Author Topic: SDS800X HD Bug Reports + Firmware  (Read 69343 times)
Offline eTobey
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
Re: SDS800X HD Bug Reports + Firmware
« Reply #500 on: February 25, 2025, 08:36:04 am »
I don't know if this is a bug, or just an oversight.
The scope supports SMB server, but only SMB client is documented in the user manual. For the client, both username and password can be set. But for the server, there seems to be no way to change the username from the default "ShareUser". I'd certainly prefer if it could be changed to a username of my own choice.
If something "is just not there" then i would say, a bug "is just not there". Why would you prefer a custom choice here?
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD bugs/issues/workarounds (Updated 17. Feb. 2025)
Offline Furna
  • I still don't know
« Reply #501 on: February 25, 2025, 05:47:39 pm »
If you don't know if it is bug you are supposed to discusst it over the topic for genereal discussion
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/
The sky above the port was the color of television, tuned to a dead channel.
Offline mikes
« Reply #502 on: February 25, 2025, 07:36:35 pm »
:P If you're not a moderator, you're not supposed to be moderating.
Offline Furna
« Reply #503 on: February 25, 2025, 09:54:08 pm »
Read the first post of this topic; behave mikes.
Offline mikes
« Reply #504 on: February 26, 2025, 07:12:27 am »
You're not a mod. I will gleefully ignore your hypocritical suggestion.
« Last Edit: February 26, 2025, 07:45:16 am by mikes »
Offline eTobey
« Reply #505 on: February 26, 2025, 07:48:55 am »
Seems like you are ignoring my question too?
Offline Conrad Hoffman
    • The Messy Basement
« Reply #506 on: March 13, 2025, 03:31:01 pm »
New firmware for the SDS800 is out. Would somebody please install it! When I hear that it works OK, I'll do mine. Not an early adopter anymore!
Offline SHF
« Reply #507 on: March 13, 2025, 04:52:36 pm »
new firmware is running, could not find anything negative in the short term
Precision is no coincidence
The following users thanked this post: Conrad Hoffman
Online mawyatt
« Reply #508 on: March 13, 2025, 07:22:52 pm »
Just installed and no problems to report so far :-+
Best
~Wyatt Labs by Mike~
Offline 2N3055
  • Country: hr
« Reply #509 on: March 13, 2025, 08:30:56 pm »
Best
Hi Mike!
Check FFT..  :-+
Best,
 Siniša
Dr. Richard W. Hamming
Online mawyatt
« Reply #510 on: March 14, 2025, 01:03:53 pm »
Best
Hi Mike!
Check FFT..  :-+
Best,
 Siniša
Wow!! This little DSO just brings a smile every time we use it. Just keeps getting better and better from an already exceptional performance/value baseline ;)
Best
The following users thanked this post: Conrad Hoffman, SHF, 2N3055, Martin72, Wrenches of Death
Offline ExecutiveDysfunction
« Reply #511 on: March 14, 2025, 09:54:42 pm »
Hey, everyone. This is my first post here.
I downloaded the firmware update to an 8GB USB stick freshly formatted as FAT32. I added the .ads file to it and ejected it from my PC. Then I plugged it in to my SDS814X, went to upgrade, chose the file, and pressed the reboot button. The oscilloscope rebooted, but it is now stuck on the Siglent splash screen. It's been that way for 30 minutes. I haven't tried to touch anything, but I'm unsure what to do. This isn't the first time I've updated the firmware on it, so I'm not sure what's going on. This unit is "unlocked" to an SDS824X, if that matters.
The firmware file I downloaded is named "SDS800X-HD_1.1.6.2.ADS"
Any ideas? Thanks!
Online Martin72
« Reply #512 on: March 14, 2025, 10:22:17 pm »
Try the hardware reset routine...(pdf attached).
« Reply #513 on: March 14, 2025, 10:25:46 pm »
Hi, that worked. Thanks! Looks like the update was successful too. Strange!
Online Martin72
« Reply #514 on: March 14, 2025, 10:37:45 pm »
Nice!  :-+
Offline tautech
« Reply #515 on: March 14, 2025, 10:56:51 pm »
Any ideas? Thanks!
These aren't intended to update with a reboot.
The FW update process is user selected and takes a minute or 2 to upload the FW update file and a progress bar is displayed.
Then the DSO must reboot for the new FW to be installed and the reboot either happens after an auto timeout or the user can select to reboot immediately.
Currently travelling....
« Reply #516 on: March 15, 2025, 12:05:30 pm »
Updated and it looks fine. Now I just need time to use it and see what's different.
