Author Topic: Show Us Your Curve Tracer  (Read 40920 times)
Offline KungFuJosh
  • TEAS is real.
Re: Show Us Your Curve Tracer
« Reply #125 on: November 20, 2021, 12:05:28 am »
All the popular guitar amp tubes.
Cool!  8)
Can you switch between triodes?
I ran a trace on a new production Tung Sol 12AX7. Here's the plot:
The GUI window is resizable, so you can make the plots full screen. The other 3 screenshots attached below are my monitor's resolution. They have both or each individual triode.
Thanks,
Josh
« Last Edit: November 20, 2021, 12:07:17 am by KungFuJosh »
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: Johnny10, Cubdriver, THDplusN_bad, Andrew_Debbie
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #126 on: November 20, 2021, 12:41:34 am »
Yeah, I definitely want to build one of these!
-Pat
Offline Johnny10
« Reply #127 on: November 20, 2021, 12:59:41 am »
Very Nice!
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline KungFuJosh
  • TEAS is real.
« Reply #128 on: November 21, 2021, 04:59:24 am »
For anybody interested, I'm going to order some more PIC chips to program, and then I'll get 5 to 10 kits ready. Initially they won't have anything on the boards, so I suggest anybody interested has or develops some SMT skills before proceeding with this set. For the future, I'm getting quotes on PCBA service to cover the 5 smaller SMT parts (there's also a couple larger ones setup for easy hand soldering that don't need any special skills).
Thanks,
Josh
Offline Shock
« Reply #129 on: November 21, 2021, 06:02:53 am »
Please start a thread in the projects forum.
Offline Cubdriver
  • Nixie addict
« Reply #130 on: November 21, 2021, 07:10:47 am »
Thanks,
Josh
I'm definitely interested.
-Pat
Offline KungFuJosh
  • TEAS is real.
« Reply #131 on: November 23, 2021, 06:27:33 pm »
The following users thanked this post: Shock
Offline lugaw
  • Country: jp
« Reply #132 on: November 25, 2021, 01:20:20 pm »
SMU gang represent!
(glances to the left, then to the right -- coast is clear, SPA gang isn't around yet)
Custom 3D printed feet and "panel" (bar) turn this SMU into a convenient bench tool. Actual work is done in jupyterlab / holoviews / pyvisa-py.
Please share the STL of your custom feet, I need it on my picoammeter. Thanks!
Online Roehrenonkel
« Reply #133 on: December 26, 2021, 03:19:47 pm »
At https://jacmusic.com/Tube-testers/index.html you can find under No.10 most of the digital/PC-controlled curve-tracers for tubes.
Have tried some but nothing is perfect. What i wanted is more accuracy and flexibility.
More than the kit that calls itself "professional tube testing system" in germany.
Not even grid-current measurement possible there. Nice software but Windows-only.
So i put some VXI-modules (16 Bit DAC +-40V, seven voltmeters and a PSU) together
with a selfmade relay-matrix 4-In 16-Out and some GPIB-Powersupplys.
For now controlled by Agilent-HP-VEE, would like to do that from my Raspberry.
Have also checked transistors and LEDs with it,
just depends on the controll-software and power-sources.
« Last Edit: December 29, 2021, 01:42:25 pm by Roehrenonkel »
The following users thanked this post: THDplusN_bad
Offline jjoonathan
« Reply #134 on: December 26, 2021, 06:40:38 pm »
SMU gang represent!
Whoops I must have missed this last time. Here they are!
Offline THDplusN_bad
« Reply #135 on: January 21, 2022, 05:53:00 pm »
Good Day,
this is not about a self-made curve tracer, but those interested in PC-based measurement equipment might be entertained by this.
I use a "Electronic Explorer" device from Digilent/US for a few years now. This is basically a simple USB-connected, FPGA-based multi-instrument that integrates an 4-channel oscilloscope, 2-channel arbitrary waveform generator, simple logic analyzer and a power supply in combination with a solderless breadboard. I primarily use it for the quick evaluation of simple circuits whenever needed. It also supports Bode plots etc. The "Electronic Explorer" hardware platform is outdated by now, but it still supported by Digilent's "Waveforms" software. If any Digilent employee reads this: Thank you for doing that.
