today I want to present to you something I tried to get for quite some time. A 35 year old multimeter that was made in Vienna, Austria. I would consider to be one of the best available hand held multimeters of it's time. Even today, many of the specs are far from being outdated.
SIEMENS B1023developed and manufactured by NORMA Messtechnik GmbH in Vienna, Austria starting at about 1986 until the end of the 1980ies. In Austria it was mostly available as "NORMAMETER MP14".
In the 90ies, NORMA was purchased by LEM, and later on LEM was purchased by FLUKE, as far as I know.
I purchased the unit recently in east germany. It has a couple of calibration and inspection markings on it. It's condition gives away that it probably had seen a lot of action, but it is otherwise fully functional. I first did the teardown-images, the other pictures are done after I gave it some intense cleaning. The buttons and switches now feel almost like new.
For me this devices carries some sentimental value: One of the models from the same series (but directly from NORMA) was the first digital multimeter that I used when I still lived in Vienna. We were not allowed to touch them unless we learned our way around analog meters and could handle such an expensive device. Also they wanted us to understand the principles in manual ranging and understanding readings before using a comfortable device.
HighlightsUser Manual in manualslibThe B1023 is a 20700 count 4 1/2 digits digital multimeter with fast analog bargraph, math functions and a wide variety of optional features, like a data interface that you could use to connect it to your COMMODORE 64. Unfortunately the device I have was not extended with that interface module.
The DMM chipset of these meters are ASICs built by Austrian Mikro Systeme (AMS). Some of the components and ICs are SMD. One very interesting detail about this device: The shielding coveres virtually everything with only very few gaps. There are even multiple layers of shielding in the button-area.
It's display has a phosphorescent-kind backlight. You can "charge it" using any light source. It improves readability even in dim conditions even without actively "charging" it. Generally the viewing angle has some weak spots and is optimized for a more flat usage of the device.
Numeric readings are updated twice per second, the bargraph updates 25 times per second. Autoranging is quite fast at about 1s for voltage and higher resistance readings, and 2-3s for lower resistance readings. It's basic DC accuracy is 0.04% + 2. The bargraph has multimple different scales and can even be centered and "expanded" (zoomed).
Input protection was implemented according to the standards of it's time (DIN 57411-1A VDE 0411-1 from 1980). It seems to be well designed, gaps, extra insulation, even things that look like they have been added for blast protection. The manual provides a lot of details about that.
The meter has a wide variety of "math" functions, you can use them in most measurement ranges and even combine them. This includes relative, min/max, limit function with accustic violation indication, configurable dB. Example: The reference value of REL can be entered manually and you can then make a limit check +/- some value with centered bargraph view.
It is also possible to change the display update rate and reduce display counts and other things.
The leather case also acts as some sort of "protective holster", it's designed to be used in the case and even has a hole for the power switch.
The manual includes a schematic diagram of the device and is very detailed about everything. I wish I had such a manual for todays devices.
There was a huge variety of accessories available, like high voltage and high frequency probes, industrial data interfaces, high temperature probes, current probes, etc., it's listed at the end of the manual. My device came as basic set 2.
According to the manual the device adjustment/calibration values are stored in EEPROM.
Basic functional checkI was surprised to get perfectly precise readings for all functions where I could verify it. The youngest cal sticker on it looks like being at least 20 years old. I tested at ~23°C after >1h of thermal balancing and used the BM789 for direct comparison. DC voltages from nearby sources give mostly readings identical to the BM789, deviating by 0-1 counts.
DC Voltage (AD584JH):
* REF value: B1023 reading (BM789 READING)
* 2.5V: 2.499 (BM789: 2.4982)
* 5V: 5.001 (BM789: 5.0005)
* 7.5V: 7.500 (BM789: 7.499)
* 10V: 10.001 (BM789: 10.001)
Precision resistors:
* 100R: 100.05 (BM789: 99.97)
* 1K: 1.0002K (BM789: 1.0003K)
* 10K: 9.997K (BM789: 9.997K)
* 100K: 100.00K (BM789: 100.02K)
I checked some nearby diode in reach, the B1023 measured it at 0.4160V while the BM789 gave a reading of 0.4627V. Output voltage in this mode is 2.72V.
It could surprisingly light up all LEDs that I could grab (red, green, yellow, blue, white) and even gave me voltage drop readings for red, green and yellow.
All in all, it seems like the device is fully working and perfectly within spec. Remarkable.
I attached images of the device and the teardown. I did the teardown images first before cleaning it, the other pictures are done afterwards.
Have fun :-)
Martin
Table of brands and variantsAdded later on to this post, after several users posted more information. As an attempt to summarize it. I will update it if possible when I discover new things or people post information (links will be disclosed at the bottom of the table).
NORMA | SIEMENS | GOSSEN | GRUNDIG | ENERDIS |
NORMAMETER MP11 | B1020 | MAVO10 | DM60 | MULTITEST MT11 |
NORMAMETER MP12 | B1021 | MAVO20 | DM61 | MULTITEST MT12 |
NORMAMETER MP13 | B1022 | MAVO30 | DM62 | MULTITEST MT13 |
NORMAMETER MP14 | B1023 | MAVO40 | DM63 | MULTITEST MT14 |
Last update: 2021-07-26
Data sources: General online research; own device / manual; information / images posted by:
Neomys Sapiens,
shakalnokturnItalic: Assumption (confirmation required) for exact match.
NORMA seems to be the OEM and brand used in Austria
SIEMENS sold them in many countries for a longer time (units with green/cyan SIEMENS logo could be found)
GOSSEN probably sold them in germany, other countries unknown, same with GRUNDIG
ENERDIS sold them in France
