How can I tell if there is damage to the rotary attenuator pots/encoders (they have a distinct step when they are rotated)or if the there is damage to the input stages of the Y amplifiers themselves?
It's strange that on all 3 channels (1,2 and 3) the trace disappears on ALL volts per division settings over 2 volts. I could try to remove reseat any connectors on the assembly that holds the rotary encoders behind the front panel.
Rotary Encoders: just smoothly turn any decoder as with 24 steps. If you get a a missing or larger unexpected steps, then it is likely the encoder or the cause of black dust. Even the none detent models, follow a digital step inc/dec.
As LED's completely off, black dust as hell on the mentioned panel.
I simple reduced the fan ALU holder, so remove and mounting gets smoother, but the damping foam have to be replaced. Anyway if you go for any smoother fan's or using 14cm fans with required 12 to 14 cm adapter (3D print)
In addition if you use an XP with a dual CPU (3GHz Models), a special masking driver is required otherwise LED flashing will occur.
I could not go further than XP, otherwise XStream or Touch driver gets any wired.
Also 3V battery to replace as stops the main board on boot.
Happy tuning
