Author Topic: SDS800X HD Bug Reports + Firmware  (Read 69943 times)
Online 2N3055
  • Country: hr
Re: DHCP "bug."
« Reply #450 on: February 08, 2025, 10:57:26 pm »
Here's another bug (or at least sloppy/lazy programming). SDS800X HD basically ignores DHCP lease times. Below is with the lease time set to 8 hours. Instead of renewing every 4 hours (1/2 lease time) as is normal, it's doing it every minute or so. Although technically allowed by the DHCP spec, I've never seen another client do this, and it is unnecessarily abusive. Ugggh.
Feb  8 14:13:04 dnsmasq-dhcp[710342]: DHCPDISCOVER(br0) 74:5b:c5:23:68:83
Feb  8 14:13:04 dnsmasq-dhcp[710342]: DHCPOFFER(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:13:04 dnsmasq-dhcp[710342]: DHCPREQUEST(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:13:04 dnsmasq-dhcp[710342]: DHCPACK(br0) 192.168.168.71 74:5b:c5:23:68:83 scope
Feb  8 14:14:23 dnsmasq-dhcp[710342]: DHCPREQUEST(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:14:23 dnsmasq-dhcp[710342]: DHCPACK(br0) 192.168.168.71 74:5b:c5:23:68:83 scope
Feb  8 14:15:37 dnsmasq-dhcp[710342]: DHCPREQUEST(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:15:37 dnsmasq-dhcp[710342]: DHCPACK(br0) 192.168.168.71 74:5b:c5:23:68:83 scope
Feb  8 14:16:52 dnsmasq-dhcp[710342]: DHCPREQUEST(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:16:52 dnsmasq-dhcp[710342]: DHCPACK(br0) 192.168.168.71 74:5b:c5:23:68:83 scope
Feb  8 14:18:06 dnsmasq-dhcp[710342]: DHCPREQUEST(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:18:06 dnsmasq-dhcp[710342]: DHCPACK(br0) 192.168.168.71 74:5b:c5:23:68:83 scope
Feb  8 14:19:21 dnsmasq-dhcp[711671]: DHCPREQUEST(br0) 192.168.168.71 74:5b:c5:23:68:83
Feb  8 14:19:21 dnsmasq-dhcp[711671]: DHCPACK(br0) 192.168.168.71 74:5b:c5:23:68:83 scope
...continues ad infinitum.
Yep,
 you are right.
I just tried. It will refresh every 75 seconds or so....
As you said it is technically not in violation of DHCP specs, and shooting off several 342 bytes long UDP packets is hardly "abusive".
But I agree that it should be done right...
Will report.
Best,
Dr. Richard W. Hamming
Offline eTobey
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
Re: SDS800X HD Bug Reports + Firmware
« Reply #451 on: February 09, 2025, 07:18:03 am »
Today i got bloody annoyed by that scope again:
Plugging it in on LAN to get a screenshot out, since i am using it on another place. Nice, LAN does not work yet again (Yes, i am not an IT expert). Ok, lets use it with USB, since it has that. Of course since it does not have a RTC, it does not have the right time. OK, that is not a problem for a "great" scope... Sortet the filenames of the screenshots, as the screenshot i wanted to get out is the last one. And surprise surprise, this "great" scope would not present you the last screenshot, since the filename of the screenshot are poorly choosen:
I am looking for screenshot No. 529, but what i get when sorting is:
99
92
90
89
88
And yet this is not the only issue with sorting:
"c" comes after "S"
 :palm: :palm: :palm: :palm: :palm:
I hope you understand, that i will not deliver a screenshot for now.  ::)
The "G" in "SDS800X HD" stands for "great" :-DD
EDIT:
It does not bloody stop! Just when i go to copy the screenshot, the last number is hidden. More clicks needed...  :palm:
« Last Edit: February 09, 2025, 07:44:21 am by eTobey »
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD bugs/issues/workarounds (Updated 17. Feb. 2025)
Online shapirus
  • Country: ua
« Reply #452 on: February 09, 2025, 10:23:53 am »
99
92
90
89
88
Yes, another consequence of hiring inexperienced programmers. This is a beginner's mistake.
This is a result of using alphabetic rather than numeric sorting, where "99" ends up greater when compared to "899". This can be fixed by utilising a proper file naming scheme (which is usually the easier way) or modifying the sort algorithm.
It is a very, very widespread mistake in user interfaces. Programmers write code without giving a thought to how it will work in different scenarios and testing it.
"c" comes after "S"
Same thing, but this one is even easier to fix: use case-insensitive sorting.
