Author Topic: Show us your noise floor  (Read 1492 times)
Offline Jay_Diddy_BTopic starter
« on: September 05, 2024, 08:13:17 pm »
Hi group,
The recent introduction of the Keysight HD3 series of oscilloscopes has prompted a discussion on noise floor.
Please share your oscilloscope's noise floor here.
To get this started:
Tektronix MSO46 4-BW-500
Sample mode, full bandwidth, 1mV/div
Hi-Res Mode 1mV/div
Hi-Res Mode 5mV/div
Regards,
Jay_Diddy_B
« Last Edit: September 05, 2024, 08:17:22 pm by Jay_Diddy_B »
Re: Show us your noise floor
« Reply #1 on: September 05, 2024, 08:40:39 pm »
Hi, adding to the thread
Tektronix MSO24 2-BW-500
This scope does not have an internal 50 \$\Omega\$ termination. This is with input open.
And with the high-res mode turned on:
Regards,
Jay_Diddy_B
« Last Edit: September 05, 2024, 08:42:55 pm by Jay_Diddy_B »
« Reply #2 on: September 05, 2024, 08:44:53 pm »
Tektronix MDO4104-3  1 GHz scope
And with the high-res mode on:
Regards,
Jay_Diddy_B
« Last Edit: September 05, 2024, 08:46:45 pm by Jay_Diddy_B »
« Reply #3 on: September 05, 2024, 09:04:52 pm »
Agilent DSO-X 3034A (with BW50 500 MHz option)
And with the high resolution turned on:
I have run out of scopes. Please share yours  :D
Regards,
Jay_Diddy_B
« Last Edit: September 05, 2024, 09:07:50 pm by Jay_Diddy_B »
Offline sonpul
  • Country: ua
« Reply #4 on: September 05, 2024, 09:26:46 pm »
Siglent SDS1202X-E
« Last Edit: September 05, 2024, 09:43:22 pm by sonpul »
Offline Aldo22
« Reply #5 on: September 05, 2024, 10:00:46 pm »
The $150 Hantek DSO2000 is probably not comparable, but here it is anyway.
Normal Mode, 400kPts
HR Mode
Offline Fungus
« Reply #6 on: September 05, 2024, 10:09:11 pm »
Rigol DHO804: RMS ~66uV
« Last Edit: September 05, 2024, 11:39:03 pm by Fungus »
Online KungFuJosh
  • TEAS is real.
« Reply #7 on: September 05, 2024, 11:07:14 pm »
Here's my SDS2504X HD.
The following users thanked this post: egonotto, tautech
Offline joeqsmith
« Reply #8 on: September 07, 2024, 12:29:36 am »
SJL Gigawave 6400 prototype showing both normal and probability distribution modes.
Offline hpw
« Reply #9 on: September 07, 2024, 08:18:20 am »
Here some 8 / 12 / 14 bit simulations with 64K / 1M / 16M FFT & "von Hann FFT Window" and without any averaging.
So be carefully to compare FFT noise floor with various FFT size settings. Even used detectors algorithm.
Offline Furna
  • I still don't know
« Reply #10 on: September 15, 2024, 12:38:07 pm »
Siglent SDS824X HD
BW 20MHz
PP215 set 10X: CH1 1M and CH2 50Ω external terminator feed through. Vertical at 5.00 mV (limit when 10X)
Elditest GE2501 set 1X: CH3 1M and CH4 50Ω external terminator feed through. Vertical at 1.00mV
BW 200MHz
PP215 set 10X: CH1 1MΩ and CH2 50Ω external terminator feed through. Vertical at 5.00 mV (limit when 10X)
Elditest GE2501 set 1X: CH3 1MΩ and CH4 50Ω external terminator feed through. Vertical at 1.00mV
The sky above the port was the color of television, tuned to a dead channel.
Offline Furna
« Reply #11 on: September 16, 2024, 07:01:57 pm »
Siglent SDS824X HD
Offline trackersoft
« Reply #12 on: September 18, 2024, 07:08:24 pm »
Tek 784A all inputs at 50 Ohm 1 mv
