Author Topic: Teledyne T3DSO2304 Oscilloscope Question  (Read 173 times)
Offline Robbdoe1Topic starter
« on: December 09, 2024, 05:22:35 pm »
We have a very nice 300MHz 2GSa/s scope at work. TMI came to calibrate it as they do annually. They weren’t able to as the Zoom/ S-nS switch/encoder was broken. The switch was locked up and some gorilla here broke the knob shaft off.
I need a new switch. This one is made by LJV.  It has 3 pins on the bottom, 2 pins on the top and 1 pin on each side. I have attached pictures. The board with 14 switches/encoders is made by Siglent. I reached out to them but they are unable to help. I have also reached out to Teledyne and I’m awaiting a response.
If anyone can identify this part I would appreciate it greatly. Thanks.
Offline tautech
Re: Teledyne T3DSO2304 Oscilloscope Question
« Reply #1 on: December 09, 2024, 09:24:15 pm »
Looks like a SDS2000X model.
Timebase encoder......detented and press to select IIRC.
Probably the same as used in the later SDS2000X Plus models.
You might find the info you seek in one of the threads here.....
« Reply #2 on: December 09, 2024, 10:48:00 pm »
I found what appears to be a direct replacement on DigiKey. I had to pull it apart to get the PPR number. Hopefully it works as it’s a real nice scope. Thanks for your help. I appreciate it.
