Author Topic: SCPI "TRACe:DATA?" command on SVA1015x  (Read 410 times)
Offline Meestor_XTopic starter
« on: October 26, 2022, 11:04:48 pm »
Is there a beginners guide to using this command?
With the SVA in SA mode, It seems to spit out 35 1/2 values, how do I know what frequency each one refers to? How do I get more than 35 values?
Thank you for any and all help!
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
Re: SCPI "TRACe:DATA?" command on SVA1015x
« Reply #1 on: October 27, 2022, 03:02:09 am »
This is probably a limitation of the UI rather than the unit directly - I've never used this SA but it certainly looks like the UI is just truncating the buffer - Install whatever the appropriate communication software is (NI VISA, Keysight IO Libraries, PyVISA etc) and then write a small program to send the command and read back the data - You'll probably end up with several hundred values that will be distributed from the start and stop frequencies of the sweep - For example, my HP 8563E returns 601 values so I would simply calculate the frequency based on start, stop, divided by 601.
Not sure if this helps very much but maybe it'll help you find the right answer.
TonyG
The following users thanked this post: Meestor_X
« Reply #2 on: October 27, 2022, 03:03:18 am »
Thank you. I'll give that a try!
