Author Topic: Schaffner CPW9670 Powemeter manual needed  (Read 750 times)
Offline dxlTopic starter
« on: August 06, 2023, 03:52:36 pm »
i couldn't resist and bought this powermeter on ebay: https://www.ebay.de/itm/334958415802
However, there's almost no documentation on the internet available. Does anyone know how to read measurement values from the serial port? Or even better, have a manual?
It doesn't have much inside - 4 sensors, two MUX's, one SPI ADC and the microcontroller. The microcontroller seems to have the ISP fuse blown, at least i wasn't able to read the firmware the via SPI. Don't have a 44 pin adapter to try parallel programming.
The 4 converters are providing a DC voltage equivalent to the measured power, 0V for -30dBm, +2.5 for about 15dBm. All 4 inputs are generating the same voltages, so all channels seem to be ok. It would likely be not to hard to write a custom firmware for this unit, but maybe someone knows how to use them.
Thanks!
Online Martin72
  • Testfield Technician
Re: Schaffner CPW9670 Powemeter manual needed
« Reply #1 on: August 06, 2023, 07:12:33 pm »
It seems that the powermeter works or worked with the radimation software:
https://wiki.radimation.com/wiki/index.php/Chapter_15
https://wiki.radimation.com/wiki/index.php/Schaffner_CPW9670_Channel_1
Have you tried to contact schaffner directly ?
« Reply #2 on: August 06, 2023, 07:46:36 pm »
Yes, i contacted them last week, but they said they sold the EMC division about 20 years ago to Teseq. So i contacted them today, lets see whether there will be a response.
« Reply #3 on: August 06, 2023, 07:51:13 pm »
The thing responds to *IDN? via the serial port and says:
RF Power Meter: Iss 0.0p
