Author Topic: Siglent SDS1104X-E Hack to 200Mhz, and full options ?  (Read 66606 times)
Offline wally2q
Re: Siglent SDS1104X-E Hack to 200Mhz, and full options ?
« Reply #225 on: January 20, 2021, 04:39:11 am »
I figured it out.   from: |O   to: :-+
There were 2 issues:
First off - running the python code remotely in that link's website didnt work for me.  I copied the code and ran it in this on-line python execution website: https://www.programiz.com/python-programming/online-compiler/
it then returned the correct keys.
Secondly, the correct command in SCPI is: MCBD key........ not MCBD 200MHzkey
I thought the 200MHz had to be there as a prefix to the key... but that's not the case.  I see what the OP meant... ie "use the 200MHz key" in that place, but the way it's written, i mistook it as needing that "200MHz" prefix.
cheers!
« Last Edit: January 20, 2021, 04:40:42 am by wally2q »
Offline Roger Hartmann
« Reply #226 on: January 22, 2021, 10:04:25 am »
hello all,
I used the above python script and successfully generated the codes for the Teledyne LeCroy T3DSO1104 (which is the same HW as the Siglent).
The AWG, WIFI and MSO upgrades I can check in the GUI itself. But for the 200MHz upgrade - beside of the "success" return from the SCPI MCBD command, how can I tell if it worked? Beside doing measurements, of course.
thanks a lot, Roger
Offline tv84
  • Country: pt
« Reply #227 on: January 22, 2021, 11:15:30 am »
The only "beside" is entering the equipment and see the BW license file to check its contents.
The following users thanked this post: Roger Hartmann
Offline wally2q
« Reply #228 on: January 22, 2021, 03:10:28 pm »
On the Siglent, you can check the model-number in the "information" page - you will notice the 1204 model - depicting the 200mhz version vs the 100mhz which is model 1104.
This will validate that the unit "thinks" it's a 200mhz unit.
Secondly, if you turn the "horizontal" knob, you will be able to get 1 or 2 more settings, down to 1ns per division, whereas the 100mhz unit only goes to 5ns I believe.
Lastly, as far as actual performance, there may be different low-pass filters setpoints for 100mhz versus 200mhz - someone that may have done some actual tests can confirm this.
From a sampling rate, quality of data etc - there is no difference - the same data is presented to the processor, from the A-D.  1GS/s shared per 2 channels (2 A-D's for the 4 channels).  So no more "data" is available... so it only comes down to how the data is used / processed etc.
Best way to think about it is this way:  this is a native 200mhz device, that was "throttled down" to 100mhz to fit a market-space... rather than a 100mhz device that is "stretched" to 200mhz
Offline peter2
« Reply #229 on: January 24, 2021, 11:37:22 am »
i have the sds 1104x-e in pro mode,the screen says sds1204x-e and the horizon scale is now 1.00ns.
now i will disable the pro mode,to get the keys from the memorydump.bin file.
how dissable the pro mode?
and are all the options also free in the pro mode?
Offline Pugduck
« Reply #230 on: January 30, 2021, 05:10:04 am »
Hi, wonder if anyone experienced the same.. I ran the python web interface to generate the 200M bandwidth key for my Siglent 1104x-e scope.
The python app generated 4 possible codes which i tried but none of them worked. I know this as each time i ran a key, I queried it by MBCD? and then my existing key was returned.
Any help would be appreciated. ^-^
Offline Pugduck
« Reply #231 on: January 30, 2021, 05:27:13 am »
Sorry had a typo in previous post, ment MCBD instead of MBCD :phew:
Offline tv84
  • Country: pt
« Reply #232 on: January 30, 2021, 10:16:36 am »
When you are able to generate your current license, then you can be sure you are using the keygen correctly.
Offline thaistatos
« Reply #233 on: January 30, 2021, 11:22:42 am »
check here:
https://www.eevblog.com/forum/testgear/unlocking-siglent-sds1104x-e-step-by-step/200/
you have to enter bandwith update by MCBD command, all other updates directly on the scope. first select the option you want to update and then enter the code.
Offline jorgemef
« Reply #234 on: February 21, 2021, 01:03:40 am »
I also had multiple problems people are reporting, and after reading a lot I found the solution. I had to downgrade first. :) Latest version doesn't supports telnet enabling nor some scpi commands.