Offline TomKatt
  • Electro-BOOMER
« Reply #517 on: March 15, 2025, 01:03:56 pm »
Seems like a few new features and operating changes in addition to a few bug fixes…
https://siglentna.com/wp-content/uploads/dlm_uploads/2025/03/SDS800X-HD-Firmware-Revise-History-and-Update-Instructions.pdf
What does moveable channel labels mean?  Or ‘Remote Reading Acceleration’?
I successfully updated my SDS804X (now 824) and it went smoothly…. Though I don’t frequently use many of the more advanced options.
« Last Edit: March 15, 2025, 02:39:48 pm by TomKatt »
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline nanopico
« Reply #518 on: March 15, 2025, 02:49:31 pm »
Any ideas? Thanks!
The same thing happened in my case. Factory SDS824X, SW 1.1.3.8, UBoot-OS 2.8.12, FPGA 2024-04-11, HW rev. 00.
My oscilloscope was allowed to warm up for a sufficient amount of time.
Then the new firmware was loaded from the web interface and I let the instrument reboot itself when the reboot timer expired.
After reboot it stuck on the Siglent logo for an indefinite time.
No message like "please wait in progress" is displayed (considering that in the background Siglent is installing something or doing some cleanup.)
After waiting for 15 minutes, I decided to turn off the oscilloscope then a simple power on brought the instrument back to life.
I followed the advice to perform a self-calibration routine after the firmware update and the operation took about 5 minutes.
The new firmware seems to have been installed successfully, FPGA is now ver. 2024-11-26, but UBoot-OS remains at ver. 2.8.12.
Why are there two versions of UBoot (2.x.x versus 3.x.x), is this related to the hardware revision? I saw SDS800X with the same HW rev. but with different UBoot OS versions.
Offline 2N3055
  • Country: hr
« Reply #519 on: March 15, 2025, 03:15:28 pm »
Moveable channel labels mean exactly that. If you enable chanel labels, label itself can be dragged around the screen to position it where you like.
"Remote reading acceleration" is some kind of acceleration of VNC remote screen display when you have low bandwidth.  I didn't see much difference in local work in LAN, and didn't try it over some slow link.
FFT was further optimized, and few new windows added.
Offline TomKatt
  • Electro-BOOMER
« Reply #520 on: March 15, 2025, 03:52:39 pm »
Quote from: 2N3055
Thanks for the explanation - the Channel labels feature might prove useful with busy screens with multiple signals.
Edit - all this time and I just noticed that your avatar is probably a cut open 2N3055 lol
« Last Edit: March 15, 2025, 03:58:20 pm by TomKatt »
Offline 2N3055
  • Country: hr
« Reply #521 on: March 15, 2025, 05:26:11 pm »
Quote from: 2N3055
You're welcome.
Yes it is.  ^-^
Offline tautech
« Reply #522 on: March 15, 2025, 06:38:21 pm »
Any ideas? Thanks!
As does my SDS814X HD, an early build (#0316) from early 2024.
Just updated to 6.2 and previously running on the beta version 5.0.
Where have you seen a V3 Uboot ?
Offline TomKatt
  • Electro-BOOMER
« Reply #523 on: March 15, 2025, 07:18:58 pm »
I bought my SDS804X HD (upgraded to SDS824X) around March or April last year (2024)...  Can't recall the exact date but I do remember it was early after release when some stock was hard to come by.   I never paid attention if the U-Boot upgraded in the process, but it's currently showing as version 3.8.12
« Last Edit: March 15, 2025, 07:21:41 pm by TomKatt »
Offline nanopico
« Reply #524 on: March 15, 2025, 07:39:22 pm »
Any ideas? Thanks!
Regarding UBoot ver. 3, User @Furna post here:
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5586747/#msg5586747
On the other hand, I think I found the reason why the oscilloscope got stuck on the Siglent logo after installing the new firmware.
I always performed the firmware upgrade from the web interface. No problems up to version 1.1.6.2.
I couldn't call this a bug, because it doesn't prevent it from working, but...
- With the LAN interface connected, DHCP and NTP configured to auto, I turned on the oscilloscope and it remains stuck on the startup logo.
- I suspected something related to NTP, so I configured NTP to manual. Still stuck on Siglent logo.
- If I call the Utility - Reboot menu, everything works normally, but if I select normal shutdown, after next power on the oscilloscope remains stuck in the startup screen.
- Without LAN connection to wired network, the oscilloscope starts normally.
Maybe it's a specific malfunction only for me, it remains to be seen if it can be reproduced by other users who have installed firmware 1.1.6.2
« Last Edit: March 15, 2025, 07:45:51 pm by nanopico »
