Author Topic: Show Us Your Curve Tracer  (Read 48930 times)
Offline Electro FanTopic starter
« on: March 01, 2021, 07:44:12 pm »
It is very interesting to see the various approaches to "Curve Tracers":  analog, digital, hardware, hardware plus software, standalone, with an oscilloscope, with a computer, with a SMU - in each case the design reflects the objectives and other thinking of the designer(s).  Some curve tracers are for transistors, some for tubes, some for other active devices and/or passive components - lots of possibilities.
I think there might be a bit of a resurgence coming in curve tracers, for various reasons and purposes, not the least of which is education.
Please feel free to post your favorite curve tracers (including any images or links) that you use, built, or designed.  Tell us a little bit about your use case(s) and what you like about your curve tracer and what if anything you might like it to do differently.  Or feel free to post other related info that helps show the various uses and designs for assembled, kit, or DIY curve tracers.
Some people say that the world's first curve tracer was a Tektronix 570 but maybe someone knows of earlier curve tracers.
Here are several links for people wanting to get oriented toward curve tracers (intended to show some of the principles of curve tracers, not to advocate any particular product):
https://vintagetek.org/curve-tracers/
https://en.wikipedia.org/wiki/Semiconductor_curve_tracer
https://www.evaluationengineering.com/instrumentation/article/21126325/whats-the-difference-classic-curve-tracer-vs-smu-with-curve-tracer-software
https://www.rs-online.com/designspark/how-to-use-an-oscilloscope-as-a-curve-tracer
https://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=2838609&nid=-32110.1203274.02&id=2838609
https://www.allaboutcircuits.com/technical-articles/understanding-i-v-curves-part-i/
https://www.qsl.net/kd7rem/pdf/octopus.pdf
https://www.microwaves101.com/encyclopedias/curve-tracer-measurements
https://www.ossila.com/pages/iv-curves-measurement#
https://www.electronics-tutorials.ws/blog/i-v-characteristic-curves.html
« Last Edit: March 06, 2021, 12:10:03 pm by Electro Fan »
The following users thanked this post: tubularnut
Re: Show Us Your Curve Tracer
« Reply #1 on: March 03, 2021, 07:07:20 pm »
A few more links in case it stimulates any posts.
Excellent fundamental video on curves by W2AEW:
A very cool curve tracer:  ELV KS7000
A pretty practical/useful tracer:  DCA75 - Atlas DCA Pro Advanced Semiconductor Analyser
https://www.peakelec.co.uk/acatalog/dca75-dca-pro-semiconductor-analyser.html
An ideal entry/intermediate curve tracer (imo) might combine some of the functionality of the ELV KS7000 and the Peak DCA75  :)
Edit  Added comments and link:
An extension of the integration of ELV-like and PEAK-like functionality might be something like these Huntron products:
https://youtu.be/DHoEQivIdQQ
https://youtu.be/s-mRtOIHqqM
The realm beyond Huntron seems to go in the directions of perhaps still more functionality and flexibility and no doubt higher voltage thresholds as pioneered by the vintage Tektronix curve tracers.
Edit  Added:
Edit  Added:
https://www.eevblog.com/forum/testgear/transistor-curve-tracer-kit-on-ebay/?all
« Last Edit: March 10, 2021, 06:20:46 pm by Electro Fan »
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #2 on: March 04, 2021, 03:40:21 am »
Here is a 3D red-cyan anaglyph of my Tektronix 575 curve tracer.  It requires red (left) - cyan (right) anaglyph 3D glasses to view.  Click on it for a full size version.
Chris
The following users thanked this post: Exosia
Offline capt bullshot
« Reply #3 on: March 04, 2021, 07:43:06 am »
Recently I've used my Tek 577 to test a simple circuit (PWM to Resistance converter for a particular purpose):
The curve tracer is set to 0.1V/div, 50uA/div and 0.1mA per step with some offset.
Not too linear, but I believe it'll do the job as it will be part of a closed loop. The circuit is intended to control the output voltage of a COTS SMPS by paralleling its output side to the adjustment pot. Voltage across that pot is low enough for this circuit to work. Of course, the curve tracer doesn't apply an PWM signal to the photocoupler, but PWM will be fast enough it gets smoothed out by the systems frequency response.
« Last Edit: March 04, 2021, 07:45:10 am by capt bullshot »
« Reply #4 on: March 04, 2021, 08:10:04 am »
I used a 33120A and TDS210 as a curve tracer here to test a tunnel diode:
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg1974956/#msg1974956
33120A has a floating output which makes this easier to do.
« Last Edit: March 04, 2021, 08:11:42 am by bd139 »
Offline flash2b
They say attention is a shovel. It's time to dig 'em out.
