Author Topic: Shopping. How long do (chinese) scopes last?  (Read 3906 times)
Offline argile_tileTopic starter
« on: February 15, 2023, 12:58:07 am »
So I'm thinking "throw away the tek 420a i can't find a power supply replacement*".
I'm looking at Hantek $200 - $500 models.  I am unsure which and how long they will last.  I am guessing if the power dies they will not be repairable.  So how long should I guess I will own it?  That would help me decide between models.  (EEVBlog gave a horrid review of "touchpad scope" fnf1rn or what - so that's out the window)
Measuring  $/(hours_on), low hobby budget.
I very much remember the "scopes in the dumpster" EEVblog episode. I'm unsure if I have money to set down $500 if I know the scope will fry itself in a 2 yr.  I'd be the $200 customer or even put off getting one if they are 2yr not 10yr builds.  (and the features are changing so quick: Hantek is on the move.)
Should I consider a $500 low-end Keysight or Tek (that appear to be cheap chinese units) as will "lasting longer and better to own", or no, they will die just as soon and be less featured as to new hantek $500?
I'm a linux users I'm not helped by "win10 only", nor will i plug any wire into my PC from any project board.  I like "hackable" but - for money - knobs and display and results: are good too.
Tek 420a: slowly had issues coming on - then just stopped.  Caps were good.  I think the transformer was dead (my chart says - i disconnected it completely after suspicion ran many tests - sometimes using power from the ps), I couldn't be sure.  No schematic available u kno.  I burned the ps up after about 100 tests transformer I/O i mistakenly shorted it went right to power control IC (i was searching for possible issue that wasn't transformer's fault with just a multimeter).  I (assume) I can't replace the ps - there are like 40+ pins to power - at least three voltages, and who knows what they didn't document on 20 pins they didn't document :)  Scope obviously was not connected during any test whatsoever - sure it works still.
« Last Edit: February 15, 2023, 01:15:07 am by argile_tile »
Offline BillyO
Re: Shopping. How long do (chinese) scopes last?
« Reply #1 on: February 15, 2023, 01:08:45 am »
I have an 11 year old UNI-T that looks like the day I took it out of the box.  A round-about estimate is 8,000 power-on hours or about $0.20 per hour.  I would not consider UNI-T to be the best made scope out there.  I am sure a Siglent or Rigol would be a better bet, but the UNI-T shows no signs of getting worn out or failing. But now it's back in it's box looking for a buyer.  YMMV.
The Siglent 2000XP and 1000X-E series scopes (I have both) have web interfaces, Ethernet connectivity, are trivially hackable, and are orders of magnitude better built scopes than the UNI-T.  But time will tell...
BTW, my Tek 465 (about 45 years old) is still going strong and it's cost per POH is probably similar to the UNI-T.
« Last Edit: February 15, 2023, 01:19:19 am by BillyO »
Offline james_s
« Reply #2 on: February 15, 2023, 01:14:28 am »
They're probably fine, but don't throw away the Tek, even with a bad power supply it can be sold. I finally managed to fix both of the TDS400's I have, both had bad power supplies when I got them.
Offline edavid
« Reply #3 on: February 15, 2023, 01:24:25 am »
Why would you spend $500 on a Hantek when you could get a much better GW Instek, Rigol, or Siglent scope for less?
Instek GDS-1054B is currently $350 from Tequipment with EEVblog discount.
It even has a 3 year warranty.
« Last Edit: February 15, 2023, 01:26:11 am by edavid »
« Reply #4 on: February 15, 2023, 01:27:07 am »
I'm unsure anyone would pay what shipping now costs for a Tek 420a with 1 burned out channel (2 good, 1 mostly-good) and no power.  Been on the floor for a year.  One Nicad battery is damaged poorly charges.
The parts and time to connect 40 "not all known connectors" will cost as much as a UNI-T or Hantek I think.  For example: I can say "taken an old PC supply it has 12V 5V", but 5V on a PC supply is thin: the scope uses ALLOT of amps on 5V.  It's not cheap to fix at all - I think.  And oh did i loose the ROM by having a bad battery?
Unless you have advice :)  I actually have a large old OS transformer that "might power it has many taps" ...  but I don't want to burn up a good transformer unless I know the specs on the 420a:  i would burn out a heavy transformer for no good reason.  on the other hand, buying TI discrete parts part by part on mouser for 40 pins connecting them all for the watts this things needs: that's gonna cost allot really.
