Hi friend, i have bad osciloscome,
a need to decompres ads file to arhive
my osciloscp after flashing as brick,
but U-boot is alive annd need 3 files
this is console out:
Download Linux from USB to Nandflash...
reading ro_uImage
** Unable to read file ro_uImage **
reading rootfs.img
** Unable to read file rootfs.img **
reading datafs.img
** Unable to read file datafs.img **
** Unable to read file logo.bmp **
Booting from nand ...
how to mount or extract this files of the update file?
https://siglentna.com/download/15283/siglent sds1102cml+
good update log
[00]
U-Boot SPL 2013.01.01-svn29730 (Mar 27 2017 - 19:02:34)
config ddr_pll_config()++
config ddr_pll_config()--
nand_init+++++
nand_init-----
Lcd_Init()++
SetUpLCD()++
SetUpLCD()--
len=768052, height=480, width=800
Logo from nandflash: base=0x81000000; end=0x810bb81f; end-base=0xbb81f; rwsize=0xbb820; r=0x0
Lcd_Init()--
U-Boot 2013.01.01-svn29730 (Mar 27 2017 - 19:02:34)
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
set_default_env::7864
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot
(Re)start USB...
USB0: scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
reading ro_uImage
reading rootfs.img
reading datafs.img
NAND read: device 0 offset 0x3080000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-3.2.0+
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2157768 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
init started: BusyBox v1.13.2 (2012-04-08 17:28:57 CDT)
starting pid 519, tty '': '/etc/init.d/rcS'
rS in
/etc/init.d/rcS: line 15: setterm: not found
starting pid 536, tty '/dev/ttyO0': '-/bin/sh'
Processing /etc/profile... Done
/ # check_and_upgrade:starting...
mount_fs: rw,sync,ubi1_0,/usr/bin/siglent/usr
ubi1_0unattached
attach_ubi:datafs
attach_ubi:11
UBI device number 1, total 812 LEBs (103104512 bytes, 98.3 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
MOUNT_DIR_NAME = /usr/bin/siglent/usr
TEST_RESTURN =
is_fs_mounted 0 ---
is_need_upgrade
is_need_upgrade:not need upgrade
check_and_upgrade:end...
++mount_check_copy_appdata: starting
mount_fs: ro,sync,ubi2_0,/usr/bin/siglent/firmdata0
ubi2_0unattached
attach_ubi:firmdata0
attach_ubi:9
UBI device number 2, total 400 LEBs (50790400 bytes, 48.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
MOUNT_DIR_NAME = /usr/bin/siglent/firmdata0
TEST_RESTURN =
is_fs_mounted 0 ---
--mount_check_copy_appdata: ending
Load Fpga Success!
ECC failed: 0
ECC corrected: 0
Number of bad blocks: 0
Number of bbt blocks: 0
Block size 131072, page size 2048, OOB size 64
Dumping data starting at 0x00000000 and ending at 0x00010000...
Erasing 128 Kibyte @ 0 -- 0 % complete
Erasing 128 Kibyte @ 20000 -- 50 % complete
Erasing 128 Kibyte @ 20000 -- 100 % complete
The Help file load OK!!
I0101 00:00:10.805797 534 module.cpp:568] ---------------------------------------------------------------------------------------
I0101 00:00:10.828555 534 module.cpp:569] Creat Log
I0101 00:00:10.858596 534 module.cpp:464] rm -f /usr/bin/siglent/usr/log/Info_19700101-000010.534
I0101 00:00:11.086069 534 module.cpp:489]
vxi11_main = 11206
init_lcd_driver()++
g_vinfo.xres = 800
g_vinfo.yres = 480
g_vinfo.bits_per_pixel = 16
E0101 00:00:13.605361 655 dev_interpreter.cpp:332] the device = /dev/sda mount fail
I0101 00:00:13.653393 655 dev_interpreter.cpp:338]
№ТФШUЕМ /usr/bin/siglent/usr/media/U-disk0 device = /dev/sda1
FileHeader.product_type == 10000
version_flag == 1
xml_upgrade_id = 10000
Archive: /usr/bin/siglent/usr/usr/upgrade/config.zip
inflating: SDS1000_arm.app
inflating: sds1000_fpga.rbf
inflating: siglentlib.sh
inflating: ti81xx.ko
inflating: u-boot.img
inflating: udc-core.ko
inflating: update.sh
inflating: upgrade.sh
inflating: cfbcopyarea.ko
inflating: cfbfillrect.ko
inflating: cfbimgblt.ko
inflating: da8xx-fb.ko
inflating: datafs.img
inflating: firmdata0.img
inflating: g_usbtmc.ko
inflating: gpib.ko
inflating: help.bin
inflating: libglog.so.0
inflating: MLO
inflating: musb_hdrc.ko
inflating: NSP_config_upgrade_info.xml
inflating: ro_uImage
inflating: rw_uImage
update.sh starting ...
