Author Topic: RuiDeng Riden RD6006 DC power supply  (Read 73083 times)
empeka, Tatanka1961 and 4 Guests are viewing this topic.
Offline UniSoft
  • Country: kz
Re: RuiDeng Riden RD6006 DC power supply
« Reply #325 on: September 23, 2020, 08:45:02 pm »
Here is the tool to dump the screen...
Only for custom firmware!!!
The following users thanked this post: Cliff Matthews
Offline tppc
« Reply #326 on: September 23, 2020, 09:22:30 pm »
Hi there,
thanks for this update.
Already flashed  ;D
It looks good so far.
|ON/OFF| button does not flash anymore at startup  :-+
|CC| icon showing at higher voltage setting is corrected too .
French translation looks good too (noticed 2 small errors to be corrected)
- --- Paramètres --- shows strange characters
If no way to correct it, you can also spell it --- Parametres ---, it will be "Good enough for France...:-DD
- "Max d'énergie" could be replaced by "Puissance max"
Default max power is set to 390W how can this be? (6.1A * 61V = 372.1W) maybe I missed something....
Edit : Indeed, I DID miss that it was the power on the primary side  :palm:
TANK YOU!
« Last Edit: September 23, 2020, 09:52:49 pm by tppc »
The following users thanked this post: UniSoft
Offline UniSoft
  • Country: kz
« Reply #327 on: September 23, 2020, 10:20:15 pm »
...2 small errors to be corrected
ReUpload fixed version: 12c ...
* fixed French
* few small fixes
The following users thanked this post: diogoc, Cliff Matthews, tppc
Offline Tepa76
« Reply #328 on: September 24, 2020, 07:34:48 pm »
If you have any ideas, what to add, what to fix, let me know.
Feedback is welcome!
I wish you can add in charging mode user settable parameters Vlpt, Vpre, Ipre:
  • Vlpt = voltage threshold -> if U is below when entering charge mode then don't enable charge! (protection for deep over disharge lithium)
  • Vpre = voltage precharge -> if U is between Vlpt-Vpre then limit current to Ipre default can be 0.1C (protection for light over disharge lithium)
br,
Tepa76
Offline tppc
« Reply #329 on: September 24, 2020, 08:59:01 pm »
Hi there,
+ modified French translation (please check if all correct...)
(still need to make translations for German, and Chinese.)
I tested RD60062_V1.32.12c.bin
Texts are corrected  :-+
Everything looks fine.
The only tweak I would suggest is not to force the Fan on when V-SET > 40V (I know you already answered this issue  ;))
Just in case some volunteer would like to help with English/German translations, I updated the texts file.
Kind regards.
« Last Edit: September 24, 2020, 10:08:17 pm by tppc »
Offline UniSoft
  • Country: kz
« Reply #330 on: September 24, 2020, 10:20:36 pm »
Not all strings was there...
I add missing strings
Offline UniSoft
  • Country: kz
« Reply #331 on: September 26, 2020, 05:18:41 am »
Since there are no negative reviews and interesting ideas, then I can already release the final versions.
Here are versions for all 3 models.
The following users thanked this post: BravoV, rowant, Cliff Matthews, coromonadalix, Tepa76
Offline dsc5555
« Reply #332 on: September 26, 2020, 05:56:19 am »
Fantastic job and effort!
Offline BravoV
  • +++ ATH1
« Reply #333 on: September 26, 2020, 06:19:50 am »
I own too many bench power supplies  :palm:, and I've been following this thread, and damn, UniSoft's great work and contribution alone is teasing me that made me want to buy this RuiDeng PS, just because of the custom firmware.  :-DD
Really, RuiDeng should hire UniSoft, or at least pay for this enhancements on their product.  :-+
Offline diogoc
  • Country: pt
« Reply #334 on: September 26, 2020, 09:13:10 am »
Unisoft thank you  :-+
Sorry but I just noticed now that the new layout 1 options don't appear on the screen
Offline UniSoft
  • Country: kz
« Reply #335 on: September 26, 2020, 02:32:45 pm »
Those new options (V-BATT, T-BATT, I-OFF, T-OFF) have meaning only for battery, therefore will appear only after detect the battery.
Offline diogoc
  • Country: pt
« Reply #336 on: September 26, 2020, 03:00:36 pm »
Oh makes sense. Nice  :-+
Offline gilegue
  • Country: id
« Reply #337 on: September 27, 2020, 01:24:09 pm »
Just one small problem (not sure if it is mentioned before). When I flash my RD6012 either with custom or back to standard v1.31, I cannot set splash screen anymore. All I get is black and white start screen. Not that it is important but I just want to confirm if it is me doing something wrong.
Edit: I forget to mention that this is only happened when I use newer PC Software version 1.0.0.8. If I use the older version, it can write without any problem. I guess it's just the PC app doing something wrong.
« Last Edit: September 27, 2020, 01:29:34 pm by gilegue »
Offline danosimo
« Reply #338 on: September 27, 2020, 07:31:42 pm »
Did you try to start in boot mode when flashing Custom firmware (hold "ENTER" key while powering the RD), also make sure to reset config (hold "0" key while powering the RD). I mean not using the PC software to flash
Offline ptluis
  • Country: pt
« Reply #339 on: September 27, 2020, 09:14:11 pm »
Hello first let me thank Unisoft for this amazing firmware!  ;D ;D and all you guys who have been involved on this  :box:.
