Author Topic: RuiDeng Riden RD6006 DC power supply  (Read 399885 times)
bozo and 5 Guests are viewing this topic.
Offline bateau020
Re: RuiDeng Riden RD6006 DC power supply
« Reply #1250 on: May 02, 2024, 06:00:26 pm »
Is there anyway to use the Riden RD6006 flashed with the great Unisoft firmware with Sigrok? I would like to do power logging
https://sigrok.org/wiki/RDTech_RD_series
The following users thanked this post: myf
Offline NutuElectronist
« Reply #1251 on: May 15, 2024, 06:46:25 am »
Hi .
I have big problem with my RD6018 .
My RD6018 dead completly STM32 have go in short circuit and now i buy new STM32 circuit and short circuit is gone.
But now i need firmware to install on STM32 please let me know how i can do that and from where i can take firmware.
Thank you and please help me.
Online darkspr1te
  • Country: zm
« Reply #1252 on: May 15, 2024, 09:54:03 am »
if the boodloader code is the same for 6018 and 6012 then flash this file and it should work.
« Reply #1253 on: May 15, 2024, 02:02:24 pm »
Thank you for your help but i think not working.
I have change stm32 with another new one and i think no have bootloader .
I write your dump with STM32_ST_LINK_UTILITY is good ?
If i buy another device how i can back-up dump from STM32?
Thank you.
Online darkspr1te
  • Country: zm
« Reply #1254 on: May 15, 2024, 03:22:42 pm »
The file I have provided includes the bootloader+firmware, it is from the rd6012 with stm32f103 mcu.
« Reply #1255 on: May 15, 2024, 04:39:18 pm »
In this cases i have more problems .
My processor is STM32F103RCT6 .
On the board have 25q32 and 24c04 i think one is flash and one is eeprom right ?
But i can write your dump with STM32_ST_LINK_UTILITY  ? or need another software ? :phew:
Thank you for your help.
Online darkspr1te
  • Country: zm
« Reply #1256 on: May 15, 2024, 05:09:25 pm »
Yes, you can write the .bin file with st link or st prog (current st flash software) or openocd.
the 25q32 and 24c04 are used for storing settings and logging data i think.
It's been a while since i wrote code for this so am no sure.
darkspr1te
The following users thanked this post: NutuElectronist
« Reply #1257 on: May 17, 2024, 06:09:27 am »
Hello.
Problem now is 24c04 i cant read with programer i think is faulty.
If remove chip from board can see on display Bootloader V1.10 fIRMWARE VERSION : V-,-- .
If i put back chip on board pwer up but nothing on screen.
Can hepl me with binary from 24c04 ?
Thank you again for help. :)
Online darkspr1te
  • Country: zm
« Reply #1258 on: May 17, 2024, 07:52:19 am »
If you are seeing bootloader but not seeing the application version or even booting into applicaition you should do a firmware upgrade and see if it goes into the main app. if you are unable to read the 24c04 in a external programmer i would replace with a blank one, the factory firmware will write default value to this chip if blank, but if the system cannot read/write to a chip it will hang at that point while it retries.
darkspr1te
« Reply #1259 on: May 19, 2024, 09:32:18 am »
Hi there.
Yes first i change 24c04 faulty with brand new one, before i read with programmer an i erase .
Same problem with 24c04 installed on board just pwer up but nothing show on screen no backlight no nothing.
When i take out memory display come on and show what i say you.
25Q32 is not faulty because i can read with programmer .
« Reply #1260 on: May 20, 2024, 04:32:53 pm »
Hi there.
I forgot to say , screen not working good .
Attash the photo.
Thank you.
Offline UniSoft
  • Country: kz
« Reply #1261 on: May 21, 2024, 12:37:13 am »
...new STM32...
...please let me know how i can do that and from where i can take firmware.
Best solution, is to contact with RD Support and ask them for the new pre-programmed MCU.
There is a some kind of copy-paste protection in code (based on unique id),
so even if you upload a full dump from another MCU, it will not work.
Also, all bootloaders are incompatible... so BL from 6012 will not work as 6018
There is no 24c04 (eeprom)! It is MB85RC04V (FRAM) used to store settings (also calibration constants).
25q32 is used to store logo only.
Keep pressed ENTER while power on, and you will see same string.
Nothing on display is because protection.
Screen working, but the bootloader what you've upload is the old version and doesn't know anything about that type of display.
« Last Edit: May 21, 2024, 02:53:47 am by UniSoft »
« Reply #1262 on: May 21, 2024, 05:56:04 am »
Hi UniSoft and thank you for your help.
In this cases is rubish i can do nothing .
I dont know if guy from Riden help me .
Thank you.
Offline bnae38
« Reply #1263 on: May 26, 2024, 03:12:40 am »
Hi bnae38,
I never got a direct response from you regarding this. Is it not possible?
So the rd6018 can see a difference in this small step in current with the custom code.
However, it wont register anything below 10mA current draw.
Perhaps I just didn't notice your question.
ADC in MCU is 12 bits (212 = 4096 steps).
Therefore: 20A / 4095 = ~0.005A (Physical resolution)
Thanks to oversampling, the resolution is slightly increased (but with a loss of accuracy).
Why minimum 10mA?
I made a software restriction (just in case), as the original firmware process the same (only 2 digits after the decimal point),
and it was calibrated without taking into account the 3rd digit after the decimal point.
I was worried that some devices could show not zero value without any load.
Hi Unisoft,
Would it be possible to add sub-10mA visibility as an option in firmware? Perhaps with a disclaimer on accuracy?
That would be awesome 😎
« Last Edit: May 26, 2024, 03:14:31 am by bnae38 »
Offline The Doktor
« Reply #1264 on: Yesterday at 09:27:15 pm »
Is there any chance of a replacement firmware for the RK6006?
