Author Topic: Show Us Your Curve Tracer  (Read 48926 times)
Offline Calvin
    • Calvin´s audio page
Re: Show Us Your Curve Tracer
« Reply #25 on: March 06, 2021, 07:23:01 pm »
Having waited for years, I ordered my locky_z on ebay as soon as he offered the latest batch last year.
Unfortunately does it not work as I hoped for  :-//
It mostly draws just weird fuzzy lines on the display.
So I just put it aside since I had no time to dig into the issue deeper.
I heard though that another user had similar problems and got a replacement.
Unfortunately is locky_z  hard to contact and doesn´t respond very well (starting from not giving a rating on ebay to not responding on mails).
My old Tech 576 is a much more trustworthy guy in comparison.  ::)
regards
Calvin
..... it builds character!
Offline Johnny10
« Reply #26 on: March 06, 2021, 08:49:14 pm »
What about the B&K Model 501A ?
My first Curve Tracer.
Now where did I put it?
Remember also that all of the Tektronix and B&K models came with terrific manuals,
« Last Edit: March 06, 2021, 09:09:31 pm by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #27 on: March 06, 2021, 10:45:40 pm »
I am glad you liked the content, Electro Fan.
The kit is really good as the schematics and the microcontroller code are freely available. Also, one additional aspect is the ability to create your own scripts for testing, as well as save the data in tabular text form for post processing. I haven't done that yet, but it is quite promising.
I am having a blast with it.
Offline rsjsouza
  • Eternally curious
« Reply #28 on: March 06, 2021, 10:52:42 pm »
Calvin, I don't know what extent of testing you did but, depending on the set conditions, the DUT will only show really squiggly lines as it is not properly biased. I did that at the beginning and was really miffed at the results.
For example, the software by default sets the base resistor to 1M, which is quite high for most of the general purpose bipolar transistors. Also, if the collector resistor is too high, the Ic will be too low and therefore potentially cause the transistor to be simply in cutoff.
At any rate, I am sad to hear that you had a bad experience. His user's guide has a very thorough debug section, though. Yes, not an ideal solution but still some hope. Good luck!
Offline Messtechniker
« Reply #29 on: March 07, 2021, 08:15:13 am »
My semi-finished  :) semiconductor curve tracer. Completed and verified D/A converter and USB link. Output stages need to be built one day.
More on this here:
https://www.dl4jal.de/kls/kls.html
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: rsjsouza
Offline FrancisM
« Reply #30 on: March 08, 2021, 10:06:22 am »
Here's my own one, designed for small signal transistors. I got the idea from an old Elektor article.
It can show output characteristics and transconductance curve of jfets or mosfets.
The sweep is an adjustable triangular wave of +-14V max, the current limit can be set to 25mA or 250mA. Done with a TL074.
The base (gate) is voltage driven by a pic18F1320 and a double buffered dac MCP4822. I select the base resistor with jumpers.
Having a single bipolar supply, the current is monitored across a 0.1 Ohm shunt in the emitter (source). It's then amplified 100x by an AD797 to the Y output. I can change triangular's wave frequency to get rid of the looping effect with highly capacitive transistors.
The result is not that bad on newer DSOs, no flickering at all with the right setup, but still not such a nice trace as with my TEK 2465B.
Things may probably change in the next coming years with affordable high definition scopes.
The first screenshot is from an NPN ZTX851, little transistor with big die. It behaves nicely at low Vce. I don't like the colour but can't change it.
The second one is the transconductance curve from an N chanel PF5102. It was first in the fridge, then on the setup and heated with an air gun. With persistence, one can see the sweet spot of it's zero tempco.
I also own a USB Locky_Z one. I got it many years ago at the first run for cheap. It's fully made of used parts and was first released for the chinese market. But it still works.
Francis
« Last Edit: March 13, 2021, 08:41:37 pm by FrancisM »
The following users thanked this post: rsjsouza, Dwaine, bd139
Offline Martin Hodge
    • MGH Designs
« Reply #31 on: March 09, 2021, 07:03:53 am »
A Tek 575 connected to an Eico 667 tube tester through a custom curve tracer circuit.
Curves are from a 6AU6 pentode.
The following users thanked this post: rsjsouza, Cubdriver, bd139, graybeard, K0ELB
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #32 on: March 09, 2021, 04:17:07 pm »
I have been considering how to adapt tubes to my 575.  Thank you for this example!
Offline Jay_Diddy_B
« Reply #33 on: March 10, 2021, 03:39:19 am »
Hi group,
I have a few. I have a Huntron 2000 for troubleshooting.
Tektronix 576 for looking at transistors and diodes.
Tektronix 571
My best curve tracer is an HP 4155B Semiconductor Parameter Analyzer:
This picture is Id and GM versus Vgs for 2N7002 MOSFET.
The vertical scale (Id) is logarithmic and goes from 1fA (1E-15) to 100mA (1E-1) 14 decades  :D
Regards,
Jay_Diddy_B
Offline Electro FanTopic starter
« Reply #34 on: March 10, 2021, 04:33:57 am »
Hi group,
Tektronix 571
(Attachment Link)
Regards,
Jay_Diddy_B
14 decades to a femtoamp?!  Very neat!
Offline jh15
« Reply #35 on: March 10, 2021, 06:39:42 am »
Where is pic?
I'll show you mine (Tek  575 with pussy on top enjoying the heat, , if you show yours. (Might just show 2 photos offset by eyelength for 3d.)
