Author Topic: Siglent SDS800X HD Review & Demonstration Thread  (Read 248753 times)
Online 2N3055
  • Country: hr
Re: Siglent SDS800X HD Review & Demonstration Thread
« Reply #425 on: November 11, 2024, 06:34:11 am »
As an old geezer trying to make the transition from analog to digital scopes, (and struggling). Is there a way to display the volts per division permanently on the screen of my 802X?
In "Display" menu, slide the right menu up, and you will find there a "Axis labels settings".
Click on that and switch axis labels On, set them to Moving, and select left right or middle for vertical labels.
This will show calculated scales on graticules for currently selected channel.
Dr. Richard W. Hamming
The following users thanked this post: Furna, Goody
Offline hp lee
  • Country: kr
« Reply #426 on: November 13, 2024, 10:43:39 am »
Is the SDS800X able to provide 5V at 2A out of the USB ports?  I would like to use a little travel router with the oscilloscope.
I use this AP set to Bridge mode all the time:
https://www.tp-link.com/us/home-networking/wifi-router/tl-wr802n/#specifications
5V 1A
Look up the power requirement spec for yours.
That’s useful to know because the router I am looking at using is very similar, so I am pretty sure it will work. Thanks tautech.
I don’t want to use a wall adapter because this is meant to be a portable setup.
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5697471/#msg5697471
I recommend this. power consumption <1W. IMO ideal for portable setup.
Offline Goody
« Reply #427 on: November 14, 2024, 10:22:58 pm »
Thank You very much. It feels more familiar.
Offline Bill3745
« Reply #428 on: December 07, 2024, 06:57:18 pm »
Apologies if this is an obvious question that was addressed elsewhere, but what setup did you use for the bandwidth measurements? The closest I can do to approximate the FFT displays you presented was to feed a broadband noise signal into the scope and then run an FFT with averaging.  I'm not questioning the bandwidth figures (I pretty much had similar results), but am stymied on how you produced them.
Bill
A charter member of Test Gear Hoarders Anonymous and owner of a variety of Tektronix, Rigol, Siglent, HP, Wavetek and Fluke gear.
Online 2N3055
  • Country: hr
« Reply #429 on: December 07, 2024, 07:58:11 pm »
Most of the settings are visible in images posted.
Use peak hold mode for FFT and sweep frequency by signal generator.
Offline Bill3745
« Reply #430 on: December 07, 2024, 08:11:17 pm »
Thanks, peak hold on the FFT answers my question as to how the graph was so smooth without averaging. However, how do you synchronize the generator frequency sweep with the FFT sweep?  To me that implies something like a tracking generator on a SA, but not sure how you would duplicate on the SDS800X without some additional equipment.
Bill
Offline Bill3745
« Reply #431 on: December 07, 2024, 08:24:54 pm »
Scratch that.  I'm guessing (can't test it right now) that the answer lies in the peak hold...  Thanks.
Bill
Online gf
« Reply #432 on: December 07, 2024, 08:52:21 pm »
You don't synchronise. You let the generator sweep very slowly so that the scope captures a large number of records during the sweep and combines them with peak hold. Don't use a too long record length (and number of FFT points) for this use case.
Online Martin72
  • Testfield Technician
« Reply #433 on: December 07, 2024, 09:01:06 pm »
I use these settings when I want to determine the bandwidth using sweep and fft peakhold:
https://www.eevblog.com/forum/testgear/bandwidth-limit-on-siglent-sds2000x-plus-oscilloscope/msg5208711/#msg5208711
Offline Bill3745
« Reply #434 on: December 07, 2024, 09:15:17 pm »
Thanks, Martin (& gf).  I ended up with the same setup after thinking a bit more about how max-hold operates  :palm:
Bill
