So for an example of setting up a MCU with a 12Mhz Crystal, if I was to buy 2 different crystals, how would 'YOU' go about selecting the correct caps for this.
I acknowledge some of you have said to read the DS and use the values they state. From what I have seen in the last 5 datasheets I have read, they don't give you a cap value, they give you some specs of the crystal only.
As I have mentioned 2 or 3 times already, there are some formulas I have come across in order to select the cap value based on the crystal CL value, and whatever stray capacitance your circuit etc might have.
I dont believe anyone has commented on this. Does anyone have any input on this?
Here is one post on Adafruit blog, take what you will from it, but here is the source I found:
https://blog.adafruit.com/2012/01/24/choosing-the-right-crystal-and-caps-for-your-design/So if we take 1 crystal for example. Abracon ABM8-12.000MHZ-20-D1-T3
This has a CL of 20pF
https://abracon.com/Resonators/abm8.pdfWhat capacitors would you aim for on this?
Based on the formulas I have found, it would be somewhere between 35pF and 38pF.
Does this seem correct?
Another one, a chinese branded Yangxing Tech X322512MMB4SI
Found a DS here:
https://datasheet.lcsc.com/szlcsc/Yangxing-Tech-X322512MMB4SI_C50430.pdfThis particular one has a CL of 10pF
What capacitors would you aim for on this one?
15-18pF?
Do these seem reasonable?
If they are not reasonable, can you please make a suggestion as to what you think is reasonable, as a place to start.
Trying to learn here.
Thanks
