We have this Tenma power supply:
http://au.element14.com/tenma/72-2630/power-supply-bench-0-30v-5v/dp/2478798#techDocsHookFor its price and functionality it's not too bad overall, but it comes with a very dangerous feature.
There are, as usual, two power switches: the big main on/off button on the left, and the DC on/off switch in the column of buttons on the right.
Naturally, one uses the DC switch to provide and remove DC power to the device under test.
However, on this particular model, when you remove power via the main switch and then power back on, the DC switch position is remembered from last time and you can get instant powering on of the DC too -- which can be catastrophic as you don't get a chance to set the voltage before you apply the DC to the leads.
In other words, if last time you had the supply set to 30 volts and power off via the main switch, then upon re-powering via the main switch some time later you get 30 volts again live to the output terminals. The supplier element14 advises that this is a "feature" of this model.
With our other Tenma power supplies, the DC on/off switch is always OFF by default upon re-powering the supply, so unwanted smoke releases from equipment under test can occur with the 72-2630 if you're not careful.
We'd love a hack that makes the DC switch default to 'off' when mains power is removed.
Anyone familiar with these supplies and can suggest such a hack?
TIA.
