Products => Test Equipment => Topic started by: benpharr on December 01, 2015, 03:20:10 pm
Title: Seeking Bench Power Supply Recommendations
Post by: benpharr on December 01, 2015, 03:20:10 pm
I had a HY1803D variable bench power supply and it finally died on me. It would never properly regulate voltage anyway. I'm looking to take a small step up in quality and possibly features. My requirements are simple (at least 13.8V max and current limiting) and my budget is $150, though less is better. I am a simple hobbyist working with microcontrollers and low power ham radio transceivers.
One model that has caught my eye is the Tekpower TP3005T:
http://www.amazon.com/Tekpower-TP3005T-Variable-Linear-Supply/dp/B00ZBCLJSY/ (http://www.amazon.com/Tekpower-TP3005T-Variable-Linear-Supply/dp/B00ZBCLJSY/)
Does anyone have any other recommendations? Are there any features I "need" but simply don't know about?
Thanks in advance,
Ben
Title: Re: Seeking Bench Power Supply Recommendations
Post by: all_repair on December 01, 2015, 03:30:52 pm
Look out for the power supply made for the cellphone repairmen.  They come with a 3 to 4A adustable output, an analog current meter that allows you to capture surge and know (guess) the state that the DUT is, a volt meter input, a USB socket for charging need, a RF signal strength detector.   I do not have an ebay link for you.   Aliexpress is selling.  Something like this    http://m.aliexpress.com/item/32437425333.html (http://m.aliexpress.com/item/32437425333.html)
Post by: rgawron on December 01, 2015, 04:14:20 pm
I have this one and I'm happy with it.
http://www.tme.eu/en/details/nsp-3630/one-channel-power-supplies/manson/ (http://www.tme.eu/en/details/nsp-3630/one-channel-power-supplies/manson/)
Here I've wrote more about it (the whole thread my also be useful for you):
https://www.eevblog.com/forum/testgear/small-power-supplies-do-they-exist/msg807010/#msg807010 (https://www.eevblog.com/forum/testgear/small-power-supplies-do-they-exist/msg807010/#msg807010)
Post by: moya034 on December 01, 2015, 04:19:12 pm
HP power supplies are built like a brick shit house and you can get them reasonable priced on ebay. I just got a HP 6286A 0-20V 0-10A PSU recently and really like it. Biggest filter capacitor I've ever seen too!
(http://i.imgur.com/BV6tzZ2.jpg?1)
Post by: ErikTheNorwegian on December 01, 2015, 04:27:50 pm
Hi.
I just bought one of these.. very good powersupplay.  Strech your budget a little.. it kost $199.00 , BUT you get a free gift... up to a 30$   :)
http://www.circuitspecialists.com/hantek_pps2320a_power_supply.html (http://www.circuitspecialists.com/hantek_pps2320a_power_supply.html)
The free gift: http://www.circuitspecialists.com/free-gifts.html (http://www.circuitspecialists.com/free-gifts.html)
(http://www.circuitspecialists.com/content/175395/pps2320a-0.jpg)
    Number of Channels: 3
    Maximum Output Voltage: 64 volts (32 volts Channel 1 & 32 volts Channel 2)
    Fixed Channel 3:  Adjustable from 2.5 volts, 3.3 volts and 5 volts at 0 to 3 amps
    Modes: Constant Current ( c.c.) , Constant Voltage ( c.v.), Parallel, Serial, Split-Rail( negative and positive voltages)
    Regulation ( CV): <0.1% =5mV (1,3A): <0.02% + 5mV (1>3A)
    Regulation (CC):  <0.02% +3 mA
    Ripple and Noise (CV):<5mV RMS
    Ripple and Noise (CC):<3mA RMS
    AC input: 120VAC 60Hz/50Hz   +/- 10% (USA style power cod
    Rise Time ( output voltage) :<100ms  with or without load present
    Fall Time (output voltage) : < 100ms with or without load present
    Display Accuracy (Voltage & Current): +/- 0.5% plus 2 words
    Protection: OCP ( Overcurrent Portection), OVP (Over Voltage Protection)
    Cooling:  Thermostaticly controlled fan
    Size: 8.6" x 5.6" x 13.6" ( 215mm x 140mm x 340mm)
    weight: 16lbs
    Temperature for accurate Operation: 0- to 40 Deg Celsius
    Humidity max for accurate operation: <80
    1 year limited warranty
Software:
    USB Interface
    Compatible with WIN7 andoldewr versions of WINDOWS
    5 programmable presets ( voltage & current )
    Manual/Preset/Software methods of control (CSV file)
    CSV data logging
    10mV to 10 V user selectable voltage step size
Post by: rdl on December 01, 2015, 05:13:13 pm
Don't buy a switch-mode power supply.