ubi0:rootfs / ubifs ro,relatime 0 0
rootfs ro
upgrade /usr/bin/siglent/usr/usr/upgrade/rw_uImage
Erasing 128 Kibyte @ 20000 -- 2 % complete
Erasing 128 Kibyte @ 40000 -- 4 % complete
Erasing 128 Kibyte @ 60000 -- 6 % complete
Erasing 128 Kibyte @ 80000 -- 8 % complete
Erasing 128 Kibyte @ a0000 -- 10 % complete
Erasing 128 Kibyte @ c0000 -- 12 % complete
Erasing 128 Kibyte @ e0000 -- 14 % complete
Erasing 128 Kibyte @ 100000 -- 16 % complete
Erasing 128 Kibyte @ 120000 -- 18 % complete
Erasing 128 Kibyte @ 140000 -- 20 % complete
Erasing 128 Kibyte @ 160000 -- 22 % complete
Erasing 128 Kibyte @ 180000 -- 25 % complete
Erasing 128 Kibyte @ 1a0000 -- 27 % complete
Erasing 128 Kibyte @ 1c0000 -- 29 % complete
Erasing 128 Kibyte @ 1e0000 -- 31 % complete
Erasing 128 Kibyte @ 200000 -- 33 % complete
Erasing 128 Kibyte @ 220000 -- 35 % complete
Erasing 128 Kibyte @ 240000 -- 37 % complete
Erasing 128 Kibyte @ 260000 -- 39 % complete
Erasing 128 Kibyte @ 280000 -- 41 % complete
Erasing 128 Kibyte @ 2a0000 -- 43 % complete
Erasing 128 Kibyte @ 2c0000 -- 45 % complete
Erasing 128 Kibyte @ 2e0000 -- 47 % complete
Erasing 128 Kibyte @ 300000 -- 50 % complete
Erasing 128 Kibyte @ 320000 -- 52 % complete
Erasing 128 Kibyte @ 340000 -- 54 % complete
Erasing 128 Kibyte @ 360000 -- 56 % complete
Erasing 128 Kibyte @ 380000 -- 58 % complete
Erasing 128 Kibyte @ 3a0000 -- 60 % complete
Erasing 128 Kibyte @ 3c0000 -- 62 % complete
Erasing 128 Kibyte @ 3e0000 -- 64 % complete
Erasing 128 Kibyte @ 400000 -- 66 % complete
Erasing 128 Kibyte @ 420000 -- 68 % complete
Erasing 128 Kibyte @ 440000 -- 70 % complete
Erasing 128 Kibyte @ 460000 -- 72 % complete
Erasing 128 Kibyte @ 480000 -- 75 % complete
Erasing 128 Kibyte @ 4a0000 -- 77 % complete
Erasing 128 Kibyte @ 4c0000 -- 79 % complete
Erasing 128 Kibyte @ 4e0000 -- 81 % complete
Erasing 128 Kibyte @ 500000 -- 83 % complete
Erasing 128 Kibyte @ 520000 -- 85 % complete
Erasing 128 Kibyte @ 540000 -- 87 % complete
Erasing 128 Kibyte @ 560000 -- 89 % complete
Erasing 128 Kibyte @ 580000 -- 91 % complete
Erasing 128 Kibyte @ 5a0000 -- 93 % complete
Erasing 128 Kibyte @ 5c0000 -- 95 % complete
Erasing 128 Kibyte @ 5e0000 -- 97 % complete
Erasing 128 Kibyte @ 5e0000 -- 100 % complete
Writing data to block 0 at offset 0x0
Writing data to block 1 at offset 0x20000
Writing data to block 2 at offset 0x40000
Writing data to block 3 at offset 0x60000
Writing data to block 4 at offset 0x80000
Writing data to block 5 at offset 0xa0000
Writing data to block 6 at offset 0xc0000
Writing data to block 7 at offset 0xe0000
Writing data to block 8 at offset 0x100000
Writing data to block 9 at offset 0x120000
Writing data to block 10 at offset 0x140000
Writing data to block 11 at offset 0x160000
Writing data to block 12 at offset 0x180000
Writing data to block 13 at offset 0x1a0000
Writing data to block 14 at offset 0x1c0000
Writing data to block 15 at offset 0x1e0000
Writing data to block 16 at offset 0x200000
++is 3.0 parition version
nand_init+++++
nand_init-----
Lcd_Init()++
SetUpLCD()++
SetUpLCD()--
Lcd_Init()--
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
cpsw
(Re)start USB...
