I am very much an amateur electronics person, with a bit of G.A.S. I'm posting here to get opinions on my approach to buying another PSU.
I've got a 6+ years old Eventek 30V/10A PSU. I've used it for a variety of things, from powering RPis, Arduinos, other small circuits to testing strings of 12 or 24V LEDs, a stand in for 2S to 4S LiPo battery, a crude charger for a variety of battery chemistries, whatever. I don't often need beyond 3 or 5A, but have sometimes. I generally haven't been using it in places where the ripple (IIRC, somewhere around 200mV) mattered or I wasn't sophisticated enough to know it mattered.
Recently, I've been thinking about and doing more projects that I think will benefit from a better bench supply. My thinking is I would keep my existing PSU for anything that really needed >5A because I can't imagine a project I would do in the next few years that needed >5A and needed the accuracy and low noise. I'm also had a few I wanted 48VDC and just used a fixed swithing PSU (meanwell) I already have for another project, but would be nice to have this on the bench supply.
So, all this leads me to thinking about not-expensibe linear supplies that can do about 60V and 5A. This could be a one channel device, or multi channel 30V/5A that could do parallel/series across channels. I get a multichannel w/paralleling PSU, I guess I could ditch the current Eventek because that would be 30V/10A with cleaner output.
Since I'm not willing to spend a ton on this, it has me looking at the "best of the cheap" or "bottom of the quality" end of things. The usual suspects. Keep in mind I've been ok with 200mV ripple now. When I have need accurate voltage, I have verified it with a known good DMM and adjusted the supply until my DMM hit the number I wanted. So maybe the new PSU having voltage sense and feedback would be good?
- Siglent/Rigol The DP832 being the common one I see recommended here
- Korad KA3005 or KA3305 for multi output.
- Maybe super cheap RD6012P (it looks like in the 0-6A range it acts just like a 6006P) ? Should I even bother with these sort of "20mV ripple SMPS" things or just go linear?
I'm not sure I'd actually use the multiple channels all that much. But maybe that's just because I don't have them now.
Is there anything else I should be considering? I don't know if I need memory slots, I'd use them for some common configs I guess, but not required. Since I'm upgrading I would like to be able to have some better input than just coarse/fine pots. But I guess that's not required if it saves a ton of money. I haven't looked deeply at what the computer interfaces do with these things, generally I'd say I would do without that. I haven't come up with complex control needs, mostly "set to a given max current, get the voltage I want, go". Then maybe "vary current and voltage a bit manually" if I need to see how things behave.
Thanks for any advice.