Offline eTobey
« Reply #453 on: February 09, 2025, 01:43:20 pm »
Yeah, those are easy to fix. More difficult would be to get Siglent to fix such bugs. I have already contacted the support about other issues multiple times, but i guess i had some "bad luck", not getting the competence i wanted. The first guy used an old firmware with different values than i stated (different in orders of magnitude), and the next one was seemingly annoyed with such "unimportant" issues...
I wonder if there will be a firmware update in the near future, or if they are just working on other new "great" products...
Offline awakephd
« Reply #454 on: February 09, 2025, 10:59:13 pm »
99
92
90
89
88
"c" comes after "S"
EDIT:
I apologize if this is a red herring, and I am still enough of a newbie that I may be getting the wrong end of the stick. But just in case: I noticed in a couple of screenshots in a post on Jan 7 that you have the sorting set to descending rather than ascending - which is exactly what the screenshot showed, and would seem to be what you are indicating above. Could that be what is going on?
The following users thanked this post: mikes
Offline eTobey
« Reply #455 on: February 10, 2025, 07:12:58 am »
Why would you think, that i am refering to those screenshots?
Offline awakephd
« Reply #456 on: February 10, 2025, 01:46:25 pm »
As I said, I may be on the wrong track. In post # 428, you referred to problems with sorting, and you attached screenshots. It seemed that you were reporting a similar problem with sorting in post # 451, and you list the results in question. In both cases, the results (regardless of how they are shown - screenshot or list) look to me as though they are sorted perfectly ... just descending, rather than ascending. Again, I can only apologize if I have misunderstood what you are describing.
« Last Edit: February 10, 2025, 01:50:05 pm by awakephd »
Online 2N3055
  • Country: hr
« Reply #457 on: February 10, 2025, 02:54:52 pm »
Yes there is sorting direction and also Linux is case sensitive.
It is perfectly Ok to have files named:
mike
Mike
MiKe
In the same folder.
And in reverse order it will sort Upercase, Lovercase and numbers. Or opposite in the ascending sort.
Online shapirus
  • Country: ua
« Reply #458 on: February 10, 2025, 03:54:12 pm »
mike
Mike
MiKe
In the same folder.
Exactly.
But it doesn't solve the user experience issue, it only explains why it works the way it does.
Offline mikes
« Reply #459 on: February 10, 2025, 04:04:30 pm »
What do you think "the user experience issue" is, and how would the example be sorted to fix it?
Online shapirus
  • Country: ua
« Reply #460 on: February 10, 2025, 06:26:33 pm »
Well it's described in the post that started this discussion.
One way to fix it would be to:
a) (this one's a minor annoyance IMO) give the user an option to choose between case-sensitive and case-insensitive sorting in the file dialog;
b) (this one's much more serious IMO) use zero padded numeric values in file names that are suffixed with an auto-incrementing number (e.g. "shot000001.png .. shot999999.png" instead of "shot1.png .. shot999999.png"). Using a timestamp-based suffix is more convenient, but it's not possible where there is no RTC chip (or time isn't set via NTP).
Offline eTobey
« Reply #461 on: February 10, 2025, 06:34:12 pm »
mike
Mike
MiKe
In the same folder.
Exactly.
I do ignore the dude you quoted, but as i have read that by accident, i will reply:
"Mike" is beeing sorted well behind "z" !!  :palm:
But what do i know. I am just a noob that cant sort filenames...  :-//
For reference see pictures, and notice how "V***" is "far away" from "v***":
« Last Edit: February 10, 2025, 06:38:15 pm by eTobey »
Offline mikes
« Reply #462 on: February 10, 2025, 06:39:24 pm »
What's the difference? In the example given above, if it's case-insensitive, which comes first, "Mike" or "mike"? Whichever you pick, why is that "case-insensitive? Or should it just be random?
That's got nothing to do with sorting, per se, and your response was to a post about sort order which said nothing about how files are named.
Online 2N3055
  • Country: hr
« Reply #463 on: February 10, 2025, 07:25:28 pm »
User experience is exactly the same as on Ubuntu Linux and all other linux GUI.
While I understand your position, nobody is going to rewrite standard operating system file dialogs.
I would rather they add something relevant to actual measurements.
And on top of that this is not a bug. It is normal behaviour from Linux.
The following users thanked this post: awakephd, tmeub
Online shapirus
  • Country: ua
« Reply #464 on: February 10, 2025, 07:44:32 pm »
There is nothing wrong with file dialogs. They're fine. Having an option for case-insensitive sorting would be a nice improvement to them, but it's minor.
Having consecutively numbered files sorted out of numeric order, however, is a worse issue.
