Author Topic: Siglent 1104X-E ground noise  (Read 498 times)
Offline 1audioTopic starter
« on: December 01, 2024, 06:25:50 am »
I have an 1104X-E which mostly works great. However since a lot of what I do involves looking at low level signals I have a constant problem with this instrument- Pretty much whenever The DUT is grounded I have a high broad noise floor that messes with any trace below several volts. I did some careful checking and I'm getting about 25 mV of 50 KHz spikes between the scope ground and everything on my bench. Is this switching supply leakage? Does anyone else have this issue? Any advice would be appreciated.
Offline tautech
Re: Siglent 1104X-E ground noise
« Reply #1 on: December 01, 2024, 07:00:38 am »
Most likely but not from the scope.
Your task is to find where the interference is coming from.  :popcorn:
Screenshots as evidence please.
Offline Kean
    • Kean Electronics
« Reply #2 on: December 01, 2024, 09:15:01 am »
That sound like interference from a nearby SMPS.  The most common cause mentioned here is LED lighting.
Try turning other things on/off in a systematic way to identify the source.
« Reply #3 on: December 01, 2024, 06:50:00 pm »
I just checked and the power ground the scope is on is 10 Ohms from the power ground the rest of the instruments are on. I have some power distribution checking to do before locating noise sources (I have lots).
« Reply #4 on: December 05, 2024, 01:37:58 am »
Thee real issue it turns out is intermittent connection in the probe shield at the BNC end. A small tug in the wrong direction and its open. Need connecting is 10 Ohms or more. All 4 probes show this problem. If I switched to a tek or HP probe the noise is much lower. Has anyone else had this issue with Siglent probes?
Offline Calambres
    • Piso-Tones
« Reply #5 on: December 05, 2024, 04:26:40 pm »
Nope! All the 4 probes for my 1104X-E work fine, 'though I must say that one of them was warranty exchanged because the 1x-10x switch was not working properly.
