Author Topic: New Keithley DMM6500 and now DAQ6510  (Read 356413 times)
Online mawyatt
Re: New Keithley DMM6500 and now DAQ6510
« Reply #1525 on: December 04, 2024, 02:57:59 am »
We've had our DMM6500 lock-up a few times over the past couple years, and recall it was something graphing related, but not enough times to be of concern or make note of.
Since you've indicated this only happens with the graphing function and everything else is fine, leads one to consider a hardware issue that becomes relevant only when the graphing is enabled which might point to some unique graphics memory or logic use. Having the issue over different firmware revisions also points to some graphics related hardware problem.
As you've discovered these Keithley DMMs (also the KS34465As) are in another class of DMM instruments and why we have both types!!
Anyway, hope you can get this graphing issue worked out, this is where the Keithley stands out :-+
Best
~Wyatt Labs by Mike~
Offline KungFuJosh
  • TEAS is real.
« Reply #1526 on: December 04, 2024, 05:57:04 am »
Thanks Mike, I hope so too! I just watched this video: https://youtu.be/Lezd27BzQLo?feature=shared&t=1926 - and yeah, the graphing looks pretty awesome.
Thanks,
Josh
Offline thm_w
  • Non-expert
« Reply #1527 on: December 04, 2024, 10:41:01 pm »
The front is easy to take off, it looks like there are two sets of DDR2 ram: https://xdevs.com/doc/Keithley/DMM6500/lukier/fpback.jpg
Maybe one is for graphics processing, the other for buffering data?
Offline KungFuJosh
  • TEAS is real.
« Reply #1528 on: December 05, 2024, 09:33:17 pm »
A rep from Tek has gotten back to me. She said "there has been intermittent issues with other customers" and they're trying to reproduce the issue there. Hopefully they figure it out quickly so I can use the feature once and then ignore it for a while. 😉
The following users thanked this post: thm_w, 2N3055
Offline 2N3055
  • Country: hr
« Reply #1529 on: December 05, 2024, 09:54:24 pm »
That is at least some good news.
Let's hope it produces some usable results..i.e. a fix.
Dr. Richard W. Hamming
Offline Hydron
« Reply #1530 on: December 05, 2024, 11:00:32 pm »
Yeah the graph isn't one of those try then ignore features. Sure it can be pretty annoying trying to get the right scale using the touchscreen or the very limited controls, but it's also incredibly handy when you just need a quick trend display or something and don't want to dump and analyse the data on another system, especially given that you can leave it on in the lower area while keeping the big main current-value display above.
Offline KungFuJosh
  • TEAS is real.
« Reply #1531 on: December 08, 2024, 06:09:56 pm »
According to the declassification guide, they're cleared when the device is power cycled.
Offline KungFuJosh
  • TEAS is real.
« Reply #1532 on: December 09, 2024, 09:46:25 pm »
I made a breakout panel with my "laser." Now I just need the scanner cards to arrive.
