Author Topic: SDS800X HD Bug Reports + Firmware  (Read 4344 times)
Online ebastler
Re: SDS800X HD Bug Reports + Firmware
« Reply #50 on: April 26, 2024, 08:50:03 am »
From eTobey's side, it might feel like he is doing work for Siglent?
Actually, some kind of "bug bounty" program would be a nice touch. Users who find and characterize bugs are providing a service to Siglent and to the user community, after all.
Dear Siglent -- I would settle for an SLA1016 logic probe, ideally with an extra set of the better grabbers!  ;D
Online eTobey
« Reply #51 on: April 26, 2024, 09:06:46 am »
Actually a function generator would be my preferred item at the moment. Also i wouldnt find so much bugs then, which is something me and others would prefer anyway.  ;D
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
Online eTobey
« Reply #52 on: April 29, 2024, 07:13:43 pm »
Issue:
Field of no response.
There is a region, where no clicks or dragging is working. Anyone else having this problem?
You can see the extends, if you look how the mouse pointer changes its appearance.
Offline BillyO
« Reply #53 on: April 30, 2024, 12:29:00 am »
Two things I have noticed so far..
1) Math does not appear on the ribbon menu at the top of the screen like on the SDS2000XP.  This means it's not available through the web interface.
2) You cannot enter the IP address is 206.108.0.132, nor the IP address 216.239.35.4  I can enter the 2 and the 0 of the first octet, but then it just stops.  I can enter 199 in the fist octet, but not 206 or 216.   200, 201, 202, 203 are all okay, but not 204, 205, 206, 207, 208 or 209 (214, 215 ..)
Very strange.
Has anyone else noticed these?
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
« Reply #54 on: April 30, 2024, 12:36:50 am »
It is.
Math is done on an active channel by activating a Math channel.
Press the + and select Math for the new channel, then select its source.
Avid Rabid Hobbyist.   Come visit us at EMEX Stand #1001 https://www.emex.co.nz/
The following users thanked this post: BillyO, KungFuJosh
Offline BillyO
« Reply #55 on: April 30, 2024, 12:41:12 am »
It is.
Ahh, RTFM then, eh?
It just looks and works so much like the SDS2KXP I made a silly assumption.
Thanks Rob.
Offline KungFuJosh
  • TEAS is real.
« Reply #56 on: April 30, 2024, 12:45:02 am »
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
« Reply #57 on: April 30, 2024, 12:54:59 am »
It is.
Ahh, RTFM then, eh?
:-DD
Actually I booted one to check and as you say there is no room for a Math dropdown due to the small display....actually it's one of the 1st things spotted when I got this one in early Feb as the white model SDS1000X HD I already had and its 10" display does have a top ribbon Math dropdown menu.
So rather than press the front panel Math button I already knew how to add a Math channel with a mouse but for this check so just used the touch display and the webserver will be the same.
Offline 2N3055
  • Country: hr
« Reply #58 on: April 30, 2024, 07:32:21 am »
One thing that I like is copy to Ch..
You need to look into SPI?
Enable all 4 ch, Set 1st one, copy 3 times and off you go...
Those CH tabs are full of wonders....
The following users thanked this post: Performa01
Online eTobey
« Reply #59 on: May 01, 2024, 07:29:11 pm »
New issue: Measurement wont work on parts of the captured waveform:
The measurement does not measure, when the gate is at different positions. Watch the measurement tables when the gate is moving.
« Last Edit: May 02, 2024, 12:20:42 pm by eTobey »
Offline Martin72
  • Testfield Technician
« Reply #60 on: May 01, 2024, 09:18:10 pm »
What are you doing there?
Online shapirus
  • Country: ua
« Reply #61 on: May 01, 2024, 09:32:33 pm »
I really, really hate to post a reply here, because it will make the thread start popping up in the "new replies to your posts" section, and I have no immediate interest in Siglent scope bugs, but I finally have to, it's just unbearable.
@eTobey, pretty please, read this: https://marker.io/blog/how-to-write-bug-report
and this: https://www.chiark.greenend.org.uk/~sgtatham/bugs.html
and this in general: https://www.google.com/search?q=how+to+write+a+good+bug+report
I mean no offense, truly. It's for everyone's good.
The following users thanked this post: newbrain, 2N3055, Martin72
Online eTobey
« Reply #62 on: May 02, 2024, 07:12:54 am »
I thought it is quite obvious what is happening. I have edited that post.
Offline 2N3055
  • Country: hr
« Reply #63 on: May 02, 2024, 08:19:28 am »
We get you are showing something about measurements.
Still no explanation what exactly do you think is wrong and why do you think is wrong.
Online eTobey
« Reply #64 on: May 02, 2024, 12:24:46 pm »
I edited that post (with the video), and put the explaination in there.
Offline 2N3055
  • Country: hr
« Reply #65 on: May 02, 2024, 01:29:08 pm »
I cannot reproduce any problem.
I made a signal on AWG:
Pulse, repetition frequency: 45.45Khz (22µs period), pulse width 150-300ns modulated with random noise.
Scope 1ch, slope trigger, 20µs/div, 2GS/s
Measurement gate width: 31.4 us
I guess that is close enough.
I found no problem with scope.
Fact that at certain points you stop having results for certain measurements is because of the fact that to establish measurements of period you need to select time period where there is a full period inside.
Online eTobey
« Reply #66 on: May 02, 2024, 05:53:07 pm »
Me neither  :-DD  :wtf:
Should have saved the setup. :palm:
Online eTobey
« Reply #67 on: May 02, 2024, 06:34:04 pm »
I now could partially reproduce the issue. Only the width+ measure does not work now.
Maybe it is the way how to captured the waveform:
First single shot trigger, then activation of cursors and measurement. Scrolling the waveform to the right?
See attached the setupfile.
