Author Topic: Show the homemade equipment you are using now.  (Read 25621 times)
Offline Bud
Re: Show the homemade equipment you are using now.
« Reply #75 on: January 29, 2023, 07:14:58 am »
A project from 2003, a dual audio tone generator 700 Hz and 1800 Hz  to check intermodulation performance of Ham radio transmitters (design from an ARRL Handbook of the era)
Offline DavidAzulay5000
  • Country: il
« Reply #76 on: January 29, 2023, 08:10:40 am »
HP 3325B
HP 8904A
Tektronix 2445
Tektronix 2465
Keysight E3620A
R&S CMU200
keithley 197a
FLUKE 87
hakko FR-801 smd rework station
hakko 850b
quadtech 1659 rlc digibridge
« Last Edit: January 29, 2023, 08:57:47 am by DavidAzulay5000 »
You don't need pants for the victory dance
Cuz Baboon's better than Weasel
Offline MrYakimovYA
  • Country: ru
« Reply #77 on: January 29, 2023, 09:23:46 am »
HP 3325B
HP 8904A
Tektronix 2445
Tektronix 2465
Keysight E3620A
R&S CMU200
keithley 197a
FLUKE 87
hakko 850b
Wow! What a nice homemade equipment! :)
The following users thanked this post: DavidAzulay5000
Offline BillyO
« Reply #78 on: January 29, 2023, 05:37:16 pm »
HP 3325B
HP 8904A
Tektronix 2445
Tektronix 2465
Keysight E3620A
R&S CMU200
keithley 197a
FLUKE 87
hakko 850b
I was thinking the same thing.
  • Country: il
« Reply #79 on: January 29, 2023, 06:06:48 pm »
HP 3325B
HP 8904A
Tektronix 2445
Tektronix 2465
Keysight E3620A
R&S CMU200
keithley 197a
FLUKE 87
hakko 850b
I bought most of the my equipment broken .
i repaired and calibrated it
I enjoy it the most
to repair measuring equipment
Offline shapirus
  • Country: ua
« Reply #80 on: January 29, 2023, 06:35:16 pm »
This is a voltage reference based on a well-known Chinese "LM399" module which actually appears to be staying pretty stable over time. How precise the numbers that are hand-written on it are is quiestionable, but they appear good enough and they can always be verified when there's a chance to use a precision voltmeter. Most importantly, it can definitely be used to check if the DMMs are still all right, which is its primary job.
Inside is a linear power supply and mode selection circuitry that uses relay contacts where a jumper was used on the module's pin header to select one of the six output voltages.
Usage:
And this one's used literally every time I need to try something out on a breadboard or quickly power something up otherwise.
Nothing fancy, just an isolated transformer -> bridge -> caps -> one of those well-known Chinese DC/DC modules.
The following users thanked this post: bingo600, Mickle T., MrYakimovYA
Offline jonpaul
    • IEEE Spectrum
« Reply #81 on: January 30, 2023, 02:10:57 am »
Unearthed in the  # 3 archive, covered in dirt , unused in 30 years.
1980s DIY 3 wide Tektronix plugin TM500 tester PSU, like TM503 but no cage or rails just the PSU.
NPN/PNP on floating HS,  56 pin  genuine AMP card edge connectors are gold plated and spring floating.
Your thoughts appreciated!
Jon
An Internet Dinosaur...
Offline jasonRF
« Reply #82 on: January 30, 2023, 12:15:55 pm »
I enjoy it the most
Offline tomud
« Reply #83 on: February 05, 2023, 12:45:57 am »
My old case design for Chinese 150W Constant Current Electronic Load 60V 10A
3D Printing Case Design: https://www.thingiverse.com/thing:4328521
« Last Edit: February 05, 2023, 12:52:20 am by tomud »
For every complex problem, there is a solution that is simple neat and wrong...
The following users thanked this post: exe, PerArdua, Kosmic, pcprogrammer, TizianoHV, shapirus
Offline rfclown
« Reply #84 on: February 05, 2023, 04:01:32 am »
Rubidium 10 MHz.
Online coppercone2
« Reply #85 on: February 05, 2023, 11:06:57 am »
Small 1A variac. Has fuses and an IEC connector on the back. Needs one more switch on the back, so its possible to isolate the primary when plugged in (I will probobly add a switch + iec this spring). The vents are painted steel grate. One of a few that I have built. But this one is mainly used as a portable source that goes back on the shelf when not in use. And color coding the binding posts is a priority   :-[
I also always wanted to lay in the inside with metal, maybe nickel silver sheet. And a indicator lights for powered and output (which will only work for high settings). Plenty of room for a few things anyway, but that one is not getting meters.
