I have an R&S FPC1000 SA. Under some conditions I notice an artifact step in the display at just about 1 MHz. This is not a function of the signals I put in -- in fact it also occurs with no input signal and just a 50 Ω connected to the input. I have seen this step as large as 10 dB in some cases.
It seems this is somehow related to relative values of RBW and VBW settings, and/or the averaging mode, but I can't figure out what.
Here is an example of no input, and (in this case a small step) a step is visible at 1 MHz (not precisely, generally 989 kHz).
Any ideas on what is causing this ?
