Any date for the next FW?
Oh dear, all the same 'features' are still there in P18.
All the Print BMPs I saved, saved as 751kB, they used to be 1.1MB, don't what that is yet.
I'll make a list.
They need to supply a list of the fixes.
I've managed to 'reset' something or other.
Took me quite a while to notice, but missing the (rarely used) LongMem option and "Siglent" off the screen!
Tried reloading the FW .18.
Any simple fix? Although nothing seems to effect my normal usage.
OK thanks, it's not life threateningly urgent, you may pass on my email if you want, but I tend to only check it once or twice a week.
When I confirmed 'Load' over the .18 FW file name, I was expecting it to go away for a few seconds and then say something like "FW .18 already installed. Continue ?", but it just switched straight to the "Updating firmware" screen.
When I confirmed 'Load' over the .18 FW file name, I was expecting it to go away for a few seconds and then say something like "FW .18 already installed. Continue ?", but it just switched straight to the "Updating firmware" screen.It may has something to do with this line in "update instructions" docx: Before updating the ADS file, the ADS file need to be renamed and ensured it’s name less than 9 letters.
Should we ask Siglent if this can be implemented ?That would be very nice. As I said, I thought that I would see the option to measure whatever math function you are using in "Measure" menu, I expected to find that option just where you select to measure CH1 or CH2, I mean, I expected it to also measure "Math".
Shifting a reply on Math measurements to here where it's more on topic:Should we ask Siglent if this can be implemented ?That would be very nice. As I said, I thought that I would see the option to measure whatever math function you are using in "Measure" menu, I expected to find that option just where you select to measure CH1 or CH2, I mean, I expected it to also measure "Math".I will send a request to Siglent that at least a good basic selection be offered in future FW.
I will send a request to Siglent that at least a good basic selection be offered in future FW.Have they replied?
I will send a request to Siglent that at least a good basic selection be offered in future FW.Have they replied?Yep. It's still in discussion of what Math OSD measurements to include.
Suggestions ?
