Author Topic: Show us your square wave  (Read 238042 times)
Offline Howardlong
Re: Show us your square wave
« Reply #325 on: February 02, 2017, 03:39:02 pm »
What's the prototyping board you're using?
Offline capt bullshot
« Reply #326 on: February 02, 2017, 07:00:56 pm »
This is a SP3T-50x50-G from BusBoard Prototype Systems. It has a copper plane on the bottom side, 50x50 mils pads on the top side and non-plated holes every fifth pad or so. It is a thin PCB, can be cut using a paper scissor.
Offline jpb
« Reply #327 on: February 02, 2017, 07:03:57 pm »
I've been using the LTC6957 demo board. Unfortunately I'm in the middle of moving house (again) so everything is packed up so can't show anything other than this very bad photo.
The rise times for LVCMOS output is around 700 to 800 psecs and much less for the LVPECL version.
http://www.linear.com/product/LTC6957-1
« Last Edit: January 12, 2019, 12:35:16 pm by jpb »
Offline Howardlong
« Reply #328 on: February 02, 2017, 10:42:13 pm »
Very nice, I'm sure I'll be adding a couple of those onto my next Mouser order.
Edit: do they spec the Er?
« Reply #329 on: February 03, 2017, 06:09:56 am »
Online tggzzz
« Reply #330 on: February 03, 2017, 10:01:09 am »
I would have thought that the variability of anything you would use as conductors on the topside would be more significant than the likely difference in Er. I'd simply assume 4.2.
Offline sorenkir
« Reply #331 on: March 25, 2017, 04:55:12 pm »
I have discovered that BG7TBL's 35M-4.4G USB Signal Source (based on ADF4351) generates a quite nice square wave with fast edges around 200ps.
Measured with my TDS520B-500MHz (in fact ~650MHz --> Tr=~538ps)
Michel.
Offline Muxr
« Reply #332 on: March 26, 2017, 05:13:05 am »
Don't really have a fast pulse generator, but I can show some relatively fast rise time on my RF gen.. as captured by the RTM 1054
I can reliably see the signal up to 1.2Ghz.. even up to 1.8Ghz is somewhat visible but the trigger starts failing pretty often at that frequency.
Offline AlphaRomeo
  • Country: ph
« Reply #333 on: April 16, 2017, 09:41:59 pm »
Thank you all for the postings.  I just got the Siglent SDG2042X, at 1Mhz the square wave is acceptable,  at 5Mhz starting to degrade very bad, etc. I thought I got a defective device. I need to dig more into how these things works. How the square wave is generated, etc. Reading your post helped me understand  that I did not get a defective generator.
« Last Edit: April 16, 2017, 10:14:24 pm by AlphaRomeo »
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #334 on: April 17, 2017, 06:52:34 am »
Might get better results with ARB mode=DDS and using square from built in ARB wfms.
Offline ADT123
    • Pico Technology
« Reply #335 on: April 28, 2017, 08:24:07 am »
Heard a colleague say "now that's a fast edge"
« Last Edit: April 28, 2017, 08:39:57 am by ADT123 »
Disclaimer: I have worked for Pico Technology for over 30 years and designed some of their early oscilloscopes.
We are always recruiting talented hardware and software engineers! Happy to answer Pico related questions when time permits but here as electronics is a hobby
Offline amspire
« Reply #336 on: April 28, 2017, 01:27:32 pm »
ADT123,
was that sampling scopes one of your projects? Having a go at building a sampling scope has always been something I have wanted to try. The principles are so simple, but I am sure it took a massive effort to get that 25MHz bandwidth. The waveform really is amazingly clean.
Historically, this is the technology that allowed scopes to be built with GHz bandwidths when scope mainframes were struggling to reach even 1 MHz bandwidth.
A pity the price is so out of reach of the hobbyist. I have always thought this is potentially a very cheap technology if the market was big enough - maybe not for 25GHz, but 5GHz bandwidth would be pretty good.
