Author Topic: SCPI access to LeCroy Wavesurfer 3054?  (Read 434 times)
Offline Coliban
« on: August 13, 2020, 08:03:32 am »
Hello,
i am trying to connect (telnet, sockets) to LeCroy WS3054.
But that is not working :-(
I can connect with telnet without a port an login to the system. But then there is only (presumably) the Embedded Windows environment which is useless for accessing the functions of the WS304.
Is it possible to establish such a socket connection?
"If Lyfe were a Thing that Monie could buy -- the Poor could not live & the Rich would not die." Quote on a gravestone from a glove maker, Scotland, 17th century
Offline tv84
  • Country: pt
Re: SCPI access to LeCroy Wavesurfer 3054?
« Reply #1 on: August 13, 2020, 08:10:18 am »
Try to see what ports are open:
nmap -p- <IP>
Offline tautech
« Reply #2 on: August 13, 2020, 08:15:43 am »
Try port 5024 as it's common to many Siglent models.
Avid Rabid Hobbyist
Come visit us at EMEX 15th - 17th February. Hall 1 Stand 1002
https://www.emex.co.nz/
Offline Sighound36
« Reply #3 on: August 13, 2020, 08:31:34 am »
However the software and encryption are on another level  ;D
Offline Coliban
« Reply #4 on: August 13, 2020, 08:44:54 am »
There is no way to establish a socket connection :-(
Following ports are available:
PORT      STATE SERVICE
23/tcp    open  telnet
111/tcp   open  rpcbind
824/tcp   open  unknown
825/tcp   open  unknown
1861/tcp  open  lecroy-vicp
49999/tcp open  unknown
Offline tautech
« Reply #5 on: August 13, 2020, 08:45:48 am »
It's one of these right ?
https://www.siglent.com/products-overview/sds3000x/
Avid Rabid Hobbyist
Offline PeDre
  • Country: at
    • Private Website
« Reply #6 on: August 13, 2020, 09:10:28 am »
Port 111 should be for the RPC/VXI protocol (LXI). You can try my program, I would like to know if it works with it.
But it is only for Windows and can only send and receive SCPI commands at the moment:
https://peter.dreisiebner.at -> "Messinstrumente"
Online 2N3055
  • Country: hr
« Reply #7 on: August 13, 2020, 11:11:11 am »
Offline PeDre
  • Country: at
    • Private Website
« Reply #8 on: August 13, 2020, 11:18:31 am »
If it is as described in the linked document that the LXI connection requires a password, then my program does not work. I have not provided a way to enter a password.
Offline Coliban
« Reply #9 on: August 13, 2020, 02:34:58 pm »
@PeDre: that is very kind, thank you, but i am working on Linux.
@2N3055: thank you. But it seems that LeCroy is depending on Windows/Basic and so on.
I didnt manage to get SCPI fully to work on LeCroy (nor LXI). While i can attach the Device and, for example, set an SCPI command, for example *IDN?, it seems that the Lecroy is not fully supporting SCPI because the other commands are not working and the (very) old Error Messages ( at least 5 years old) is given by th LeCroy: WARNING : CURRENT REMOTE CONTROL INTERFACE IS TCPI
This message is given regardless if connected with visa or vxi.
My opinion is that I have no problems connecting all sorts of devices, Rhode & Schwarz, Keysight, Socket, GBIP, etc.,  etc. because they are supporting simple TCPIP socket connections
Offline Coliban
« Reply #10 on: August 14, 2020, 08:30:27 am »
I am not able to get SCPI on the LeCroy to run.
SCPI and socket communication is working on my Rohde & Schwarz (RTC1002) out of the box.
So i will order the R&S RTE 1024.
