Hi all,
I have a Kikusui PMC 18-5A power supply. I am trying to charge an individual li-ion cell with it. I've watched this video by Dave (
https://youtu.be/jNmlxBXEqW0) where he sets the current limit to 1.7A and voltage limit to 4.2V and the supply works in CC mode until the cell reaches 4.2V and switches into CV mode. My cell has the same charging parameters.
When I connect my cell to my supply I can get the supply to work fine in CC mode like described above. However, in the Kikusui manual, it recommends using a diode in series with the load to protect the power supply. They recommend for the diode to have a reverse voltage withstand capacity at least twice
the rated output voltage of the power supply, and the forward current capacity to be three to ten times the rated output current of the power supply, I am using this diode:
https://www.mouser.com/ProductDetail/821-SRAF1640HC0.However, when I put the diode in series with the battery cell, the load will remain in CV mode and wont draw more than an amp.
How can I use a diode to protect my power supply while still operating in CC mode? Can I use the remote sensing feature of my power supply to fix this? Or can I choose a diode that has less resistance?