Don't buy one of those bare "module" things off ebay.
Don't buy a power supply with a fan.
In many situations, one or more of the above may be acceptable, just not for a first and/or only bench power supply.
Post by: nanofrog on December 01, 2015, 05:34:30 pm
Given that you live in the US, you can get quality used bench supplies at very reasonable prices with due diligence (even dual and triple output are possible on your budget, and are actually a better value for the money IME).  ;)
Well worth the effort IMHO.   :-+
For example, there's currently a listing for a HP 6236B (http://www.ebay.com/itm/HP-6236B-Triple-Output-Bench-Constant-DC-Power-Supply-6V-2-5A-20V-0-5A-/131665098820?hash=item1ea7d9f844:g:SvoAAOSwv-NWXUXC) (triple output; 1x 6V @ 2.5A, 2x 0-20V @ 0.5A, CC, CV, linear type).
Besides HP, you could look for other names such as (some examples linked that are good value IMHO & within your budget):
Or try general terms such as "lab power supply", "variable power supply", "dual output supply", and so on (sifting through these can yield some really good bargains if you're careful & patient).
Post by: zapta on December 03, 2015, 06:08:23 am
My needs are similar to yours (hobyiest working on microcontrollers) and am happy with the latest version of this one one.  Small, light, quiet and easy to operate. There are two variants, with different max voltage/current combinations.
https://www.youtube.com/watch?v=6LEN_HNFK40 (https://www.youtube.com/watch?v=6LEN_HNFK40)
Post by: MarkF on December 03, 2015, 06:32:02 am
I asked about the Tekpower TP3005T a while back.  Check out some teardown pictures and measurements done by another member:
https://www.eevblog.com/forum/testgear/tekpower-tp3005t-variable-linear-dc-power-supply/msg719478/#msg719478 (https://www.eevblog.com/forum/testgear/tekpower-tp3005t-variable-linear-dc-power-supply/msg719478/#msg719478)
I have two HP-6216A 0-30V 0.5A linear supplies from eBay around $50.  One a little more the other a little less.
http://www.ebay.com/itm/HP-Hewlett-Packard-Variable-DC-Power-Supply-6216A/262159201562?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3Dd1c5eba00e1943519d11b2c8f2864878%26pid%3D100011%26rk%3D1%26rkt%3D10%26sd%3D262058665833 (http://www.ebay.com/itm/HP-Hewlett-Packard-Variable-DC-Power-Supply-6216A/262159201562?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3Dd1c5eba00e1943519d11b2c8f2864878%26pid%3D100011%26rk%3D1%26rkt%3D10%26sd%3D262058665833)
Post by: TheSteve on December 03, 2015, 06:58:15 am
This is how I view power supplies as well. My main bench supply is an Agilent E3610A. If I need 13.8 volts with more current(for amateur radio gear) I also have a Samlex SEC-1223.
I like linear bench supplies with no fan whenever possible.
Post by: rdl on December 03, 2015, 07:42:25 am
I have a couple of 3610s myself, I bought them used off ebay. One is an Agilent and the other is an older HP. Neither was over $150 including shipping. I actually have six power supplies now. None are switch-mode and none of them have fans. I really, really dislike loud, noisy power supplies.