Digilent (which is a NI company, by the way) has released a "transistor test adapter" some time ago. That is an add-on for their more recent USB-based instruments such as the "Analog Discovery 2" device. https://digilent.com/reference/test-and-measurement/transistor-tester-adapter/reference-manual
And so they have also added the required settings in form of a virtual curve tracer to the mentioned "Waveforms" software. I have created my own version of a curve tracer in Waveforms some time ago (this is primarily a configuration of the two-channel waveform generator, and not too hard to do). However, I have tried this new "tracer" configuration and attached are a few plots I have generated from a standard BC337-40 BJT today. (Side note: The noise level results from the wiring and the two curves on the right are artefacts).
It's quite nice to see how the curves are generated, a large data set gets acquired very quickly and how the data can be exported to a database, MS Excel etc.
Also, the software offers a 3D-view of the collected data that is quite fascinating. https://digilent.com/reference/test-and-measurement/guides/waveforms-curve-tracer
This is not a real curve tracer in terms that the voltage and current supplies are limited (+/-10V, 35 Ohms output impedance each channel for the "Electronic Explorer"). But it's an excellent starting point into the fascinating world of component testing. It's also certainly good enough to match some small signal transistors /BJTs or FETs/ as well as diodes.
Have a great weekend, all.
Cheers,
THDplusN_bad
« Last Edit: January 21, 2022, 05:56:48 pm by THDplusN_bad »
The following users thanked this post: Markus2801A
Offline 6SN7WGTB
« Reply #136 on: January 21, 2022, 06:58:03 pm »
I built the Paul Carlson curve tracer, but modified to be (a) SMD and (b) have a power op-amp to provide a split rail supply from a single external PSU.
I use it for go/no-go testing in circuits.
Shown below, inside and out, and with a germanium diode under test.
« Last Edit: January 21, 2022, 07:00:13 pm by 6SN7WGTB »
The following users thanked this post: kripton2035, Johnny10, THDplusN_bad, Markus2801A
Offline Martin72
  • Testfield Technician
« Reply #137 on: January 21, 2022, 07:23:19 pm »
Nice work !  :-+
Offline Electro FanTopic starter
« Reply #138 on: March 13, 2022, 09:28:42 pm »
Thanks to rstofer's posting in this thread:
https://www.eevblog.com/forum/beginners/oscilloscope-triggering-from-function-generator/msg4058536/#msg4058536
I came across this link to a thread on a curve tracer project:
https://circuitcellar.com/research-design-hub/create-your-own-i-v-curve-tracer/
- another nice inexpensive combination of hardware and software
The following users thanked this post: SilverSolder, Markus2801A
Offline deemarkay
« Reply #139 on: April 10, 2022, 03:43:25 pm »
Here's my copy of the ELV KS7000. It works quite well and has turned out to be a useful tool for the workshop when fixing stuff.
Hooking up devices with clip leads was not only very messy and annoying, it also resulted in nasty oscillations. So I decided to go the
Tektronix route and made up a testfixture. So far I've got this one that works for small & medium power transistors. I've got parts on order to make another one for TO3 packages. This works very well so far.
Certainly no Tek but ok for me.
Looks really nice! The testsocket adapter, frontpanel and all is very shmick!
I'm currently in the process of collecting all the parts for a build of my own and having trouble sourcing some components. Especially the relais are a mystery and it turns out even replacements for the transformer  are no easy feat to aquire. Could you share how you solved parts sourcing problems on this build?
Offline david77
« Reply #140 on: April 10, 2022, 04:24:09 pm »
Yes sure I'll help.
I use two transformers. One is 2x15V 0,5A for the OP's and CMOS stuff and a big toroid that used to give 2x44V output and I've added a few windings to get it up to 2x60V.
Ah yes, those Siemens Relais are long obsolete but not really necessary. Just use regular Relais, there's nothing special about them.