« Reply #5 on: February 15, 2023, 01:27:47 am »
thank you i'll consider that.  i was just looking at UN-T
« Reply #6 on: February 15, 2023, 01:36:53 am »
I saw ALLOT of complaints on many ($200 $500 chinese scopes) on AMAZON.COM.  It's why I asked.
"failed after hours of use", "failed after days of use", "screen is corrupted on arrival", "failed just after 1 yr warrantee", and so on.  Complaints filed on many models even on EDU tek and keysight.
It's good to hear people who bought and used them believe they can last 8 years.  They have only a 1yr warrantee.  I can afford that, I really can't afford a flash in the pan, is all.
Offline bdunham7
« Reply #7 on: February 15, 2023, 03:37:21 am »
I saw ALLOT of complaints on many ($200 $500 chinese scopes) on AMAZON.COM.  It's why I asked...
..."failed just after 1 yr warrantee", and so on.  Complaints filed on many models even on EDU tek and keysight.
There are a number of choices that won't have those issues.  I'd recommend the Siglent 1104X-E, $464 on Amazon with no such complaints and a 3 year warranty.  You can sometimes find them on sale for a bit less, or perhaps TEquipment will have a lower net price for you at $499 + 6% discount for EEVBlog + free shipping + maybe no tax.
The 420A won't sell for much and about the only thing going for it is the TekProbe interface.  I'd be tempted to tear it apart and use the parts to make a TekProbe adapter, but I don't think it would be easy to get all of the functionality to work--although you may not need it and I'm not sure the 420A has all the features either.
Offline james_s
« Reply #8 on: February 15, 2023, 03:51:23 am »
A working TDS420 should fetch $100-$250 depending on condition. Looks like prices are finally starting to come down, they were pretty crazy for a while. I have a couple of TDS400 scopes and quite like them actually, they're not as nice as the newer TDS scopes but they work well and the display is usually nice and sharp.
As for failures of low cost scopes, you have to look at the overall reviews. Nobody logs in after a year to say their scope is still working, they only write something if it breaks.
« Reply #9 on: February 15, 2023, 06:36:43 am »
In the 10 years we've sold Siglent, AFAIK all are still operating.
IMO don't buy from Amazon but instead select an authorised dealer that will stand behind the products they sell.
We deal with Siglent HQ and TBH we couldn't wish for better support and backup in the case of warranty which is very rare for us. Siglent offer a 3 year warranty on equipment and 1 yr on probes.
Their branch in Ohio will give just as good support.
Offline Gyro
« Reply #10 on: February 15, 2023, 09:15:53 am »
If it was you who damaged those channels, I wouldn't expect the inputs of a Chinese scope to be a rugged as those on a TEK.
Best Regards, Chris
The following users thanked this post: MadTux, Fungus
Offline Fungus
« Reply #11 on: February 15, 2023, 09:39:05 am »
I wouldn't go for the rock-bottom brands like Hantek or Owon. They're very limited.
There's no reason other Chinese brands won't last 10 or 20 years. Rigol/Siglent/GW-Instek brands are rock solid.
Yeah, that's "Amazon" users for you.
The very first thing they probably did with them was connect them to mains electricity with the probe on 1x setting just to see the pretty sine waves.
You aren't going to do that, are you?
Offline BeBuLamar
« Reply #12 on: February 15, 2023, 12:44:35 pm »
May be 30 years?
Offline AFTORF
« Reply #13 on: February 15, 2023, 12:53:33 pm »
It's cheaper than a function generator to make a test !  ;D
En formation continue depuis 1980...
Offline TomKatt
« Reply #14 on: February 15, 2023, 01:52:33 pm »
'Made in China' isn't really a reflection of a product's quality...  Pretty much every Apple product is 'made in China' and they seem to set the bar for what consumers expect for quality.
Like anywhere else, there's well designed and manufactured gear, and there's cheap low quality merchandise.
From my limited experience, provided you steer clear from the non-name cheap rubbish and go with some kind of name brand that carries some respectability (like Rigol, Siglent etc), those products will last as long as anything else in their class.
Where any modern piece of test gear suffers is in reparability - while you can maintain an old analog scope and find repair documents and replacement parts, modern gear is simply less repairable by the average hobbyist.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
The following users thanked this post: 807, Fungus, zrq
Offline edavid
« Reply #15 on: February 15, 2023, 04:02:25 pm »
Forget the C brands like Hantek and Uni-T.  The brands you should be considering are Instek, Rigol, and Siglent, and they all have a 3 year warranty.  They wouldn't offer that if the scopes weren't reliable. Buy with a suitable credit card and you get an extra year on top of that.  Don't buy from Amazon, buy from Tequipment or Saelig and get the EEVblog discount.
