Author Topic: Show the homemade equipment you are using now.  (Read 25616 times)
Offline Jester
Re: Show the homemade equipment you are using now.
« Reply #100 on: March 17, 2023, 11:47:31 am »
I'm using it this morning, 19bit AC/DC load, mostly use it in AC mode. 250V, 40A
« Last Edit: March 17, 2023, 11:55:19 am by Jester »
Offline Edison
  • Country: cz
« Reply #101 on: March 17, 2023, 12:34:14 pm »
Well used HP case, unfortunately these boxes do not fit deep into my workplace
👍 beautiful work 👍
Everything works as the weakest link in the chain
Offline jasonRF
« Reply #102 on: June 17, 2023, 03:34:27 pm »
This is a very simple low-voltage differential probe I made a while ago, mostly to use at audio frequencies, so is just built with a TL052 with some 0.1% 100k resistors.  I had it open today to check which op amp I used so decided to take a picture.  The front-panel switch is to engage a 40 kHz 2nd-order Butterworth low-pass filter (very useful when measuring outputs of some class-D amplifiers).  I measure 50+ dB CMRR in the audio band.  It frees up a channel on my 2-channel scopes, so is pretty useful.
jason
Online Martin72
  • Testfield Technician
« Reply #103 on: June 17, 2023, 07:12:50 pm »
Not in use now, but in progress:
Power inductor checker, inspired by:
http://elm-chan.org/works/lchk/report.html
I designed the board and made some changes, the first test showed that some improvements are still necessary.
When I have them on the way, a separate thread will follow.
Online Aldo22
« Reply #104 on: June 17, 2023, 07:59:52 pm »
My first, handmade, cheap adjustable power supply.  8)  :D
Offline ccktek
« Reply #105 on: June 19, 2023, 06:52:31 pm »
« Last Edit: June 19, 2023, 06:57:25 pm by ccktek »
Le chat a ses raisons que la raison ne connaît point.
KØMGP
Offline fable
  • Country: cs
« Reply #106 on: June 30, 2023, 07:43:03 am »
Here are some of the tools i have made and use every day
First picture from top to bottom
Dummy Load
PSU ac/dc
vacuum pump pickup tool
triple soldering iron controller
2.  PSU 2x24v 2A
3.  Soldering iron and desoldering gun controller
4. Differential probe
Offline KungFuJosh
  • TEAS is real.
« Reply #107 on: June 30, 2023, 01:22:34 pm »
This is my vacuum tube curve tracer.
In my current unit, I added a step up converter for the heater voltage. Now I can run heater voltages at 20V easily (or higher, but I don't have any need for that).
The following users thanked this post: Martin72, jasonRF
Offline py-bb
  • Country: af
« Reply #108 on: August 03, 2023, 05:06:25 am »
A bit of horror is inside.
I fully agree.
But totally worth posting - I learn a lot from just seeing how some of these are assembled.
Never be afraid to post a monstrosity, if we only posted perfection there would be no posts!
Offline Hexley
« Reply #109 on: August 03, 2023, 03:56:42 pm »
This device tests batteries of various types -- button cell, AAA, AA, C, D, and N; coin cell lithium; and 9 volt packs. It supports battery chemistry of alkaline or NiMH types for most cells.
The knob selects the cell size and chemistry, then is clicked to start a load test with the appropriate current. The voltage under load is measured, and the display shows "New/Good/Weak/Dead" according to the corresponding voltage threshold. The estimated charge level is displayed, as is the voltage under load.
It is built around an adjustable current sink with a range of 10 uA to 200 mA, controlled by a small ARM Cortex processor that also handles the rotary encoder input and LCD output.
The battery holder is a "BF-2A", found on Banggood. Henrik Jensen (forum user HKJ) put me on to it.