Post by: KubaSO on July 24, 2022, 09:22:55 pm
In case anyone needed it: I've reverse-engineered the secondary section of the Kepco 620M. The schematics are here:
https://github.com/KubaO/T-M-Reverse-Engineering (https://github.com/KubaO/T-M-Reverse-Engineering)
It's a beast :)
Post by: KG7AMV on July 24, 2022, 09:30:32 pm
Save a little more and get a Siglent SPD3303X-E Mine is Very Accurate After Calibration using the instructions in the service manual. I think its the only PSU MFG out there that gives Calibration Info.
Also look for Siglent in amazon Whearhouse deals. Single Channel Siglent SPD1305X go for about 200 shipped.
Post by: Wallace Gasiewicz on July 24, 2022, 10:52:33 pm
 I agree entirely, I believe SMPS work well in the system they are designed for. In a bench supply you don't need spurious signals running amok.
In SMPS applications these spurious signals are outside of the intended device powered. You do not know that is the case when using a bench PS on different devices.
I do like triple PS, when powering gear that requires them, I don't know if you intend to do this.
Post by: Old Printer on July 25, 2022, 02:29:51 am
I have several of the old HP 6216A supplies and really like them. Built like a tank, very serviceable, and the service manuals are easily available online. Mine averaged $50 70 shipped on eBay. Two can be setup for a +&- supply for opamp circuits.
Post by: mansaxel on July 25, 2022, 06:45:10 am
Second the recommendation on hp/Harrison supplies. They're eminently serviceable, cheap on your side of the pond, and so high quality that anything remotely as good, new, would cost 4 digits dollars.
I have a 6206 and a 6237, and use them a lot. (I also have a 3A 2x32V Uni-T and a big, 10A 2x35V TTi, and there's a 3-voltage Oltronix lurking in the repair queue. I'd like to get hold of a 6209b for the high voltage; that would be used for valve work and as transfer standard for checking multimeters.)
Further, supplies are one of those things you really early need more than one of, so by buying used you can get further along your needs. Just like multimeters (this only partially explains why I have something like 10 of them, though).  In your case, I'd initially look at one variable for lab work, and one fixed at 13,8V for running the radio gear. Then progress with another for the lab. If you do opamp work, a lot of time and hassle can be saved by getting a dual-voltage one.
Post by: nctnico on July 25, 2022, 08:51:35 pm
The biggest downside of the older PSUs is their inaccurate metering. A PSU like the GW Instek GPP-4323 or Keysight E3631x series have accurate (4.5 digit) metering which doesn't require external metering (=extra DMMs) to measure output voltage, power and current.
At some point I wanted to get extra DMMs to measure voltage and current on a bench PSU when it dawned to me that the PSU itself should have adequate metering.
Post by: abeyer on August 02, 2022, 09:51:07 pm
Seems like you could get 5 good older HP supplies and 5 decent 4.5 digit DMMs (that you'll also have for other uses) and still come out ahead of the retail price of buying that Keysight new. ???
Post by: nctnico on August 02, 2022, 09:54:55 pm
You'd need 10 DMMs to measure both current and voltage and still have no way to show power usage. Now look at the volume 10DMMs and 5 PSUs would take. Besides that you have the issue with the burden voltage across the DMMs that measure the current so you'd need sense wires as well. It simply is better to start with a PSU that has accurate metering built in.
Post by: abeyer on August 02, 2022, 10:33:14 pm
Yeah of course, I was being facetious, I don't expect anyone to actually do that -- but pointing out the benefits of a multi-thousand dollar option is in a thread about what are good options on a $150 budget seems kind of pointless. Yeah, you're right, if you exceed your budget by an order of magnitude, you can get better gear.
Post by: nctnico on August 02, 2022, 10:53:08 pm
None of the options I proposed costs multi-thousand dollars! The GW Instek GPP-4323 is over budget but not out of reach. Also on the used market you can get power supplies with accurate metering. For example the Agilent 66311B and it's brothers can be obtained for low prices with some patience (or by just low balling sellers on Ebay; some do know their asking price is way too high and happily accept a much lower offer).
Post by: abeyer on August 02, 2022, 11:10:51 pm
Ah ok! That makes way more sense -- I think we're in agreement then, I was just totally perplexed when I threw that keysight model in google and was getting all results in the $1500-$2000 range, but I think it was just mangling the search to one it thought was "more appropriate"  |O
