As far as I know, your meter will support Firmware version 1.16 and not the newer 1.41. The newer firmware is for their newer board revision they did somewhere in mid/late 2018 and later ones.
what is the difference between 1.41 vs 1.16 ??
what is the difference between 1.41 vs 1.16 ??did they answer you?
Quote from: mqsaharan on July 13, 2020, 01:27:06 pmAs far as I know, your meter will support Firmware version 1.16 and not the newer 1.41. The newer firmware is for their newer board revision they did somewhere in mid/late 2018 and later ones.Qasim, thank you, this info is useful for me, please, do you have the link to the source?
