@free_e
Correct me if I'm wrong, but I believe that the MegaZoom makes the scope feel much, much more responsive. After trying out the Agilent 2000X and the 3000X, the Tek TDS, DPO, and my Rigol all feel like cold molasses by comparison. I would believe that this is the magic of the on-die memory?
the megazoom is the key. the same technology sits in the 'big iron' infiniiums like the 54831 and 54832D ,
Infinivision is the next generation of megazoom ( more on that in a second) the 2xxx 3xxx and 4xxx 5xxx 6xxx and 7xxx has that
Megazoom is , apart from the large memory, basically a huge resampling asic. depending on how you define the 'viewport' in the memory this asic resamples the data in storage and paints a new image.
when you twiddle the timebase and offset knob on the frontpanel basically what you do is mess with two pointers : start and stop in the memory.
the display only hs so many pixels ( 540 i believe horizontally on the 645d) ( there are more but those are for the menus and graticule , only 540 wide for the real trace data )
the megazoom asic resamples the 'slot' you define in the memory and creates a new 540 pixel wide image. basically it divides your defined span in 540 slots and looks inside each slot and performas a peak detect. the result of the peak detect becomes the new pixel.
that is why these machines dont show aliased images. that asic is incredibly fast. it can do this work withing1 refresh cycle of the old tv tube ( 60hz refresh cycle)
you can see this process at work. simply touch your finger to a probe and look at the signal. tune it so you see about a period. look at how wide the 'trace' is. then hit the stp button. now see how small the trace has become. it is only 1 pixel thick !
the 'wide' band you saw when the thing is running is due to the refresh speed. your eyes cannot follow the screen. combine it with the persistence of the phosphor in the tube . the megazoom asic can repaint a complete display inside the vertical blanking interval ! so it repaints the entire display 60 times a second.
now, these older machines do have a blind time. they dont do 1000000 waveforms a second , but they can do a full sweep insinde the flyback of the tv tube. that is why they feel so incredibly fast. the megazoom asic can reprocess the entire image inside the blanking interval of the video signal that goes to the display.
your 2xxx or 3000 feel 'sluggish' because it has to crunch a much larger pool of data , plus the lcd in those scopes does not refresh at 60hz. more at 30 hertz. so you have the impression of slugginess , in reality the machines crunch a much larger pool of data. they can't do that inside a screen refresh interval anymore..
