and it really depends from temperature.
--- RD60062_V1.32.11.bin ---
+ When edit "ScrsaverBright" or "Power LED" now you can see the real effect...
+ Added option "Comm Buzzer" make a sound when the software writes new parameter(s).
+ Option "Mem Hint" now can select the time how long show the message (2, 3, 5 sec)
+ Added option "ShiftMemTable" Press SHIFT to display the table with settings for all memory slots.
+ Added new menu group "- Colors -", now you can choose what color (one of 15) to use for the next parameters:
Voltage, Current, Power, Input, V-Set, I-Set, OVP, OCP, OPP, Ah, Wh, Temp, BattVoltage, BattInfo (Layout 2).
Option "Custom Color" allow to use selected colors (using this option you can enable/disable custom colors in bulk).
Option "Test" is just temporary option and will be removed in next release,
can be used to see any color and its hex value.
List of colors need be adjusted, if you have any ideas just let me know (tell me hex values).
// Here is the current list of colors.
const uint16_t g_colors[16] = {
0, // 0 - Default
C_RED, // 1 = 0xF800
C_GREEN, // 2 = 0x07E0
C_BLUE, // 3 = 0x001F
C_WHITE, // 4 = 0xFFFF
C_YELLOW, // 5 = 0xFFE0
C_MAGENTA, // 6 = 0xF81F
C_CYAN, // 7 = 0x07FF
C_LIGHT_BLUE, // 8 = 0x01CF
C_GRAY, // 9 = 0x8410
C_BROWN, // 10 = 0xA145
C_ORANGE, // 11 = 0xFD20
C_OLIVE, // 12 = 0x8400
C_TEAL, // 13 = 0x0410
C_PINK, // 14 = 0xFDF9
C_MAROON // 15 = 0x8000
--- RD60121_V1.31.3.bin ---
* Bug fixes
+ Minor improvements
+ Option "Save Mult." to save current multiplier (for current session only, reset after restart)
* Increased minimum battery voltage from 300mV to 500mV (Due to some instability)
+ Added option "Power State" (Power On, Power Off, LastState). Sets the state after power on (without a battery, LastState will not remember the last state).
+ Added option "Power Switch" to turn On/Off the primary PSU. (5V standby power supply required). (Note: Adds a 3 second power-on delay).
The control output is routed to the PA14 port (pin 4 of the J2 connector). High level - turn on, floating or low level - turn off.
Note: the maximum load on the port is 20mA !!! (it is better to use an optocoupler).
+ Added option "AutoPowerOff" to automatically turn off after a specified time if the output is disabled.
+ Added option Home:"Status Info" allows you to choose which parameter to display in the status bar (if you need something else, let me know).
+ Added option Home:"Mem Hint" If enabled, then pressing any number key will display a hint with the current settings in the corresponding memory cell for 1 sec,
a second click during this time will apply these settings.
+ added new parameter "7-Seg v2" to option "Digits Style", where "input", "vset", etc. will also be 7-segment.
+ Added display of the system temperature to the caption.
+ Added option "Screensaver" to decrease brightness (ScrsaverBright) after specified time. (Note: "ScrsaverBright" must be less or equal to "Backlight")
Press any key (except ON/OFF) will turn on backlight and restart timer.
+ Added option "ScrsaverBright" Screensaver Brightness (0-complete turn off backlight, 1-equal to "Backlight"=0, 2-equal to "Backlight"=1, etc)
+ Added option "ScrsaverActive" Allow activate screensaver if output is in active state.
+ Removed meaningless icons from the caption.
+ [Left/Right] — switches the current layout (without save) (no need press SHIFT anymore)
- Removed Layout 2 (Layout 3 already shows all values).
List of colors need be aвjusted, if you have any ideas just let me know (tell me hex values).
Here is the current list of colors:
0, // 0 - Default
@unisoft: Does your new power supply also needs to be loaded with a power resistor to prevent this high frequency noise, like the NVVV S-800-70 model?
Above 48V the state changes for CC even with no load connected.
You have the option to choose what to show in layout 1. If it was possible to choose more information?
The shift table could be a little bigger (maybe using the space on the bottom bar?)
It is possible to reduce the buzzer volume?
The M0 (default when power on) don't use the values saved, it uses the last values