« Last Edit: February 05, 2023, 11:13:37 am by coppercone2 »
Offline Kosmic
« Reply #86 on: February 05, 2023, 02:14:02 pm »
Mighty good job with the enclosure, I'm impressed  :-+
Offline rfclown
« Reply #87 on: February 05, 2023, 03:40:37 pm »
Trombone air flow meter (2019) ...
Not that's something I don't have on my bench. Where do you sent it for calibration? I do have a trombone line, but I couldn't find it to take a picture, so I took a picture of a dial phase shifter (same function) and a tuner along with my cornet and trumpet mouthpieces. I don't have any mouth piece to N adaptors though.
Offline dobsonr741
« Reply #88 on: February 05, 2023, 07:14:54 pm »
5 1/2 digit Autoranging DC voltmeter for 150mV...250V. Built with ADS1263. SCPI control over USB.
The following users thanked this post: exe, TizianoHV
Offline jasonRF
« Reply #89 on: February 06, 2023, 12:59:00 am »
This is a ~6 dB,  ~5 MHz amplifier I built with selectable 50 Ohm or "0" Ohm output impedance.
Nice work! It looks so nice! Could you tell me what is its noise level?
My scope says about 210uV RMS. This is with 50-Ohm feedthrough on the scope, with the 20 MHz bandwidth limit turned on, and with the amplifier set to 50-Ohm output impedance and the volume control set to max.   The noise level of just the scope is about 160uV RMS with the 20 MHz limit, so the amplifier is at the limit if what the scope can see.  By the way, the scope is a Picoscope 5244B, and I was running it in 16-bit mode at 62.5 MS/s at the most sensitive scale (which is only 2mV/div).
Jason
« Last Edit: February 06, 2023, 03:19:49 am by jasonRF »
The following users thanked this post: MrYakimovYA
Offline Ground_Loop
« Reply #90 on: February 06, 2023, 01:29:18 am »
My Unisolder with Pace Accudrive handle that I use almost exclusively.
1709801-0
There's no point getting old if you don't have stories.
Offline tomud
« Reply #91 on: February 06, 2023, 03:56:04 pm »
Vacuum pick and place tool controlled by a foot switch.
Electronics built from what I had in stock (universal board, AT Mega microcontroller, etc.). It has several operating modes, adjustable pump speed, valve opening time, etc.
« Last Edit: February 06, 2023, 03:58:02 pm by tomud »
Offline MiroS
« Reply #92 on: February 07, 2023, 12:33:58 pm »
A bit of horror is inside.
I fully agree.
Offline tomud
« Reply #93 on: February 07, 2023, 04:18:37 pm »
Thank you for the kind words. I'm not an expert in designing in CAD programs, just an electronics engineer and a programmer. But I try to do projects for a 3D printer as best as I can and I'm still learning.
Offline Mickle T.
  • Country: ru
« Reply #94 on: February 14, 2023, 08:50:13 pm »
A portable DCV/DCI/OHMs programmable standard (left) for the "Russian Cal Club" and an upcoming desktop version for home use (right). Both are powered by selected AD5791+LM399 after 5.2 years of electrical/thermal training.
The following users thanked this post: ddrl46, bsw_m, MrYakimovYA, serg-el, MegaVolt, Kosmic
Offline shapirus
  • Country: ua
« Reply #95 on: March 04, 2023, 07:12:32 pm »
Yet another dummy loadâ„¢
This time made for the specific purpose of selecting the least crappy USB cables or USB chargers from those lying around that accumulated over the years.
0..2A adjustable constant current.
Offline Edison
  • Country: cz
« Reply #96 on: March 17, 2023, 09:54:34 am »
Hello, I haven't been here for a long time and I completely forgot about the request to create a thread with my creations, so at least add something here - the latest work is an AC regulated power supply 30V15A
Some photo of the gauges adjustment, done and here it rests with other creations
Nice day 🙂 Tom
Everything works as the weakest link in the chain
The following users thanked this post: jasonRF
Offline shapirus
  • Country: ua
« Reply #97 on: March 17, 2023, 09:58:37 am »
Beautiful.
Will you be willing to share the schematics? :)
Offline Edison
  • Country: cz
« Reply #98 on: March 17, 2023, 10:17:53 am »
I will also add one piece of quadruple voltmeter +/- 200V DC, the gauges are galvanically isolated and can thus be connected anywhere in the device under test, I haven't removed the protective film yet, because I don't have the anchor ready - so I don't scratch it.
I still have enough in stock, so I'll throw in something sometimes 🙂
Offline Edison
  • Country: cz
« Reply #99 on: March 17, 2023, 10:43:45 am »
Hi, there is nothing complicated about it, a regulation transformer is used at the input and a large toroid at the output - I needed another AC source and so I quickly built it from what I had at home, I originally thought about regulating the current, but in the end I didn't do it.
The following users thanked this post: shapirus
