Hello all,
Trials and tribulations with my 16702A continue. Recently I did a successful 2M capture of a device and wanted to transfer the resulting ~200mb file to my iMac for further analysis. I still have machines capable of plain old FTP so I set a transfer away thinking it would take 10-15 minutes. 45 minutes later I killed it because something can't be right. Next I tried NFS and that fails instantly with an ESTALE error, stale file handle. This is weird because I can happily mount a filesystem, cd to it and create a file, then delete the file. But copying eg a small core dump just fails, or will sit and LOOK like it's doing something but in fact isn't. Usually for that sort of issue I'd look for hp/ux patches and have got a patch CD for 10.20, but in all my reading here I've never seen anyone talk about doing this.
Next I tried CIFS to an XP box that would accept the connection. I could copy small files no problem, but again the ~200mb file took over 45 mins before I killed it - it was writing but would've taken hours at the speed it was going.
I wondered if it was autonegotiation with the old HP switch it's plugged into, and I thought it was strange that it autonegotiates to 10mb half duplex. Surely even in 1999 full duplex 10baseT was the norm. I mean, I was there and I'm sure 10 or 100FDx was a thing I was using. I can't see any way of changing between HDx and FDx in the config though. Somebody suggested putting a terminated t-piece on the 10base2 plug in case it was causing noise, which I've done. Next thing I guess is to pull out a 10/100 switch and hook it up to that instead. BTW I did set the HP's switch port to 10FDx and could log into the analyser, but when I tried to start vp over X nothing happened.
Am I just expecting too much?
Cheers
Adrian