reading ro_uImage
reading rootfs.img
reading datafs.img
Data Size: 2157776 Bytes = 2.1 MiB
OK
Starting kernel ...
starting pid 520, tty '': '/etc/init.d/rcS'
rS in
starting pid 537, tty '/dev/ttyO0': '-/bin/sh'
ubi1_0unattached
attach_ubi:datafs
attach_ubi:11
TEST_RESTURN =
is_fs_mounted 0 ---
is_need_upgrade
is_need_upgrade:need upgrade
check_and_upgrade: upgrade start ...
upgrade /usr/bin/siglent/usr/usr/upgrade/MLO
upgrade /usr/bin/siglent/usr/usr/upgrade/u-boot.img
Erasing 128 Kibyte @ 0 -- 100 % complete
Erasing 128 Kibyte @ 20000 -- 6 % complete
Erasing 128 Kibyte @ 40000 -- 13 % complete
Erasing 128 Kibyte @ 60000 -- 20 % complete
Erasing 128 Kibyte @ 80000 -- 26 % complete
Erasing 128 Kibyte @ a0000 -- 33 % complete
Erasing 128 Kibyte @ c0000 -- 40 % complete
Erasing 128 Kibyte @ e0000 -- 46 % complete
Erasing 128 Kibyte @ 100000 -- 53 % complete
Erasing 128 Kibyte @ 120000 -- 60 % complete
Erasing 128 Kibyte @ 140000 -- 66 % complete
Erasing 128 Kibyte @ 160000 -- 73 % complete
Erasing 128 Kibyte @ 180000 -- 80 % complete
Erasing 128 Kibyte @ 1a0000 -- 86 % complete
Erasing 128 Kibyte @ 1c0000 -- 93 % complete
Erasing 128 Kibyte @ 1c0000 -- 100 % complete
upgrade /usr/bin/siglent/usr/usr/upgrade/ro_uImage
upgrade_app:starting
upgrade_app:ending
is_no_firmdata0_partition:partion 3.0
check_and_upgrade: upgrade end... rebooting
nand_init+++++
nand_init-----
Lcd_Init()++
SetUpLCD()++
SetUpLCD()--
Lcd_Init()--
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
cpsw
(Re)start USB...
reading ro_uImage
reading rootfs.img
reading datafs.img
OK
Starting kernel ...
rS in
ubi1_0unattached
attach_ubi:datafs
attach_ubi:11
TEST_RESTURN =
is_fs_mounted 0 ---
is_need_upgrade
ubi2_0unattached
attach_ubi:9
TEST_RESTURN =
is_fs_mounted 0 ---
Load Fpga Success!
ECC failed: 0
ECC corrected: 0
I0101 00:00:10.685917 534 module.cpp:568] ---------------------------------------------------------------------------------------
I0101 00:00:10.711039 534 module.cpp:569] Creat Log
I0101 00:00:10.742288 534 module.cpp:464] rm -f /usr/bin/siglent/usr/log/Info_19700101-000010.534
I0101 00:00:10.832217 534 module.cpp:464] rm -f /usr/bin/siglent/usr/log/Warning_19700101-000013.534
I0101 00:00:11.008834 534 module.cpp:489]
vxi11_main = 11130
init_lcd_driver()++
g_vinfo.xres = 800
g_vinfo.yres = 480
I0101 00:00:12.443692 655 dev_interpreter.cpp:220] Udisk = U-disk0 not found notes
Could not create log file: File exists
COULD NOT CREATE LOGFILE '19700101-000012.534'!
E0101 00:00:12.445013 655 dev_interpreter.cpp:395] the u-disk sum = -1 is error
E0101 00:00:12.467742 655 dev_interpreter.cpp:406] the device = /usr/bin/siglent/usr/media/U-disk0 umount fail
E0101 00:00:12.472785 655 dev_interpreter.cpp:421] not erase the udisk = U-disk0
I0101 00:00:13.544532 655 dev_interpreter.cpp:338]
E0101 00:00:13.599209 655 dev_interpreter.cpp:332] the device = /dev/sda mount fail
i am don't know how hide long code,sorry
it is after i try update, iwant to copy log but i off it in momrnt
and my osciloscope is u-boot mode permanently
please help me to fix my mistake
