Author Topic: Show Us Your Curve Tracer  (Read 62205 times)
Offline EinErik
Re: Show Us Your Curve Tracer
« Reply #150 on: May 15, 2022, 09:20:11 am »
With this new tracer, compared to my old lockyZ, this one is definitely better with no doubt >:D
https://www.diyaudio.com/community/threads/new-tracer-is-coming.379759/page-5
« Last Edit: May 15, 2022, 10:25:42 am by EinErik »
The following users thanked this post: msliva, THDplusN_bad, wolfy007, Markus2801A
Offline RichardM
« Reply #151 on: July 04, 2022, 12:10:13 pm »
I would love to make this version of the curve tracer. I don't suppose you are willing to share the PCB/Scematics ? I have the ELV articles.
Regards
Richard
Offline Electron123
« Reply #152 on: August 23, 2022, 01:31:22 am »
What's the difference between a "transistor curve tracer" and a more basic octopus version (like this https://www.qsl.net/kd7rem/pdf/octopus.pdf)?  I know the fancy versions have more features, but are they both able to test the same components? Or is the basic one not able to test transistors?
« Last Edit: August 23, 2022, 01:41:46 am by Electron123 »
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #153 on: August 23, 2022, 02:11:03 am »
A transistor curve tracer allows you to characterize the transistor or other device - see how it behaves under different drive conditions.  The octopus is more a go/no-go thing that tells you it works, but not much more.
In this image of a curve tracer, each slanted line represents a different base current; the sweeps are the collector current as Vce is increased and decreased at each base current step.  In this image, the vertical scale is 5 mA/division, and the horizontal is 5 V/division.  The base current steps are 0.01 mA each.  Note that it has two sockets and the big toggle switch, it is set up to permit two transistors to be connected and by flipping the switch back and forth you can see how closely they are matched.
-Pat
The following users thanked this post: edavid, bd139, K0ELB
Offline Cubdriver
  • Nixie addict
« Reply #154 on: August 23, 2022, 02:30:53 am »
To elaborate on how the curve tracer works, it applies a base current (or gate voltage if testing a FET), then sweeps the C-E (or S-D) voltage from minimum up to whatever max you've set.  It then increments the base/gate drive by the step interval and sweeps the C-E/S-D voltage back down to zero.  Increments the drive again, repeats the low-to-high sweep, increment again and high-to-low.  Lather, rinse, repeat until the desired number of steps have been generated.  The beam on the screen thus traces out the current through or voltage across the transistor under test.
The curves for a PNP device are similar, but start in the opposite corner of the display as the polarities are reversed from those of an NPN (top right for PNP, bottom left for NPN):
Curve tracers can also characterize things like diodes and the strike voltage of neon lamps (sometimes used as voltage limiters/regulators).  In this instance, the device in the curve tracer is a color-changing LED, and the photo was taken as it was lighting two of its emitters to get a blended color.  Each of the colored LEDs inside has a slightly different forward voltage, thus the dual curves with slightly different voltages and currents, and the jumping between the two curves is caused by the internal IC in the LED switching the two different LED dies on and off alternately:
-Pat
The following users thanked this post: Martin.M, egonotto, edavid, capt bullshot, bd139, ch_scr, K0ELB, Electron123
Offline david77
« Reply #155 on: August 24, 2022, 12:11:16 pm »
Regards
Richard
It's not that I don't want to share my PCB's but they're in one file married to the schematics and I'm not willing to put that online, copyright reasons, you know?
Maybe I can unmarry the layout and the schematics... I'll see what I can do.
Online G0HZU
« Reply #156 on: August 25, 2022, 10:54:32 pm »
I recently upgraded my curve tracer jig so it can produce accurate IV curves for diodes. The jig is homemade but I use a programmable PSU and a couple of decent bench DMMs to do the measurements. It's all controlled with a VB app in Windows.
The output data is then loaded into Excel as below and this system can test the diode down to a few nanoamps and compare the result to a theoretical curve as in the image below.
Offline croma641
« Reply #157 on: August 26, 2022, 03:41:15 am »
Hi, G0HZU,
what is Your curve tracer setup for other semiconducors ?
thanks
Offline jord4231
« Reply #158 on: September 24, 2022, 05:40:17 am »
Here's my curve tracer  :popcorn:
https://youtu.be/Jb6N5H1kS2Y
The following users thanked this post: Shock, egonotto, alm
Offline armandine2
« Reply #159 on: September 25, 2022, 08:34:24 pm »
I have the Elektor magazine linked below - so no excuse
https://worldradiohistory.com/UK/Elektor/80s/Elektor-1988-10.pdf
for not having a simple curve tracer?