« Last Edit: March 16, 2021, 01:16:18 am by jh15 »
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline sorenkir
« Reply #36 on: March 10, 2021, 10:45:37 am »
This one is quite an oscure model (Br 01 from Leybold-Heraeus, made in Germany):
Front panel is mislabeled : read Uc instead of Ub on the right!
I think I will have to do a lot of reverse engineering to get it back to work, as it died the other day...
Michel.
« Last Edit: March 10, 2021, 10:47:27 am by sorenkir »
Offline Calambres
    • Piso-Tones
« Reply #37 on: March 10, 2021, 10:46:59 am »
I made one based upon the infamous "Thai Kit" (https://www.ebay.com/itm/141138017533).
Already talked about it some time ago in this very forum.
This kit is also heavily based upon an ELEKTOR magazine article (Dic. 1989). I made a small modification to the kit to let it switch between 8 and 4 curves and subsequently the total µA/mA. This is a photo of the guts while I was still prototyping it:
It needs a good ole CRO (preferred) with XY mode to show the curves.
The most interesting feature of my build is that it can compare (match) up to 6 transistors/FETs at the same time at the flip of a rotary switch. Here you can see it in action testing some transistors, first with four small transistors (2SC1815) and one power transistor:
The second is showing the details of four small transistor (2SC1815) curves:
« Last Edit: March 10, 2021, 11:48:25 am by Calambres »
The following users thanked this post: Electro Fan
Offline Ground_Loop
« Reply #38 on: March 10, 2021, 02:03:12 pm »
This is my vintage Heathkit. It has served me well. The one thing I would change about it is the single ended sweep to bipolar. It does sweep positive and negative, but not continuously. You need change the control settings to sweep the opposite direction. I gave some thought to modifying it, but gave up after realizing I would need to hack on the enclosure to accomplish it.
1190416-0
1190420-1
« Last Edit: March 10, 2021, 02:05:09 pm by Ground_Loop »
There's no point getting old if you don't have stories.
« Reply #39 on: March 10, 2021, 06:18:35 pm »
(Attachment Link)
(Attachment Link)
That's a nice combination of curve tracer and oscilloscope.  Definitely good idea to retain their vintage dignity.   :-+
« Reply #40 on: March 10, 2021, 06:26:24 pm »
Really nice post and congrats on your curve tracer.  I was going to ask how you did this:
"The most interesting feature of my build is that it can compare (match) up to 6 transistors/FETs at the same time at the flip of a rotary switch" but then I saw your link which explains your approach as you steadily worked it all out.  Your posts in that the thread and the whole thread had a lot of good info so I edited one of the posts at the front of this thread to make it easy to find the thread.
Offline Calambres
    • Piso-Tones
« Reply #41 on: March 10, 2021, 07:22:12 pm »
If someone is interested, I have a pdf of the original ELEKTOR article the Thai kit is based upon. Not that it is very diffiult to find but if someone wants it without much hassle, drop me a note.
The following users thanked this post: jpwolfe31, Anthocyanina
Online edavid
« Reply #42 on: March 10, 2021, 07:54:35 pm »
(Attachment Link)
(Attachment Link)
I disagree - I would never connect a curve tracer to an MCP scope like the Tek 2467B  |O
« Reply #43 on: March 10, 2021, 09:30:16 pm »
(Attachment Link)
(Attachment Link)
Your concern is using up the useful life on the MCP or something else?  (I'm guessing Ground_Loop doesn't trace curves all day every day, and his MCP likely has it's timeout feature operating.)
Offline Ground_Loop
« Reply #44 on: March 11, 2021, 01:32:09 am »
I also have 7 scopes on my bench and a 555 in the corner.   On the rare occasion that I use the curve tracer I usually go to the 67 because i have a preset for the curve tracer.  And the timeout works just fine.
« Last Edit: March 11, 2021, 01:50:40 am by Ground_Loop »
Online edavid
« Reply #45 on: March 11, 2021, 01:44:55 am »
The timeout is a convenience, but it won't protect the CRT from burns if you make a determined effort.
(MCP = microchannel plate image intensifier)
    • MGH Designs
« Reply #46 on: March 13, 2021, 04:14:59 am »
The circuit is designed by Dennis Tillman. Attempting to attach PDF... nope, too big.
Instead search for "An Inexpensive Vacuum Tube Curve Tracer Adapter for All Tektronix Semiconductor Curve Tracers"
« Last Edit: March 13, 2021, 04:18:13 am by Martin Hodge »
The following users thanked this post: tochnia
    • MGH Designs
« Reply #47 on: March 13, 2021, 04:28:06 am »
Here's the 575 testing the tunnel diode in the trigger of the 'b' timebase of a Tek 535A.
Vertical: 0.5 mA/div
Horiz: 50 mV/div
The following users thanked this post: Electro Fan, Cubdriver, K0ELB
« Reply #48 on: March 13, 2021, 05:42:24 am »
Horiz: 50 mV/div
Vintage Tektronix, tunnel diode, beautiful photography... doesn’t get much better.
Super Cool!  :-+ :-+
« Last Edit: March 13, 2021, 02:58:49 pm by Electro Fan »
The following users thanked this post: Martin Hodge
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #49 on: March 13, 2021, 06:15:59 am »
I built one of the Thai Kits tracers, it works well.
https://youtu.be/uU_KjH-jJnA
I also have a Tek 577-177 that I have to repair one day (blown tants etc) and a 4145A that I have to track down a bunch of triax cables to connect it to the test fixture (and do the SD card floppy drive swap and maybe a colour LCD swap too if I feel like spending money).
