#1200 Reply
Posted by
ozkarah
on 14 Sep, 2023 01:59
Hi Unisoft,
Could you please share how you wired the capacitor bank?
#1201 Reply
Posted by
UniSoft
on 14 Sep, 2023 09:11
what exactly?
I soldered all capacitors myself, so all capacitors of one channel I soldered in reversed polarity.
Guess I scared off Unisoft with my neverending questions lol.
Why should I get scared?
#1202 Reply
Posted by
ozkarah
on 15 Sep, 2023 10:13
what exactly?
(Attachment Link)
Thanks UniSoft, I got it now.
I checked the ready-to-use boards at the link, and the polarity was problematic as you described it needs to be converted.
#1203 Reply
Posted by
LinuxHata
on 16 Sep, 2023 10:23
Is there any alternative firmware for RK6006 ?
The stock firmware has several issues and manufacturer says it should be that way:
1. You can not adust tens of volts.
2. In current setting mode,if you're in 0-9mA range, when you press the encoder, instead of going into 10-99mA range, it goes into A range, so if you have some weak load connected, it will burn instantly!
3. Output voltage and current has notable fluctuations - say I set output voltage to 4V, the display reading will jump from 3.99 to 4.02 each second, and actual output will float from 4V to 4.12V!
#1204 Reply
Posted by
SpottedDick
on 01 Oct, 2023 22:24
I know the answer to getting that fucking windows application to work with the default firmware is probably in here somewhere, but I just got it working and want to explain what I did.
Went into my router and set my phones WiFi IP address to something not in use. Say 192.168.178.200.
Used the RDpower Android application to setup the RD6018 WiFi. It now saved its server as 192.168.178.200.
Went back to my router and put my phone on a different IP address. I then set my PCs IP as 192.168.178.200.
Bingo, the Windows application can now connect.
Why the utter fuck is the server IP not an option to configure in the default software?!
#1205 Reply
Posted by
LinuxHata
on 02 Oct, 2023 04:34
Brand new RD6012P has issue with negative pole binding post - it gets super hot even at 4A current. And it gets hot from the tip side, not the PCB. I'd like to replace it, but seems that it is directly soldered to PCB, right?
#1206 Reply
Posted by
bateau020
on 02 Oct, 2023 05:59
Yes, they are soldered directly on the PCB. If you want to replace them, you'd best use a good desoldering gun. But maybe the problem is not the post? Maybe it is the contact with your banana plug?
#1207 Reply
Posted by
LinuxHata
on 02 Oct, 2023 08:31
I don't use banana plug, I use fork type connector and already tried to replace it - no difference.
#1208 Reply
Posted by
bateau020
on 02 Oct, 2023 08:59
In that case, before simply replacing it, I would suggest measuring the resistance of the PCB-to-spade/fork connection with a 4W milli-ohm meter, or if you don't have that, with a simple voltmeter while you push a large current through the connection. Compare with the plus terminal. Only if the culprit is really that post, replace it.
It may also be the that the PCB to post solder connection is bad. Or that there is oxidation on the post or spade/fork, that can be cleaned up.
Hello everyone, I have a RD6018 and I would like to make the improvements that UniSoft has implemented for this source. I do not have much experience and I would be very grateful if someone could guide me in the steps to follow and the files that I have to install.
I had forgotten before, many thanks to UniSoft for so much work and greetings to all
#1211 Reply
Posted by
bateau020
on 05 Oct, 2023 05:12
#1212 Reply
Posted by
LinuxHata
on 05 Oct, 2023 08:23
I have thermal camera and heating occurs in the front part of connector, not pcb side. By the way, anyone knows inductance of that big inductor? I want to replace it with higher current rated inductor, to reduce heating.
#1213 Reply
Posted by
Mindstorm88
on 05 Oct, 2023 23:56
Hi there,
Am I the only one having a boot problem (hangs on a blank screen) with the latest UniSoft firmware (RD60062_V1.41.1k) ?
I managed to get my RD6006 to start by holding the "ON/OFF" button at startup, but it gets stuck again on the next power cycle :-/
Resetting to default parameters ("0" + Power On) did not help.
My screen is a ST7789.
Everything works fine with the previous version (RD60062_V1.38.1h).
Very nice job UniSoft by the way ! Thank you !
Fredo_
Hi UniSoft , i do get the same problem. I tried to update after removing the wifi module and the rtc battery, no change i always get white screen with 1.41.1k and all good with 1.38.1h.
BTW , when the screen is white the psu is frozen, nothing works in background, so it is not just the screen that does not erspond..
Any idea
#1214 Reply
Posted by
LinuxHata
on 12 Oct, 2023 13:09
Anyone knows main inductance value of RD6012P ?
I want to install beefier one, to reduce heating.
#1215 Reply
Posted by
ozkarah
on 11 Nov, 2023 15:45
It really seems like a shame that the 6006/6012/6012 are all supported but not the 6024.
Why is it like a shame?
This is not a commercial and not profitable project, just a hobby. And I was interested.
As for the RD6024/RD6012P, I don’t have it, and I do not want to spend money on their purchase.
As for the “shame”, it is better for you to write to developers, this is their work, they get money for this (unlike me).