Gold Capacitor Prize - 2025
Offline tautech
« Reply #160 on: September 25, 2022, 09:21:51 pm »
Not mine but member mawyatt had some time for experimentations of what he could do within the limits of a AWG and DSO.
https://www.eevblog.com/forum/testgear/fooln-around-with-dso-awg/
Reply #2 has his hand drawn setup and layout as an attachment.
« Last Edit: September 25, 2022, 10:49:27 pm by tautech »
Offline Calambres
    • Piso-Tones
« Reply #161 on: September 26, 2022, 06:03:29 am »
One year later (1989-12) Elektor showed a new instance of that curve tracer that was later cloned in the (in)famous Thai Kit. See my take on that kit in this very topic:
https://www.eevblog.com/forum/testgear/show-us-your-curve-tracer/msg3503702/#msg3503702
Offline TopQuark
  • Country: hk
« Reply #162 on: October 19, 2022, 10:26:12 am »
I'll put in my entry to the topic with probably the cheapest curve tracer mentioned in this thread.
I was once a teaching assistant for a mechatronics course in university during the pandemic lock down. It was not possible for students to access the lab gear on campus, all everyone had was an Arduino, some R and C and a couple of diodes from a basic component kit.
I was put in charge of designing a lab project for basic electronics, and I designed a fun "curve tracer" / "SMU" with the Arduino board. I have attached the lab manual I wrote for the project and a couple of test result plots. Mind you the students I taught were majoring in Integrated Systems and Design (not EE) and they were first or second year students, so the language of the lab manual was purposefully oversimplified.
What I hoped the lab would do was to instill in student's mind, the importance (and fun) of doing test and measurement, even if we were on a shoestring budget and locked down. I don't think many students understood or appreciated the lab project, but I think a few students got something useful out of the experience.
I'm not the one who knows how to crack Siglent licenses, that's someone else smarter than me.
The following users thanked this post: egonotto, Martin72, little.tesla
Offline mbrennwa
« Reply #163 on: February 24, 2023, 10:51:33 am »
Just stumbled over this thread. Cool stuff!
Here's my curve trace project: https://pypsucurvetrace.readthedocs.io
PyPSUcurvetrace takes a somewhat different approach than most other curve-tracer projects that require some specific hardware / board to work. PyPSUcurvetrace is a software toolbox that controls programmable power supplies to set and read the voltages and currents at the DUT. This means you can make a curve tracer from PSUs that are available off the shelf, and you choose the PSU units that suit your application: small transistors, power transistors, vacuum tubes, etc.
The PSUs don't need to be expensive "high end". For example, two RIDEN 6006P units can be had for about $300 or less, and will make for a very decent curve tracer setup!
PyPSUcurvetrace also allows controlling the temperature of the DUT during curve tracing. I attached an example of an IRFP150 power FET measured at 30°C, 50°C and 70°C.
PyPSUcurvetrace not only allows measurement of the curves, but also has post-processing tools for high-quality curve plotting and to determine the DUT parameters from the raw data files (e.g., bias voltage/current for a given operating point, gain parameter, output conductance). More tools like curve matching/pairing of parts are in the works...
« Last Edit: February 24, 2023, 10:57:46 am by mbrennwa »
The following users thanked this post: egonotto, edavid, msliva, THDplusN_bad, precaud, Markus2801A
Offline THDplusN_bad
« Reply #164 on: February 26, 2023, 11:08:08 pm »
Good Day,
Nice work, mbrennwa!
I have paused my activity here for some time - life happens...
At least, I have found some time to adopt my simple Python scripts for my Agilent N3280A component tester so it can also test MOSFETs now...
