Author Topic: Tektronix TSG4106A RF Signal / Vector Generator Review, Teardown & Experiments  (Read 3856 times)
Offline Hugoneus
    • The Signal Path Video Blog
You can watch the video here: [53 Minutes]
youtu.be/Fp-ZVez08m0
More videos at The Signal Path:
www.TheSignalPath.com
Offline HAL-42b
Cool gear I can never afford.
Offline TheSteve
  • Living the Dream
Looks more like it's the Stanford Research TSG-4106A
VE7FM
Offline Hugoneus
I think that it is, the front-panel looks like it is designed by Tek.
Offline nowlan
Was about to ask if SRS were related to tek/danaher. Doesnt appear to be any releation.
Certainly looks similar from back of this unit. Vector Signal Generators, SG390 Series — Up to 6 GHz vector signal generators
Offline Lukas
    • carrotIndustries.net
I've taken a look at the firmware upgrade for the TSG4000 series and couldn't find any reference to SRS.
As to be expected from Tek, this thing runs linux. Seems like the code name is 'arcteryx'
Offline Hugoneus
Interesting. I hope that they start implementing more features into it.
Offline TheSteve
  • Living the Dream
Perhaps only the hardware was contracted out and Tek is still doing the software in house.
VE7FM
Offline Hugoneus
Well the software all runs inside the LCD screen module and that is the component which is different from the SRS model, so it makes sense. :)
Offline Hugoneus
I hope that you still found the review helpful. :)
Offline HAL-42b
Yes it was. I watched it twice and I'll watch it again when I have time, just like the rest of your videos. Thank you.
