Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Schaffner NSG 1025 repair [Updated]
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Schaffner NSG 1025 repair [Updated] (Read 315 times)
implor
Regular Contributor
on:
December 23, 2025, 01:43:00 pm »
I got a Schaffner NSG 1025 off eBay. It’s sold as not working and before turning it on I opened it up and found a snake.
I'm looking for a manual or service documentation if you have it.
Symptom:
output voltage on display vary up an down. After a while it will settle.
Last Edit: January 05, 2026, 09:52:31 am by implor
Logged
implor
Regular Contributor
Re: Schaffner NSG 1025 repair [Updated]
Reply #1 on:
January 05, 2026, 09:56:32 am »
Reverse engineering attempt:
Pulses are generated mainly by classic 555 timers. After probing around it looks like very noisy rails. Would explain symptom also. Next step is power supply board.
Blue wires might look home made but solder joints are text book IPC style so i'm 99% sure this is from factory. Also they go isolated "extra" footprints and images of a NSG 1025 on youtube have same components there (resistor and diod).
Last Edit: January 05, 2026, 09:58:29 am by implor
Logged
implor
Regular Contributor
Reply #2 on:
January 05, 2026, 10:07:32 am »
As suspected. Leaky caps.
New ones are on order from digikey. Will replace every one so I never need to care again. This unit has datecode 1991 so they have lasted for 35 years.
Caps on supplyboard:
2x 1000uF 10V d10xL20
2x 220uF 35V d8xL20
1x 470uF 10V d8xL15
2x 47uF 25V d6.3xL12
1x 4.7uF 50V d5xL12
1x 68uF 400V d25xL25 (lead space 10mm)
Last Edit: January 05, 2026, 10:10:04 am by implor
Logged
hulchm9ib
Newbie
Country:
Reply #3 on:
January 23, 2026, 08:33:50 pm »
Hi there,
Nice piece of kit I have one of those which also needs fixing so I'm closely following your work up
Kind Regards
Ian.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