What prevents them from going along the same way that I, to talk with customers, ask what they need, what they want to see in the firmware.
I think it's a shame that the great work you have done is not available on the RD6024 -- that should be taken as a compliment that your work is mightily appreciated and valued.
And it's a shame that the developers who are paid to do this have not done as good a job as you have on your hobby and don't seem to be interested in making anything but minor improvements to the existing firmware. If only they would be responsive to their customers...
And it's a shame that your work is not open source (though that is 100% your prerogative) so that others could extend all the great things you have done to other models without having to rely on your charity since you totally understandably don't have the resources to support other models.'
And finally, it's a shame on me, because if I had known about your great work and it's limitations to the earlier series, I would have ordered a RD6018 instead of a RD6024 -- again a tribute to your great work!
I hope that better explains what I was intending to say...
BTW, if it's a purely a matter of not having access to a 6024, I would be willing to help contribute to buy you one and/or test any mods necessary on my version. Though again, this is your hobby and I totally understand if you lack the time or interest to extend to other models. My hope though was that it would only require a simple change to a couple of limit parameters since otherwise the models and their UI's seem very similar, at least externally.
One of my RK6006s suddenly stopped working. Nothing happens when you connect it to the power supply. (draws 5-10 mA at 24V)
I used the power and MCU boards of the working one and found out the MCU board was faulty.
If possible could you (or someone else) please measure the SMD resistor (1R5 is written on it) and write to here?
According to its label, it is supposed to be 1.5 Ohms but on the working board, I measured 54 Ohms, on the faulty one I measured 5k Ohms.
I marked the resistor on the picture attached.
#1216 Reply
Posted by
myf
on 11 Nov, 2023 18:06
Hello,
Today on aliexpress, I get a rd6012p with its box and its psu for 188eur from RD official Store, thanks to the 11/11 offers.
I make two purchases : one ad for psu at 52eur, and an other for the rd6012p with box and wifi for 134eur. I therefore add twice the discount of 4eur per 20eur up to 80eur...
Have a nice day !
F.
#1217 Reply
Posted by
DeKay
on 13 Nov, 2023 15:27
Can someone briefly summarize the difference between the RuiDeng standard firmware on the "P" models vs the UniSoft firmware?
UniSoft has said that "menu design, strings, and even font was copied from my firmware..." and it sounds like RuiDeng made other improvements as well. I would like the higher performance of the "P" version but more current than the "non-P" version can provide. If UniSoft isn't going to support other models and isn't going to open source the software (that is all up to him and ok with me), then I need to decide between more features or more current. It would be nice to have a better idea of those features I'd be missing out on.
#1218 Reply
Posted by
myf
on 15 Nov, 2023 13:07
Hello,
I'm buying (this week) the RD6012P and not the RD6006P, because using a (Chinese) device at its maximum capacity is not so safe. Power Supply Units last longer if they are used in the middle of their capacity.
My aim is to use sigrok (or other linux software) to control this power supply and a relay (by usb) in real time (to charge or discharge a battery, for example).
For me, the usb control capability is more important than the power supply's internal software.
Have a nice day !
F.
#1219 Reply
Posted by
Selin
on 15 Nov, 2023 13:37
For me, the RD6012P model has the only cons - the necessity of manual switching between 6A (0.1mA precision) and 12A (1mA precision) modes (including power limit).
Also, it has non-optimal schema to balance load between the two main transistors - they are just paralleled without balancing resistors.
#1220 Reply
Posted by
nardev
on 17 Nov, 2023 21:28
I see that this is quite a big RIDEN topic, i hope you would not mind if i ask something about it.
The one that i set up, RIDEN RD6006 has Meanwell power supply 24V 1.1A.
More than i actually need.
How reliable is the power consumption logger?
How do i understand those columns?
I just want to know how much power would be consumed after X minutes? I tried logging 5 minutes here for 3 different cases.
#1221 Reply
Posted by
crispus
on 20 Nov, 2023 20:44
Hello,
It seems that the voltage last value is saved to M0 (between restarts) only if it is entered via keypad. Using the rotary knob doesn't seem to save it. Do I miss something?
RD6006, v1.41.1k.
Thank you!
#1222 Reply
Posted by
ptluis
on 22 Nov, 2023 11:08
Did anybody tried to connect the output of two similar units (rd600xx, rk6006) in series to create a simetrical power supply output? both units should use different input power source.
#1223 Reply
Posted by
Pukker
on 27 Nov, 2023 10:54
For safety use two diodes for protection when one of the supplys stops working or settings are not correct.
Diodes have to be able to transfer the max current.
#1224 Reply
Posted by
ptluis
on 27 Nov, 2023 17:47
The idea was to use the center point also, for eg. +12v 0v -12v not just series. My use for these is to connect opamps and test some boards that demand a simetrical PS. BTW according to Ruideng the developer of these modules, it is forbidden to connect them in series and also in parallel they will burn. I think I will continue to use my homemade analog PS for this. Dc-Dc converters have issues when connected in series or parallel even with prottection diodes, I've blown some cheap dc-dc buck converters trying this, they look ok but at some point they fail. I wasn't able to do it successfully and I tried several different solutions I've found on schematics foruns and so on.