I use the RD6006 mainly for charging li-ion battery packs for ebikes. With Unisoft firmware I use layout 2 and 3 (graphic representation of charging process is important to me, been using an oscilloscope previously with my dual analog homemade PS)
I have found another problem with RD6006 module regarding battery reading voltage (show 0.05v less than real voltage). I bought 2 units and this strange "glitch" happens on both units. I attached a image explaining the problem. Do you guys have the same problem? I contacted  RD RIDEN and they said it was in specs, but I wonder if it can be fixed?
It happens with stock firmwares 1.28 and 1.32. I tried Unisoft firmware and the same happens.
Thank you!
Ps. I finally joined eevblog, I'm a regular reader, learn a lot with all you guys.
Sorry for any mistakes but I'm not english native
Offline UniSoft
  • Country: kz
« Reply #340 on: September 28, 2020, 03:19:26 am »
... but I wonder if it can be fixed?
No! Due to low resolution of ADC (12 bits).
The option Upd. R. (Update Rate) cannot in any way affect the measurement accuracy!
It is just averaging the last measurements.
UpdR=Low: averaging the last 6 measurements (sum of last 6 measurements divided by 6).
UpdR=Medium: averaging the last 3 measurements (sum of last 3 measurements divided by 3).
UpdR=High: just 1 last measurement.
Sure.
I used exactly the same calculations as in the stock firmware.
The following users thanked this post: ptluis
Offline Mr.B
« Reply #341 on: September 28, 2020, 04:24:31 am »
...show 0.05v less than real voltage...
I think you may be expecting a little too much from a cheap power supply.
Also, what device (Make/Model) did you use to measure the apparent inaccuracy?
Is that device accurate?
Welcome to the beginning of the Volt Nut rabbit hole...
Time is the overseer of all things.
Offline Cliff Matthews
    • General Repair and Support
« Reply #342 on: September 28, 2020, 12:46:56 pm »
At least, they could offer a fully paid trip to RuiDeng where Unisoft (and nice translator) can charge $2000/day to consult with their developers.
:phew:
Offline ptluis
  • Country: pt
« Reply #343 on: September 28, 2020, 01:19:30 pm »
Hi Unisoft, thank you so much for you explanation. I've been learning alot about how this device works. I can live with this limitation it's a matter of just adding 0.05v to the read value. Normally I prefer technical explanations to better understand how things are programmed rather than "it's in specs".  :-+ :-+
Sure.
I deducted that. I really like your firmware, specially the layout 2 full of information, very usefull indeed, small size font but clear readable, at least to me. I like the way you place the INPUT Voltage spliting other parameters and separated different parameters using boxes.  :-+ :-+ :-+
Offline ptluis
  • Country: pt
« Reply #344 on: September 28, 2020, 01:29:44 pm »
Hi Mr.B, I use an Unit UT61E. It was calibrated on Feb this year using a company calibration professional services.
Rabbit hole, that's why electronics are fun  :)
I know it's cheap, but cheap could be good  ^-^ but you know how we get when enthusiastic  :-DD
« Last Edit: September 28, 2020, 01:46:05 pm by ptluis »
Offline ptluis
  • Country: pt
« Reply #345 on: September 28, 2020, 01:39:38 pm »
btw, what "Save mult" option exactly does?
Offline UniSoft
  • Country: kz
« Reply #346 on: September 28, 2020, 03:53:11 pm »
Save Current Multiplier
When press I-SET, V-SET, etc., will be active last used multiplier, only for current session (till restart).
Offline ptluis
  • Country: pt
« Reply #347 on: September 28, 2020, 04:54:45 pm »
Now I get it   :) really usefull. Thank you!
Your firmware definitely deserves a User Guide  :-+
Offline trazor
  • Country: uy
« Reply #348 on: September 29, 2020, 02:28:11 pm »
I've the theory that UniSoft might be a RuiDeng employee since the beginning. Intelligently a way to develop cutting edge firmwares without the hassle of in depth testing required to have a minimal liability protection. https://en.wikipedia.org/wiki/Skunkworks_project
That will explain the availability of firmware source code, not releasing it and ignoring donation offers.
If this theory is the true or part of it I don't know and I don't care. We have being delivered a great firmware.
Offline DwayneR
« Reply #349 on: September 29, 2020, 06:02:10 pm »
I've been following the discussions here for quite some while now.  I greatly appreciate that firmware updates are being made available as people discover issues.
I have what might be a silly question / comment.  Why is it not possible for these power supplies be able to have greatly increased output current when the output voltage is low.  I do get that there may be issues with dynamic range of the current sense A/D inputs but that is easily managed with suitable component changes.
My great wish is that the 6012 could have an output current rating of 20 Amps at up to 40 Vdc output and lower.  Similar wish for the 6006: 10A max output current at 40 Vdc and lower.
The bulk power supply can handle the power requirements.  It is just the 6006 / 6012 that needs a bit of tweaking.
Comments anyone?
