Apologies for probably yet another one of 100 similar topics, although I have a somewhat specific use case in mind.
I'm looking to do some side channel analysis where two specific scope properties are highly beneficial:
- high frequency since we must typically oversample an unknown asynchronous clock
- excellent facilities to get the traces onto desktop PC for post-processing; up to 1M traces is not uncommon
Two candidate series are under my consideration and I'm looking for some advice on which way to go.
1) is a USB3 picoscope which excells in the PC interfacing but budget limitation would not stretch beyond the 200MHz 5444D or 300MHz, perhaps the 500MHz 6424E if I really _really_ stretch it
2) a higher-end Chinese like the 800MHz Rigol DHO4804, allowing for an affordable 800MHz
I do not believe 12-bit resolution is a necessity since it comes at cost of sampling frequency, but this is mostly unfounded.
Features like picoscope's rapid block acquisition seem very very useful for SCA. On the other hand, with 'only' 200/300MHz within budget, we hit limitation in the range of devices where we can apply 10x oversampling.
Can anyone recommend one over the other for my intended purpose?
