Author Topic: Siglent SDG5082 any good?  (Read 15005 times)
Offline rf-loop
  • Country: cn
  • Born with DLL21 in hand
Re: Siglent SDG5082 any good?
« Reply #25 on: May 26, 2013, 12:14:54 pm »
As a postscript to my last post -
Another test I'd like to see would be square waves both the standard ones and ones using the arbitrary waveform.
In particular some at maximum amplitude as well as at lower amplitudes to see how the overshoot and rise times change. Though I guess you'll have to set a low duty cycle to protect
the scope if you're using a 50 ohm input.
If need I can use  enough big power feed thru 50ohm RF "dummy load". (high power attenuator)
« Last Edit: May 26, 2013, 12:16:32 pm by rf-loop »
If practice and theory is not equal it tells that used application of theory is wrong or the theory itself is wrong.
Harmony OS
Offline Siglent
  • Country: cn
  • SIGLENT
    • SIGLENT TECHNOLOGIES
« Reply #26 on: June 26, 2013, 03:07:05 am »
There is an Easypulse introduction about the SDG5000:
The Best Value in Electronic Test & Measurement