Am I delusional?  :)
Richard.
Offline WackyGerman
« Reply #337 on: April 29, 2017, 08:22:20 am »
Here are my results of measuring a 10 MHz squarewave from my Siglent SDG1010 with three different bnc cables .
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #338 on: April 29, 2017, 07:48:43 pm »
I know nothing about tech side... but as a concept, maybe it is possible to hack analog frontend of cheap USB scope having ETS? For example ~100EUR Pico 2204A has 2GSa/s ETS listed. Logically software is there, timing stuff is there...
Online Electro FanTopic starter
« Reply #339 on: April 30, 2017, 06:40:06 am »
That looks like a fast rise time but to keep things apples to apples most of the measurements here have been at 10% and 90% rather than 20% and 80%.
Offline ADT123
    • Pico Technology
« Reply #340 on: April 30, 2017, 08:39:55 am »
Richard - I designed most of the real time scopes with a parallel port starting with the ADC-10 in 1991 and hung up my soldering iron around 2001 with the ADC212/100 which included repetitive ETS sampling (https://www.picotech.com/about/history).
As for a lower cost / lower bandwidth sampling scope its an interesting idea.  Above a few GHz every component gets expensive if you want to do the job properly (connectors, PCB etc) but below say 5GHz things get a lot cheaper.  Will have a think.  Guess it depends on the market - hobby users often go for 2nd hand boat anchors which can be cheap and to be honest not everyone knows how to drive a sampling scope (splitters for trigger signals etc).
10/90 vs 20/80 rise time - thats a fair cop.  I just borrowed a waveform so when I get a chance will see if I can do better.
The following users thanked this post: cncjerry
Offline pigrew
« Reply #341 on: May 02, 2017, 12:16:16 am »
Tabor 8025, programmed to be 1Vpp, 50 MHz, 50 ohm terminated. 10%/90% rise time is 5.2ns, fall is 4.65ns.
Offline ADT123
    • Pico Technology
« Reply #342 on: May 02, 2017, 07:25:38 am »
10/90 rise time (see comment from Electro Fan a couple of posts again).  Scope rise time is 14ps, pulse rise time is 10ps.  Combined gives 18.74ps.
Please dont try to beat this - not sure I can respond with anything faster!
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #343 on: May 02, 2017, 11:08:15 am »
Noticed that on last Pico screenshot sampling rate is mere 10TSa/s, while on previous 16TSa/s ::) But guess both are adequate being "slightly" over Nyquist :P
« Reply #344 on: June 02, 2017, 10:50:22 pm »
It is very competitive with the best rise time we have previously seen (~16ps by EV):
https://www.eevblog.com/forum/testgear/40-ps-rise-time/msg935446/#msg935446
« Last Edit: June 02, 2017, 10:59:13 pm by Electro Fan »
« Reply #345 on: June 02, 2017, 10:57:18 pm »
Maybe someone can show us a sub picosecond rise time?
Offline Joel_l
« Reply #346 on: June 02, 2017, 11:16:41 pm »
Not fast - Siglent SDG5082
50 Ohm output, 50Ohm pass through terminator on scope.
« Reply #347 on: June 02, 2017, 11:30:50 pm »
Looks like I missed a faster contestant:  (5.22ps by Hugoneus/Shahriar)
https://www.eevblog.com/forum/testgear/show-us-your-square-wave/msg592751/#msg592751
« Last Edit: June 02, 2017, 11:32:22 pm by Electro Fan »
Offline TheSteve
  • Living the Dream
« Reply #348 on: June 11, 2017, 10:48:42 pm »
Not too horrible for ECL logic feeding multiple sources.
« Last Edit: June 11, 2017, 11:10:39 pm by TheSteve »
VE7FM
Offline R_G_B_
« Reply #349 on: June 23, 2017, 07:25:54 pm »
R_G_B
The following users thanked this post: Electro Fan, rx8pilot, qu1j0t3, RedDogAlpha
