I work for a telecom company that tests equipment before it goes out into the field. We have dozens of different SFPs we must test and our client has specifically asked us to check the EEPROM data stored on it such as wave length, serial number, manufacturer, etc. This is to catch counterfeits since EEPROM data often gives them away. Currently, we're using this to accomplish everything:
https://www.router-switch.com/os6450s-cbl-60.htmlI wrote some software that telnets into this switch to access the shell where I execute commands to get this EEPROM data and parse it out so our technicians get a really simple overview of only the relevant data. We also connect the SFP we're testing to another switch and ping it so we ensure network communication is happening as well. This all works great, except that these switches are customer owned product (which we don't want to use for testing) and they're hard to find and are becoming less reliable due to their age.
We want a solution that doesn't rely on customer owned equipment and we'd like it to be a bit more modern. Here are the requirements:
1. It has to have the ability to display EEPROM data (Serial number, manufacturer, wavelength, etc).
2. It has to have some kind of interface so we can read data straight from the unit. Telnet or RS232 serial are preferred (we need to keep records and write software for it)
3. It does not have to be a switch, but that might be the easiest way to go. If there was a dedicated device to test SFPs, that would work too, but it would still need to show EEPROM data no matter what.
4. We'd like it to have quite a few ports on it, but isn't totally necessary. Our technicians only have so much time to test and right now they have the ability to plug in several SFPs to the switch at once. They plug in 1 fiber cable to the one they want to test, use the software I wrote to test it, then move the fiber cable to the next slot and do it again. If we had to do this 1 at a time isn't awful, but it's not desired either.
So based on this information, does anybody have any recommendations on how we can achieve this? Thanks for any help
