Products => Test Equipment => Topic started by: Coliban on August 13, 2020, 08:03:32 am
Title: SCPI access to LeCroy Wavesurfer 3054?
Post by: Coliban on August 13, 2020, 08:03:32 am
i am trying to connect (telnet, sockets) to LeCroy WS3054.
But that is not working :-(
I can connect with telnet without a port an login to the system. But then there is only (presumably) the Embedded Windows environment which is useless for accessing the functions of the WS304.
Is it possible to establish such a socket connection?
Title: Re: SCPI access to LeCroy Wavesurfer 3054?
Post by: tv84 on August 13, 2020, 08:10:18 am
Try to see what ports are open:
nmap -p- <IP>
Post by: tautech on August 13, 2020, 08:15:43 am
Try port 5024 as it's common to many Siglent models.
Post by: Sighound36 on August 13, 2020, 08:31:34 am
However the software and encryption are on another level  ;D
Post by: Coliban on August 13, 2020, 08:44:54 am
There is no way to establish a socket connection :-(
Following ports are available:
PORT      STATE SERVICE
23/tcp    open  telnet
111/tcp   open  rpcbind
824/tcp   open  unknown
825/tcp   open  unknown
1861/tcp  open  lecroy-vicp
49999/tcp open  unknown
Post by: tautech on August 13, 2020, 08:45:48 am
It's one of these right ?
https://www.siglent.com/products-overview/sds3000x/ (https://www.siglent.com/products-overview/sds3000x/)
Post by: PeDre on August 13, 2020, 09:10:28 am
Port 111 should be for the RPC/VXI protocol (LXI). You can try my program, I would like to know if it works with it.
But it is only for Windows and can only send and receive SCPI commands at the moment:
https://peter.dreisiebner.at -> "Messinstrumente"
Post by: 2N3055 on August 13, 2020, 11:11:11 am
https://www.mouser.de/pdfDocs/maui-remote-control-and-automation-manual.pdf (https://www.mouser.de/pdfDocs/maui-remote-control-and-automation-manual.pdf)
This is Lecroy documentation on the topic.
Post by: PeDre on August 13, 2020, 11:18:31 am
If it is as described in the linked document that the LXI connection requires a password, then my program does not work. I have not provided a way to enter a password.
Post by: Coliban on August 13, 2020, 02:34:58 pm
@PeDre: that is very kind, thank you, but i am working on Linux.
@2N3055: thank you. But it seems that LeCroy is depending on Windows/Basic and so on.
I didnt manage to get SCPI fully to work on LeCroy (nor LXI). While i can attach the Device and, for example, set an SCPI command, for example *IDN?, it seems that the Lecroy is not fully supporting SCPI because the other commands are not working and the (very) old Error Messages ( at least 5 years old) is given by th LeCroy: WARNING : CURRENT REMOTE CONTROL INTERFACE IS TCPI
This message is given regardless if connected with visa or vxi.
My opinion is that I have no problems connecting all sorts of devices, Rhode & Schwarz, Keysight, Socket, GBIP, etc.,  etc. because they are supporting simple TCPIP socket connections
Post by: Coliban on August 14, 2020, 08:30:27 am
I am not able to get SCPI on the LeCroy to run.
SCPI and socket communication is working on my Rohde & Schwarz (RTC1002) out of the box.
So i will order the R&S RTE 1024.