Offline basinstreetdesign
« Reply #141 on: April 11, 2022, 06:57:18 am »
Digital, smidgital...I've probably posted about this before but here is my home-built tube curve tracer.  I used it to answer a question about the biasing of some 6AU6's in a stereo amp I was making.
This is the first attempt at making it, which proved successful enough.
https://www.instructables.com/Tube-Curve-Tracer/
Then some added functionality came a bit later:
https://www.instructables.com/Tube-Curve-Tracer-Ver-11/
A word about my build style.  I don't like to spend a lot of money.  So parts are usually drawn from my glory boxes and whatever I have on hand.  If I can find enough workable stuff then it may happen that I spend exactly $0 on a project.  And so it was with this one.
Included is a shot of it in use and a shot of the HP 1741A showing the curves for one triode in a 12AX7 tube.
« Last Edit: April 11, 2022, 07:12:35 am by basinstreetdesign »
STAND BACK!  I'm going to try SCIENCE!
The following users thanked this post: THDplusN_bad, Markus2801A
Offline deemarkay
« Reply #142 on: April 15, 2022, 08:51:24 am »
Online RoGeorge
« Reply #143 on: April 16, 2022, 07:42:09 am »
This is from a Python script sending SCPI commands to a Rigol DP832 power supply, in order to browse/measure Vgs, Vds and Ids of a PHP45N03LT TrenchMOS.
https://www.eevblog.com/forum/testgear/rigol-dp832-power-supply-as-automated-curve-tracer/
Does Python qualifies as a curve tracer?  ;D
Offline caulktel
« Reply #144 on: April 17, 2022, 04:39:34 pm »
I bet not many have seen my curve tracer. https://www.nutsvolts.com/magazine/article/build-an-oscilloscope-octopus
Joel
N6ALT
The following users thanked this post: egonotto, edavid, RoGeorge
Offline branadic
  • Sounds like noise
« Reply #145 on: April 18, 2022, 07:52:56 am »
I have the updated version KLS 2.0 of DL4JAL's curve tracer, that recently got the upgrade to PIC18F46K80. The board rev2.0 with the improvements is discribed here:
https://www.bartelsos.de/messtechnik/untersuchungen-an-bauteilen/kennlinienschreiber
Attached a measurement of a 2SK170.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline David Aurora
« Reply #146 on: April 26, 2022, 10:41:44 am »
Anybody else got one of these? I picked it up in a deceased estate sale a while back, it seemed to be mid-repair (half the screws missing, cord cut off etc). Haven't been able to find any record of it ever existing, let alone schematics.
I cleaned it up a bit at the time and then kind of forgot about it because it needed all new switches and I couldn't be assed fully disassembling it, but I finally changed them over tonight after work and the thing is now 99% working (the switches were so bad that you kind of had to hold them in place to get any display and even then it was a crapshoot). All that's left to do now is troubleshoot the step generator, it doesn't put out anything on voltage mode.
I've got a Tek 576 arriving soon so I don't imagine I'll bother going much further with this one, but it seems way too nice inside to waste so it'll likely get passed on to my assistant or something if I can work the last bugs out of it
« Reply #147 on: May 02, 2022, 12:12:08 am »
New video from W2AEW on curve tracing.  As usual from W2AEW his teaching is outstanding; his videos on a scale of 1 to 10 are typically about a 12 to 20 or better for clarity and conciseness.
« Last Edit: May 07, 2022, 05:08:04 am by Electro Fan »
The following users thanked this post: BillyD, egonotto, Cubdriver
Online RoGeorge
« Reply #148 on: May 05, 2022, 09:46:18 pm »
This yellow alligator showed up once, while identifying the type of photodetector from a former punched-card reader.  The curve tracer was improvised from a Rigol DG4102 DDS generator, a scrapped transformer and a Rigol DS1054z oscilloscope in XY mode:
The bar of 12 optical sensors from 1975 proved to be made out of NPN phototransistors.
« Last Edit: May 05, 2022, 09:51:18 pm by RoGeorge »