Current situation:
$ ls|sort
Despite normal expectations, older files will come last with the ascending sort order. No need to explain why this happens, it is clear. I am not talking about implementation details, I am talking about how this is seen from the user's perspective, and that is also very clear: sorting is screwed up. Yes it's technically not a bug. But it is a UX issue nonetheless.
Solution? It's trivial. No need to modify the standard system file dialog! Just change the screenshot utility or function to generate the file names like so:
$ ls|sort
I hope my point is clear now. This is as detailed as I could explain it.
« Last Edit: February 10, 2025, 07:49:02 pm by shapirus »
The following users thanked this post: tmeub
Online 2N3055
  • Country: hr
« Reply #465 on: February 10, 2025, 08:19:21 pm »
The naming with leading zeros to sort right?
I agree. That is good suggestion.
Offline mawyatt
« Reply #466 on: February 10, 2025, 08:27:54 pm »
Another "Brilliant" deduction my friend :palm:
2N3055 knows more about these instruments than you, me and most others combined ever will!!! One of the very few that actually knows what they are talking about rather than spewing a bunch of total random nonsense and misinformation.
Best rethink your position my friend, you just might learn something valuable and add some real value rather than the usual misconceptions, misunderstandings, worthless complaints and ramblings ;)
Best
~Wyatt Labs by Mike~
Online tv84
  • Country: pt
« Reply #467 on: February 10, 2025, 08:53:52 pm »
Totally agree. I deeply regret opening this thread today to see all the BS comments that have been going on for awhile.  :palm:
Offline eTobey
« Reply #468 on: February 10, 2025, 09:00:25 pm »
Well, cant remember, that he showed much of his knowledge, often a lot of "i dont understand, but i spew out some knowledge", and some "i know everything, and anybody else knows nothing".
And then, specific questions were not answered.
Had such a Professor: Had some good knowledge about things, but in the end that was of no use in the first exam, because it was knowledge about unrelevant stuff!
Offline mawyatt
« Reply #469 on: February 10, 2025, 09:09:36 pm »
We had a Grad Student, kinda smart but didn't listen, always complained, thought things had to work his way or no way, he flunked the 1st exam (complained about the questions) and dropped the course ;)
Best
The following users thanked this post: newbrain, 2N3055, awakephd
Offline eTobey
« Reply #470 on: February 10, 2025, 09:13:25 pm »
Because some people dont understand, i try to illustrate the issue with just one picture.
Notice the "B" and its place (notice the case also).
Not how i would expect it to be sorted, but i guess i should stop complaining...  ::)
Offline mikes
« Reply #471 on: February 10, 2025, 09:17:22 pm »
mike
Mike
MiKe
In the same folder.
That's not quite correct. Linux itself has no sort order. However,  the canonical GNU sort command does. I think what shapirus meant wasn't "case insensitive" but lexical order (dictionary order), which GNU sort does, but the scope does not, so "because, Linux" is not an excuse. For example, this list in the default GNU sort lexical order:
aaa
AAA
bbb
BBB
ccc
CCC
Would be sorted by the scope as:
AAA
BBB
CCC
aaa
bbb
ccc
...which is actually ASCII encoding order. (or perhaps UTF-8 encoding order, which would be even worse if the scope allows non-ASCII characters)
Regarding file names, the following list of files, as they would be sorted by the scope:
... could be sorted in a more human friendly manner with GNU "sort -V" without having to use some arbitrary number of digits when creating them:
« Last Edit: February 10, 2025, 09:26:12 pm by mikes »
The following users thanked this post: shapirus
Offline eTobey
« Reply #472 on: February 10, 2025, 09:25:23 pm »
Leading zeros would add the benefit of that they can be used in scripts. I believe the same lame scheme is used with filenames of other data types...
« Reply #473 on: February 10, 2025, 09:34:04 pm »
 :blah:  :blah:  :blah:
Can no one work with what they already have without the need to muck with it and impact on a whole product line ?  :horse:
Don't like internal/local memory filename structure ?
Connect a USB keyboard and properly name your filenames......or is that too hard ?  :horse:
Offline Furna
  • I still don't know
« Reply #474 on: February 10, 2025, 09:34:43 pm »
If anything has to be suggested to Siglent, I would go for the "leading zeros" approach.
This approach eliminates a few unpredictable variables ...
- common linux file systems are case senitive
- ordering of the files is done by the shell in use
- saving the file on a NAS/SMB share add one more varaible; Samba can be instructed to honour case sensitive or not
- than it comes to Windows File Explorer
Just use the "leading zeros" and the "issue" is solved.
Now, for the first letter in the filename, capital or non capital?  :popcorn:
The sky above the port was the color of television, tuned to a dead channel.
