Did you not read my post?
I have MSOX3104T.
It does exactly the same thing as Siglent..
Have you checked behavior of normal and tracked cursors on KS and Siglent? They are not the same, KS is more flexible.
KS regular cursors show proper A-B diff both in non-zoom and zoom modes. In Siglent you have to use zoom mode to get proper A-B result (or zoom out).
KS tracked cursors show proper dY/dX in zoom mode for full main display (i.e. cursors can go out of "zoom" display). In Siglent you have to use narrow zoom window (cannot go outside zoom window) to get proper dY/dX result. When tracked cursor are capped to display edge, all bets are off for dY/dX and dY values.
You can get the similar results in the end if you try hard enough, but there is a difference in implementation. IMO Siglent tries to emulate cursor behavior of KS, but are unable due to other design decisions (memory/zoom thing).
For standard X cursors, they are where you put them...
Siglent cursors do not sit still with changing zoom level... And you never know if cursor is just capped to the edge of display, or you touched it and know it is fixed at edge for real. And it depends on zoom mode as well.
They don't measure anything, they are just there.
Kind of, time measurement cursors are "synthetic" - equivalent to digital cursor overlay on analog scope screen.
If they are outside the visible screen they have no useful application then.
I strongly disagree, as there is immediate useful application - time difference measurement A-B without requiring to zoom-in/out multiple times. Cursor is just sitting where it was last set, nothing mysterious happens when display window moves away. Compare how many steps it takes to measure time differences A-B & A-C in capture buffer [...A...long duration...B...short duration...C...] with KS and Siglent (with and without zoom).
Of course on Siglent cursors stay in place and also measure everything if you use zoom.
You can change zoom level any way you want, and they will stay where you put them.
Did you misunderstood something?
Manual cursors are very limited tools. You set them by yourself. Do you know where they are? Where you put them.
On Keysight there is no saved time for a A-B and then A-C measurement, unless B and C are on the same screen to begin with.
You have to:
1. Set slow timebase to capture long event.
2. Locate and position X1 to roughly where A is
3. Set timebase to see detail of A.
4. Set A cursor precisely.
5. Set slow timebase to find where in buffer is B.
6. Move to that place in buffer
7. Set timebase to see detail for B.
8. Set cursor X2 for B
9. Measure A-B
10. Set slow timebase to find where in buffer is C.
11. Move to that place in buffer
12. Set timebase to see detail for C.
13. Set cursor X2 for C
14. Measure A-C
On Siglent if both are on the screen you have measurements. If not, just use timebase to put them both on the screen, after no 8 and and after no 14. And that is it.
So on 14 steps you have 2 more,yes. But that is hardly much more work.
Or use Zoom and have it all at the same time on the screen.
In which case you have direct control of both cursors at all times and overview over full event.
Which is what I use on Keysight too.
So there is no difference for me.