Online mwb1100
« Reply #16 on: February 15, 2023, 11:40:39 pm »
Tequiptment handles their free shipping with a coupon code - which won't stack with the EEVBlog code.  Saelig gives you the free shipping regardless (no code is needed to activate the free shipping).  So generally you'll save 20-30 bucks with Saelig.
Offline bdunham7
« Reply #17 on: February 16, 2023, 12:02:40 am »
That must be a new policy.  They sell on Amazon where I'll get their same price, 5% rebate and free shipping.  I'm pretty sure Amazon takes a way bigger bite that way, so not the best move on their part IMO.
Online rsjsouza
  • Eternally curious
    • Vbe - vĂ­deo blog eletrĂ´nico
« Reply #18 on: February 16, 2023, 12:57:45 am »
As others have said, for around $500 you will be much better served by Siglent, Rigol or GW Instek. Forget about Fnirsi, Uni-T, Hantek, Owon (except their USB oscilloscope VDS1102I).
Just for the record, I have a Rigol for almost eight years and it still works like a champ. Looks brand new as well. Has its quirks but it is an excellent value for the money.
Vbe - vĂ­deo blog eletrĂ´nico http://videos.vbeletronico.com
Offline CustomEngineerer
« Reply #19 on: February 16, 2023, 10:20:24 pm »
I'm not sure where you are getting that. I ordered a new scope in late November of last year directly from tequipment and used the eevblog discount code and received the free shipping as well.
To the OP. As others have said, avoid the Hantek and other cheapies. I bought a Hantek as my first scope and sent it back because it kept locking up for a variety of different reasons. I would also recommend looking at Rigol, Siglent or GwInstek if you can afford it. Not that they will be trouble free, but they generally do a decent job of responding to issues and fixing them when they can.
Online mwb1100
« Reply #20 on: February 17, 2023, 05:45:32 am »
I tried to order an MSO5074 in September and I had to put in the "FREESHIP" coupon code to get free shipping. When I put in the EEVBlog code I got the EEVBlog discount, but the shipping was added back in.  I asked in email if they could get me both discounts and they said no, so I went to Saelig.
I don't have the emails anymore because my email client perma-deletes mails in the Trash folder after 30 days.  I tried the same thing today (but with an SDS1104X-E for whatever reason) and got the same behavior.
« Last Edit: February 17, 2023, 05:57:47 am by mwb1100 »
Offline H713
« Reply #21 on: February 17, 2023, 06:24:35 am »
Just remember, this is a very competitive market, and unless something has changed, Amazon is terrible about policing fake reviews. Who's to say those weren't left by a competing manufacturer?
The scopes coming from the far east seem to be fine. Are they as reliable as a Keysight or a Tek? Of course not, but that's what you get for $500. As a guess, I'd expect 10 years of hobby use, or maybe 5 years of constant lab use.
Odds are the fault will be an encoder, PSU or display issue, and if you're so inclined, any of these is likely to be pretty fixable even without schematics.
I believe my Siglent came with a 3-year warranty, but some of the other Chinese equipment I've bought is 1 year. The only stuff to offer better than than 3 years is pretty high-end and expensive.
« Last Edit: February 17, 2023, 06:29:47 am by H713 »
Offline ebastler
« Reply #22 on: February 17, 2023, 06:24:45 am »
I don't recall seeing any repair threads on this forum where users had to fix a broken Hantek, Owon, Siglent, or Rigol scope. Firmware hacking, modifications (e.g. encoder upgrades, quiet fans), sure -- but no repairs needed, it seems.
Personally I have had my DS1054Z for eight years now. Used it quite a bit, lugged it around in a suitcase quite a few times, and it is doing fine. Two of the original probes did fail though. That's just one data point, but the absence of repair threads suggests to me that these entry-level scopes are generally quite robust.
Mass production, optimized for good yield, probably helps. As long as the main board and power supply don't run hot (since the engineers skimped on cooling), I would not be too concerned about reliability.
Offline Fungus
« Reply #23 on: February 17, 2023, 07:27:44 am »
Evidence needed.
« Reply #24 on: February 17, 2023, 07:34:28 am »
Evidence needed.
Yep I picked up on that too Fungus.
It seems some seem to forget Rigol got its start making scopes for HPAK.
And lunch box Teks have been made in the east for decades.
