Hello,
I made the rookie mistake of shorting the neutral line voltage (120vac) through the probe ground. Not great.
I now have an issue with my scope (unsurprisingly) and I'm hoping someone can give me an idea of what the issue is. I have an analog scope (Circuit test OS-2030) and the vertical lines seem to be out of alignment. The trace adjust only adjusts the horizontal. Otherwise, it seems okay... The picture shows what I'm talking about with the 2vp-p square wave. The measurements seem to be fine,it just needs to be tweaked back.
Any thoughts?
Thanks!