Plot taken from a BS170 N-ch. MOSFET attached.  ;)
Cheers,
THDplusN_bad
Online jonpaul
    • IEEE Spectrum
« Reply #165 on: February 27, 2023, 02:42:17 am »
tektronix 576, std, pulsed 100A front porch, many Tektronix and DIY sockets and adapters.
jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
The following users thanked this post: Shock, NF6X, Johnny10, THDplusN_bad, TERRA Operative, Martin72
Offline Edison
  • Country: cz
« Reply #166 on: March 17, 2023, 11:16:51 am »
Hi, I started building my tracker, what I could buy, I bought and ordered the rest of the parts, but the delivery company lost my shipment, so I got angry and got this - unfortunately the tracker arrived with a faulty function, managed to fix it, but not much - documentation no, all ICs have laser defaced markings. A repaired small TEK serves as a display.
A few photos - something from the repair of the oscilloscope and the resulting effect
« Last Edit: March 17, 2023, 11:38:53 am by Edison »
Everything works as the weakest link in the chain
The following users thanked this post: egonotto, RoGeorge
Offline Neepa
  • Mechanic by trade Electronics enthusiast by choice
« Reply #167 on: March 17, 2023, 09:44:29 pm »
That's kinda cute. Using that tiny mobile scope as a screen.
Below my Pride and Joy with it's new to me NOS rack handles. Test Fixture on the top left and still missing the connection cables for it. But those are under procurement.
Always a treat pushing the powerbutton and seeing the monster coming to life with its flashing LEDs and that jet turbine mascerading as a fan in the back.
Turbojet Mechanic playing EE.
The following users thanked this post: THDplusN_bad, Edison
Offline Edison
  • Country: cz
« Reply #168 on: March 17, 2023, 09:52:54 pm »
A beautiful piece of technology :clap:
I love these classic testers, but the size won't fit in my study, I'm unlucky, I have to miniaturize, I bought the Tek damaged, the connectors oxidized, the timer switch glued with hot glue and most importantly no probes - I couldn't let it die like this, it got a new power supply ( batteries are not needed) I restored it as best I could and it has been working like this for two years.
Offline 0culus
« Reply #169 on: March 18, 2023, 04:24:30 am »
Very good. A very sophisticated bit of kit, with a lot of uses. I use my 4145B quite a bit. Make sure you make plenty of back-up boot disks though, since the instruments depends on them to be useful.
Offline alm
« Reply #170 on: March 18, 2023, 09:17:53 am »
Both the 4145A and B can be fitted with a Gotek or HXC floppy emulator. That would reduce the boot disk problem to making sure you keep an usb stick or sd card around with the right file. Here are some links. Apparently the main challenge is getting the cable pinout right, but 4145A and B are quite similar in that regard.
https://hxc2001.com/showroom/HxC_Floppy_Emulator_Semiconductor_Parameter_Analyzers_HP4145A.html
https://torlus.com/floppy/forum/viewtopic.php?t=1595
https://torlus.com/floppy/forum/viewtopic.php?p=24043&sid=90a698af4dbda5c4568c26813d8da371#p24043
https://torlus.com/floppy/forum/viewtopic.php?t=3878
I'd think you could also get it to work with a Gotek drive and the open source FlashFloppy firmware (cheaper), but I only found a brief mention of that.
Online RoGeorge
« Reply #171 on: September 02, 2023, 06:20:40 am »
Not mine, it's from the 'xofunkox-scientific experiments':
Characteristics varistor
The following users thanked this post: egonotto, MegaVolt
Offline gjames50
« Reply #172 on: March 14, 2024, 09:21:42 pm »
Regards
Richard
I'm curious about the overall costs of your version of the ELV KS 7000. Paul's DIY has an updated version of it, but the build cost for his is just under 1,000.00 USD. I posted a reply to the forum post located here: https://www.eevblog.com/forum/projects/1986-transistor-curve-tracer-worth-while-building/
I converted the Gratis documents from ELV to English (although I need someone who speaks/reads German/English to help verify it).
Your take on this is very interesting. What are the copyright issues on yours? Since ELV is giving this information away for free now, it must be for some other reason, correct?
Thanks!
Offline watchmaker
  • Self Study in EE
« Reply #173 on: March 17, 2024, 08:56:05 pm »
Here is my Doc Brown (Back to the Future) version of the Thaikit. Curve Tracer, octopus for zeners and TCRL tester on one unit.  Makes for easy sorting.
2077253-0
2077259-1
Offline pac1085
« Reply #174 on: February 10, 2025, 05:38:35 pm »
2498627-0
My 576 and 570.  I also have a spare working 576 and a 575.  570 was partially restored by last owner, and I've been going thru it and bringing it to 100% recently.  Lots of drifty resistors.