Offline jan28
« Reply #6 on: March 04, 2021, 04:58:18 pm »
BB3 running micropython curve tracer script: https://youtu.be/I0y6fgv8G00
Screenshot from YouTube video:
1186260-0
The following users thanked this post: Electro Fan, Kean
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #7 on: March 04, 2021, 06:13:54 pm »
575  with the 400v mod :)
The following users thanked this post: Cubdriver, K0ELB
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #8 on: March 04, 2021, 08:03:34 pm »
Gotta love those old beasts!
-Pat
The following users thanked this post: K0ELB
Offline jjoonathan
« Reply #9 on: March 04, 2021, 08:19:50 pm »
SMU gang represent!
(glances to the left, then to the right -- coast is clear, SPA gang isn't around yet)
Custom 3D printed feet and "panel" (bar) turn this SMU into a convenient bench tool. Actual work is done in jupyterlab / holoviews / pyvisa-py.
Offline Johnny10
« Reply #10 on: March 04, 2021, 08:21:05 pm »
575! No, that is my curve tracer! :-+
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
The following users thanked this post: toboxo
« Reply #11 on: March 04, 2021, 08:31:18 pm »
SMU gang represent!
This is quite funny. I started designing a generic Tektronix grade curve tracer replacement last year. By the time I’d broken it down into logical blocks, made everything as generic as possible and attached a USB interface to it on paper I stepped back and squinted and it turned out I’d designed an SMU. I lost interest then for some reason.
The following users thanked this post: Kean, SilverSolder, jjoonathan
« Last Edit: March 04, 2021, 09:41:22 pm by Electro Fan »
« Reply #13 on: March 04, 2021, 09:24:19 pm »
« Reply #14 on: March 04, 2021, 09:24:50 pm »
-Pat
Beautiful outside and inside!!
The following users thanked this post: flash2b
Offline Cubdriver
  • Nixie addict
« Reply #16 on: March 04, 2021, 10:00:14 pm »
Found the one I took of my youngest lab assistant with the 'newest' curve tracer, too.  He is observing a color-cycling LED as it transitions between hues, thus the weird instability in the trace (and he's now a third again bigger than he was in that picture):
-Pat
The following users thanked this post: Martin.M, Electro Fan, egonotto, edavid, jjoonathan, Neomys Sapiens, bd139, factory, Anthocyanina
Offline jxjbsd
  • Country: cn
  • 喜欢电子技术的网络工程师
« Reply #17 on: March 05, 2021, 01:43:27 am »
-Pat
Cat: You can increase the vertical gear one more gear. :-DD
Analog instruments can tell us what they know, digital instruments can tell us what they guess.
The following users thanked this post: Martin.M, Cubdriver
Offline rcjoy
« Reply #18 on: March 05, 2021, 08:07:58 am »
Here's HP's version of the curve tracer, the 4145A Semiconductor Parameter Analyzer!
Offline simyaci
  • Country: tr
« Reply #19 on: March 05, 2021, 08:45:26 am »
this device is also my design
Offline wolfy007
« Reply #20 on: March 05, 2021, 12:41:41 pm »
Heres an old one from me, using the classic 7603 + 7CT1N (sorry taken in low light with phone)
« Last Edit: March 05, 2021, 12:44:56 pm by wolfy007 »
The following users thanked this post: precaud
Offline Johnny10
« Reply #21 on: March 05, 2021, 11:36:01 pm »
The Tektronix 577
« Last Edit: March 05, 2021, 11:38:03 pm by Johnny10 »
Offline Shock
« Reply #22 on: March 06, 2021, 03:29:19 am »
My Tektronix 576 curve tracer requires a power supply restoration but aside from that is a fairly clean example.
Here is a video that shows one approach to filter capacitor replacement. I may do mine a little differently so it's in the queue till I can devote the time. 49m40s shows their placement.
« Last Edit: March 06, 2021, 03:31:20 am by Shock »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #23 on: March 06, 2021, 10:49:37 am »
I have been monitoring prices for years and would love to have a higher voltage unit such as the 575/576/577, but unfortunately the disposable income and space in my lab are very limited.
So, this past Christmas I got a reasonably spec'd USB based curve tracer from a Chinese developer nicknamed locky_z. The unit is well made, the software is rock solid and well featured (despite having a small translation issue here and there) and it has good midrange specifications of 0-36V up to 2.5A.
In the pictures the unit is testing an old 2N6907 and bejng driven by my Power Designs 5015A.
I also did a video about it for my channel (in Portuguese only, sorry)
https://youtu.be/NjhEYeM-FWM
« Last Edit: March 06, 2021, 11:02:03 am by rsjsouza »
The following users thanked this post: Trader
« Reply #24 on: March 06, 2021, 06:12:26 pm »
Cool
Looks like locky_z sells kits and assembled versions on eBay:
https://www.ebay.com/itm/Locky-z-2019-Curve-tracer-/114233327020
https://www.ebay.com/itm/Locky-z-2019-Curve-tracer-with-new-component/114234796434?hash=item1a98eca992:g:91cAAOSwncJeyNdX
Also saw your unboxing video - it helps show what comes with the kit.  Thx!
